Old 03-31-2011, 03:41 PM   #1501
FangsCPO's Avatar
Originally Posted by WildBillMassey View Post
We should have them added to our site either today or tommorow.
Keep checking this link.....
http://www.igthobbies.com/category_s/40.htm
I hope it's the Rally 20 and 10 premounted. Those are really great once they warm up. Wow!!!
Any chance you'll carry GRPs??
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 04-01-2011, 01:25 AM   #1502
Default what brand of pinions
what brand of pinions are people using? I seen the rc-monster ones , but was wondering if the novaks are any good, or if someone can recommend some?
Joat is offline   Reply With Quote
Old 04-01-2011, 03:01 AM   #1503
SteveP's Avatar
Robinson Racing makes some pinions in 1-module. I have a set that goes from 10 to 20T, which should cover the entire range of what you need if you've got the right motor.
SteveP is offline   Reply With Quote
Old 04-01-2011, 07:15 AM   #1504
whipnet's Avatar
I use a clutch and bell on the GT car, but for my other rigs I use nothing but Robinson Racing pinions.
Beat Your RC Like It Owes You Money!!
http://www.RCCOH.com
whipnet is offline   Reply With Quote
Old 04-01-2011, 07:26 AM   #1505
snellemin's Avatar
Trader Rating: 16 (100%+)
Robinson racing is what I mostly use with my delrin/plastic spurs. Castle and RC monster for my metal spurs.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 04-01-2011, 10:40 AM   #1506
FangsCPO's Avatar
I'm using a Tekno Clutch Bell since I'm using the Tekno Traktion Drive. I check the springs and shoes every so often and they look like new still. I've used Robinson's in other applications and they seem to be pretty good to me.
TLR Team Driver
Old 04-01-2011, 01:23 PM   #1507
Raman's Avatar
Trader Rating: 46 (100%+)
Novak mod 1
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 04-01-2011, 01:58 PM   #1508
These guys have them : http://www.fgsupply.com/ At least thats were my friend on the west coast gets them.
williamw is offline   Reply With Quote
Old 04-01-2011, 10:28 PM   #1509
whipnet's Avatar
What springs are you running? I am running the smallest (.7) myself.
Old 04-02-2011, 12:34 AM   #1510
FangsCPO's Avatar
The Tekno guys suggest that I start out with 0.9 and that's what I've run ever since. It works for me. I use to be geared at 17/48 but dropped down to a 16/48 and that has help with better control. These things are just so crazy fast!!!
TLR Team Driver
Old 04-02-2011, 06:12 AM   #1511
whipnet's Avatar
Thanks, I have a couple of the Tekno clutches, I think I might set one up with .9 and try it out.
Old 04-04-2011, 02:33 AM   #1512
kcunamay's Avatar
Trader Rating: 20 (100%+)
Default Ipanema wheels/tires
Hello fellow GT8E racers.
I wanted to share some feedback regarding MY EXPERIENCE with the ipanema wheels/tires for GT8E. This isn't me hyping up a product, nor is it me bashing another. I've spent my hard earned chips on most of the GT8 tire manufacturers to include these. With this class gaining momentum, I hope that having several options will allow the class to grow and thrive.
Prior to today, I was mainly racing with 2 different manufacturers of tires. Weather decided which ones I would run.
It is my belief from direct experience with racing both NITRO and ELECTRIC GT8 classes that GT8E is much harder on tires than their NITRO versions. The gobs amount of tq readily available from the brushless/lipo powerplants asks much more from them. I have a set that is great initially but loses grip towards the end of the race and the other set is outstanding in warmer weather, but need several laps (4-5) to get up to temp. Both sets need a lot of driver input/correction that changes throughout the heat/race.
Due to being rained out for the last 2 race weekends, Today was the day I finally had an opportunity to test my new Ipanema purchase. I was very curious to test their new wide rear tires and I am glad that curiosity got the best of me! We raced with the OC CIRCUIT crew and I must say that the tires are phenominal. NO SETUP changes were done to the car, just a change in tires which yielded instantaneous grip that lasted throughout the heat/main. It was very easy to drive the car fast with nice tight lines. The wear was also outstanding.
I highly recommend others to try them. I'm certain you won't be disappointed.
GT8E ROCKS!!!
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 04-04-2011, 10:31 AM   #1513
FangsCPO's Avatar
Great info Jai!! How do you think these would do at Corona? I'm guessing pretty damn good since that area already has pretty good traction. I'm on the fence on this one but if they can actually hold their traction throughout that whole race that's great.
TLR Team Driver
Old 04-04-2011, 11:19 AM   #1514
teknorc's Avatar
If you're running the Elektri-Clutch (freewheeling like nitro), 0.7mm is the way to go.
If you're running Traktion Drive (always engaged, slipper), we suggest starting with 0.9mm TD springs. If more traction is available, go stiffer. If you want more traction aid, go lighter.
Tekno RC
www.teknorc.com
teknorc is offline   Reply With Quote
Old 04-05-2011, 04:41 AM   #1515
Jspeed's Avatar
Jai,
Thanks for trying our products.
Congrats on the TQ & Win. Your lap times in GT8 look fast from lap #1, very happy our slicks hooked you up. That 16.1 lap is impressive, hope to see you break into the 15s next time your race at Surf City too!
To see the results click here.
Thanks again, all the best!
Jspeed is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 01:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 04:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 10:39 AM
SEO by vBSEO 3.5.0
