    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree395Likes
Old 10-01-2013, 08:25 AM   #1366
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Originally Posted by Travis S View Post
Batteries just need to be ROAR legal for USVTA. That is the only limitation. I think the Tamiya Mini Cooper body is for the M02,M03 chassis and I don't think it would fit a standard 4wd car. If it does it will not help the cars handling so I wouldn't recommend it. You could run it under USGT rules though. You can also run a USVTA body as well. They are 200mm wide so the wheels will be tucked in a bit or you can run some larger hexs or different offset wheels if you wanted. I myself would stick with the 0mm offset and standard wheel hex's because the car tends to work better this way and just have a bit more wheel tuck inside the body.
Thanks for the info. Looking at the USVTA site it says they have a limitation of up to a 5000mah battery?
Thanks for the tip on the body. I am going to sit down with her and show her the various bodies available initially from HPI to get an idea of what she likes from there. She'll probably start with some VTA tires as I believe I got a set on the way too.
Lastly, anyone got a setup they recommend for Xray T3s on carpet to start with?
Thanks everyone for all your help!
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 10-01-2013, 08:36 AM   #1367
Travis S's Avatar
Trader Rating: 46 (100%+)
USVTA is a limit of 5000. USGT is ROAR legal. I thought you were asking about USGT.
Travis S is offline   Reply With Quote
Old 10-01-2013, 09:06 AM   #1368
Tech Legend
Cain's Avatar
Sorry, I got confused on this part of your post:
As I was debating between the two classes and being setup basically for both (maybe USVTA body for myself as I like the firebird look), having stuff already legal battery wise would be a plus for reuse. But no worries, all set for info on that then.
Anyone here running heavy battery packs versus common weight packs? If so, what kind of setup difference have you noticed versus common weight ones? (stiffer spring, etc).
Old 10-01-2013, 09:35 AM   #1369
Travis S's Avatar
My brain was thinking one thing and my figures typed another... I fixed the original post. So lets try this again.
Batteries must be 5000 or lower for USVTA
USGT they only need to be ROAR legal.
Old 10-01-2013, 10:01 AM   #1370
Tech Legend
Cain's Avatar
no prob, have that happen myself a few times too lol. Thanks for responding, I really appreciate that!
Doing some research on the HPI molded wings, I am looking am looking at these three:
http://www.hpiracing.com/en/part/30093
http://www.hpiracing.com/en/part/85197
http://www.hpiracing.com/en/part/85288
I am assuming they are pretty much all the same durability, but just wanted to confirm is anyone feels one type works better than the other from a durability perspective.
Also, I am assuming the tall lexan subaru wing that comes with the body would be illegal correct?
this image:
Old 10-01-2013, 10:49 AM   #1371
NutDriver's Avatar
Trader Rating: 15 (100%+)
With so much more diversity possible with the USGT body rules, I have been thinking "out-of-the-box" and have found some interesting bodies. DeltaPlastik from Italy now has a US distributor. Check out the DeltaPlastikUSA page on Facebook. I have a couple of Alfa Romeo 155 DTM bodies in 200mm on the way now. :-)
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 10-01-2013, 10:52 AM   #1372
robk's Avatar
Trader Rating: 22 (100%+)
this image:
That wing is perfectly legal as long at it fits within the 10mm chord rule. You can mount the wing up in the air, as long as it's 10mm
Old 10-01-2013, 11:07 AM   #1373
Tech Legend
Cain's Avatar
hmm, I probably misinterpreting the 10mm rule lol. is it the actual height from the body to the top of the wing, or, from the bottom of the actual wing portion to the top of the wing portion?
Again, I apologize beforehand if this is common knowledge.
Old 10-01-2013, 12:51 PM   #1374
robk's Avatar
You are measuring from the bottom of the wing, to the highest point on the trailing edge of the wing. I think chord may actually be the wrong term. I guess it's really just the height of the wing.
Old 10-01-2013, 01:07 PM   #1375
Tech Legend
Cain's Avatar
awesome thanks!
Old 10-01-2013, 02:06 PM   #1376
NutDriver's Avatar
http://home.comcast.net/~venicesailo...st/Image17.jpg
URL for loose definition of chord
USVTA member #111
Old 10-01-2013, 02:11 PM   #1377
Trader Rating: 25 (96%+)
Scott
I contacted the admin for DP and he gave me the following link to his temporary storefront on eBay here:
http://www.ebay.com/sch/deltaplastik...p2047675.l2562
billdelong is offline   Reply With Quote
Old 10-01-2013, 02:19 PM   #1378
NutDriver's Avatar
I expect that they will be expanding their stock of 1/10th scale bodies soon. I have three of their 200mm 1/10th scale bodies and they look MUCH better than the pics on the www.DeltaPlastik.it site.
If you find bodies that you like on the DeltaPlastik.it site, you can e-mail Ben at DeltaPlastikUSA@gmail.com for ordering info. They also have 1/8th scale and other scale bodies as well. He offers volume discounts (10 or more pieces) and if you are patient (6-8 weeks), he can sometimes arrange custom paint jobs as well.
Ben says that if you mention "NutDriver Racing", that he'll include a free set of Lexan scissors and a hobby knife with 5 extra blades!!
USVTA member #111
Old 10-01-2013, 03:00 PM   #1379
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
I expect that they will be expanding their stock of 1/10th scale bodies soon. I have three of their 200mm 1/10th scale bodies and they look MUCH better than the pics on the www.DeltaPlastik.it site...
Google Translate worked pretty well on that site!
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: Losi & XRay
Rodarbal is offline   Reply With Quote
Old 10-01-2013, 03:20 PM   #1380
NutDriver's Avatar
Google Chrome with translate almost automatically.
USVTA member #111
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4332 Yesterday 08:15 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
