    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree515Likes
Old 10-04-2013, 08:56 PM   #1396
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by mikpiz View Post
I'm all for a spec tire . especially if they are cheap and pre mounted . However I think you should wait untill the end of this season to make a offical rule.
I personally just bought two sets of HPI pre mounts to run at the Halloween classic and If I just tossed close to $100 dollars out the window on top of the $70 bucks I blew on 2 n motors that are no longer legal - a rule change you guys made without any kind of warning . Well then this " Fun / Cheap " second class won't be fun or cheap at all.
From what I have heard, this rule will not be changed this season. Like yourself, people have already bought stuff to run this season. Kevin said for the hurricane races he organizes that they will use any treaded tire for this. I believe that the ride tires will only be required at the nationals held at harbor hobbies at the end of the season. Other then that run what you got. I don't think there will be any tire po-po's until the nationals race.
I should be at the Halloween Classic running USGT as well. I don't know anything about these motors you are talking about, but personally I wouldn't care if you ran the $35 motors if it's not some "Outlaw" motor... I don't know about the rest of the people running in it though.
Travis S is offline   Reply With Quote
Old 10-04-2013, 08:57 PM   #1397
Tommy R's Avatar
Trader Rating: 20 (100%+)
I'm cool with a spec tire for USGT, but it must perform and wear well on carpet *and* asphalt. It should also be available unmounted so we can use our own wheels. And I'd be undecided about tire foam restrictions. I'm leaning toward none.
Tommy R is offline   Reply With Quote
Old 10-04-2013, 08:57 PM   #1398
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I personally just bought two sets of HPI pre mounts to run at the Halloween classic and If I just tossed close to $100 dollars out the window on top of the $70 bucks I blew on 2 Trackstar motors that are no longer legal - a rule change you guys made without any kind of warning . Well then this " Fun / Cheap " second class won't be fun or cheap at all.
I agree I dont think this rule change will take effect until the first of the year or later.
Im part of a race series in my area and what we have done for this season's series is that we will allow the old rules to be used for this season....but...we are asking guys when they have to or want to buy new tires to just start buying or using the Ride tires when they can. I dont see why any local track couldnt do the same thing just allow any of the tires in play now to be used and then after the season or what ever just start to follow the national rule set.
As far as the motors the change to the rules closed a big hole that needed to be closed before it got outa hand. I know it sucks but its for the greater good that this hole was closed. If it wasnt then we would all be running out and buying outlaw or some crazy off brand thats not ROAR legal to see if their motor is faster. As it is now most ROAR approved motors are about the same speed. If you still have your other non ROAR motor ask your local track if you can still use it to club race. Just know that if you want to race at a race that is following the national rules set you would need to follow them. Really this is no different than any other class out there. When you go to a ROAR race you have more rules to follow and might need to buy something but 9 times outa 10 you dont need to be 100% ROAR legal to club race at most tracks accross the country.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-04-2013, 09:02 PM   #1399
Kevin K's Avatar
The tires will be sold with rims and with out from what Im told. The tires come with an insert and this will be the mandated insert...what they come with is a good insert to use all around. We dont want it to turn into an insert war. The tires do work well on asphalt from what we have seen but again not all asphalt is equal so the southern or warmer areas might not see the same results just based off what happens with the VTA tires.
Old 10-04-2013, 09:13 PM   #1400
Travis S's Avatar
I just got my tires and rims today as a matter of fact. So here is a picture of the insert. It's about the closest thing to a molded insert I have seen that is open cell foam.
Old 10-04-2013, 09:35 PM   #1401
I'm not trying to bitch and stir the pot , I have just had some bad timing with this class. I was at a race UF1 race and saw this class run as the second class and really liked what I saw so I came here to research it out a bit , what motors , tires , bodies to run and starting ordering parts. Seemed like the day after I ordered the Trackstar's they were banned ! Like I said but timing . Just don't want to see the same thing happen with the tires I just bought 2 weeks ago .
mikpiz is offline   Reply With Quote
Old 10-04-2013, 09:38 PM   #1402
speaking of tires . Arer the Dynamite DYN7960 pre mounts the same as the ride tires ? Sure look like it to me
http://www.horizonhobby.com/webapp/w...pe=productgrid
Old 10-04-2013, 09:46 PM   #1403
Kevin K's Avatar
I fully understand and you are not alone....I just want to show the reasons behind the change to the rules thats all.
They are the same tire not sure if the Dynamite ones are still being sold or if they are just selling off old stock. They had more choices as far as rims in the past and not anymore. I think that they changed when Thunder Power took over Ride in the US. The tires will be coming in as Ride tires and will be sold under the Ride name.
Old 10-04-2013, 11:44 PM   #1404
Trader Rating: 53 (100%+)
LOL i always thought it was ROAR approved motors
+1 spec tire
Rick Hess
Yokomo-Amain-Protek RC
R&C Hobby shop Clarksville TN
RCP Customs-RC Juice
rkhess is online now   Reply With Quote
Old 10-08-2013, 10:10 AM   #1405
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Got question. A local racer gave me these hpi x pattern tires last week, tried them and they worked good. Surprisingly they don't even rub on body like my old one did. I'm at 3.20fdr whrn I run the 24mm slicks but since these are much taller other than lowering ride heigth should I drop a tooth as well?
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 10-08-2013, 02:35 PM   #1406
Tommy R's Avatar
I'd say it depends on your track size, the tightness of the turns, the ambient temperature, and if you're running fans, etc. Personally, in Texas heat, the tallest I ever ran was a 3.32 FDR with a fan and it would come off in the 150-160 range. 3.2 may be okay if it's a big, open layout that flows smoothly.
Old 10-08-2013, 04:17 PM   #1407
Mr.juarez's Avatar
Track temp is 120* ambient is around 85ish and have a fan. Just wasn't sure if I should drop a tooth or take.motor timing out to compensate for taller tire
Old 10-08-2013, 05:59 PM   #1408
vivo quevas's Avatar
Trader Rating: 18 (100%+)
The track is 135x70 it is free flowing. Mr. Juarez gear 3.2 I have the same motor geared 3.5 I lost to him by 3 seconds last race and he had a fast lap .3faster then my fastest lap. We have the same motor close to the same timing our motor temps and we are 1 second slower then the 17.5 expert and as fast as the 17.5 Intermediate class.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 10-08-2013, 06:10 PM   #1409
Travis S's Avatar
Well if you liked where you were prior then I would assume yes you would want to go down a tooth. How do them foam guys calculate rollout??? Maybe you could try that to see the difference. I know the X-patterns are much taller then the Ride tires I used at the southern nationals.
Old 10-08-2013, 08:00 PM   #1410
I never have calculated roll out but here is a roll out calculator. Check out TQ's gear chart I use it a lot!
http://www.tqrcracing.com/rc_tools/rollout.asp
http://www.tqrcracing.com/rc_tools/gearing.asp
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4464 Yesterday 03:19 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 10:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 10:24 PM
