    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree10Likes
Old 12-25-2012, 08:15 PM   #766
dan1714's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Kevin K View Post
I think the solaris tires are consistant just the life doesnt seem to be there like we were getting out of them last season/year. Dont know if the tires changed or its another year and we are going faster in the class Im not sure. Belted Pro-Comp X-Patterns are good they can be a little too grippy at times I like the D-comp ones better. I havent ran the Advan's in a long time but last I remember they were really close to the Pro-Comp X-Patterns....dont forget that the Advans are a 24mm tire and the X-patterns are 26mm.
Thanks for the detailed info Kevin. I may try the Pro-Comp X-patterns as my car is set up with a bit of a push anyways.
We've been running the belted X's at our track since we started USGT (about the time USVTA switched to 25.5). Our experience is they are best the first few runs then fall off slightly. After that they stay quite consistent until they are pretty much totally worn out. We experimented with some cheaper options but they never seemed to be as consistent through the life of the tire so we went back to the belted x's exclusively.
Thank you too padailey. Excellent feedback. I just noticed the change to the rules, so I'm still trying to work out what to try first.
dan1714 is offline   Reply With Quote
Old 12-25-2012, 09:28 PM   #767
cementsurfer86's Avatar
I've also heard some grumblings about the different feel of the Solaris tires from one pack to the other..... X-patterns may not be the greatest, but they have been consistant for me, set after set.
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 12-31-2012, 12:27 PM   #768
JCarr's Avatar
New body for the winter season. Hope to test it out in the next week or two.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 12-31-2012, 02:28 PM   #769
jpk4ud's Avatar
Looks great Jon, I'll try not to get any of my paint on it, can't promise anything but I'll try.
Losi SCTE
Losi 22SCT
Slash 2wd
TC5 set up for USGT
The Hobby Shop in Dayton, Ohio
jpk4ud is offline   Reply With Quote
Old 01-05-2013, 12:24 PM   #770
Trader Rating: 42 (100%+)
I'm going to put my first USGT car together. I was looking at HPI web site for a pre painted body. I like the HPI 7706 ( pre painted NSX). In the picture on their web site it shows a hole in the window for a nitro car. Is there any prepainted bodies avail that i'm missing ?
Mike
miket3 is offline   Reply With Quote
Old 01-05-2013, 01:45 PM   #771
Default Pre-painted body
HPI #7265 Mazda RX-7 190mm works great in USGT
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 01-05-2013, 02:14 PM   #772
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Mike
Tamiya also sells pre painted bodies check them out.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 01-05-2013, 06:52 PM   #773
Default USGT
thanks for the suggestions. parts are ordered.
Will a 5000 MAH lipo work in this class or do you guys recommend more MAH ?
Mike
Old 01-05-2013, 07:40 PM   #774
Kevin K's Avatar
Mike
You should be fine I normally only put in about 19-2400mah after 6 minutes....with 8 min I normally put back 27-3000mah.
So 5000Mah good....I think anything over 4000 is good!
Old 01-09-2013, 08:06 PM   #775
Default USGT VS USVTA lap times ?
A couple of us ran our cars tonight for the first time. We were in USGT trim , except with the VTA camaro bodies (our old practice bodies).
we have work to do, gut i was surprised how well the x patterns worked. I was also surprised the 21.5 wasn't that much faster than the 25.5, unless were way off on set up.
For those of you who run both USVTA and USGT what's an normal lap time difference ?
Also can you guys who run both cars at the same track tell me what FDR you run in each class so we have a starting point there.
Thanks for all the advice so far.
Mike
Old 01-09-2013, 10:33 PM   #776
Mike
Our combined class has both styles running a 25.5, however, I've found that with clean driving on a medium-to-tight track, there's not much difference between the 21.5 and 25.5. Right now, in USGT trim, with a 25.5, I'm at a 3.28 FDR. We have a fairly large-sized carpet track, so this may be a taller gear than most tracks. This gearing is low, so corner speed is a must, but it's fast.
And yes the X patterns work pretty darn well for what they are. They do seem to wear quicker than the VTA tires, so watch out for that.
Old 01-09-2013, 11:25 PM   #777
Kevin K's Avatar
Mike
Change to a USGT body you will see the times change they are usually alot lighter then the VTA bodies from what I have seen.
Yeah X patterns are not that far off normal sedan tires as far as lap times....cost and life span is a different story.
Most times for us at my track the Fastest USGT lap is about .5 faster then the fastest VTA lap time. But this would also depend on track size a smaller track this gap would be less. Like our current lay out I think hot lap in VTA is 10.0 and USGT is 9.5. Most times the FDR's from what I have seen change depending on driver and motor...most VTA is around 3.5 and most USGT is around 3.8 but again this isnt always the same some guys run higher or lower depending on what their motor has.
Old 01-10-2013, 04:30 AM   #778
howardcano's Avatar
Trader Rating: 35 (100%+)
At the Hobbyplex in Omaha, a big indoor carpet track, my USGT is about 7% faster than my VTA. The USGT has an FDR of 3.85, with a Novak SS set to about 45 degrees advance. The VTA has an FDR of 5.06, with a Novak Ballistic set to 45 degrees advance. The Hobbyplex restricts the VTA FDR to 5.0.
That's not much of a difference in lap times considering the huge difference in power/weight ratio. As usual, lateral g's are the most important thing.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-10-2013, 05:01 AM   #779
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
See below the results from our New Year's Day race at The Track @ Harbor Hobby. Fast lap in USGT is about .6 faster than fast lap in USVTA.
http://www.liverc.com/view_result_fi..._(A3_Main).xml
Trans-Am Round# 3
Top Qualifier is Pepe,Ken 34/6:07.039 (Rnd 1) Race# 16
The Track at Harbor Hobbies
Position Driver Name Car # Laps Race Time Fast Lap Behind Qualifier #
1 Devroeg,Richard. 2 45 8:08.044 10.241 2
2 Larson,Michael 3 45 8:09.850 10.321 1.806 3
3 Hendrix,Jeff 5 44 8:00.627 10.328 5
4 Pepe,Ken 1 44 8:03.060 10.082 2.433 1
5 Zoerner,Justin 4 43 8:06.018 10.537 4
6 Seils,Carl 6 41 8:11.883 10.969 6
7 Davis,Bob 7 21 4:20.689 10.891 7
USGT Round# 3
Top Qualifier is Murphy,Rich 36/6:00.350 (Rnd 2) Race# 17
1 King,Rob 2 47 8:01.804 9.655 2
2 Stegen,Jimmy 3 47 8:05.139 9.512 3.335 3
3 Pepe,Ken 4 46 8:10.448 9.849 4
4 Zoerner,Justin 6 45 8:08.217 9.966 6
5 Devroeg,Richard 5 42 8:00.034 10.067 5
6 Schoenbrod,Larry 9 42 8:07.925 10.723 7.891 9
7 Seils,Carl 8 38 8:06.213 10.959 8
8 Schoenbrod,Mathew 10 34 7:16.277 10.847 10
9 Hendrix,Jeff 7 13 2:32.800 10.652 7
10 Murphy,Rich 1 0 0.000 1
Mike
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M06|F104 Pro|F103RM|RM-01
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Old 01-10-2013, 05:15 AM   #780
orcadigital's Avatar
Trader Rating: 61 (100%+)
Mike
We actually saw a much larger difference in lap times between VTA and USGT. Track is pretty fast, indoor high bite carpet. USVTA best time is a 10.9, with an average top 5 driver running 11.3 or so. Top USGT time is a 10.1, with averages 10.4 or so, again for the faster guys. 17.5 TC Blinky runs high 9's average with a 9.2 best (best I have seen was 9.5, but I am told the 9.2 happened).
Most VTA running 3.8 to 4.1, USGT running more in the 3.0 to 3.4 range, and 17.5 TC varies a lot on motor, but 3.8 to 4.5.
Oddly, we have actually found 21.5 powered cars to be closer to 17.5 TC then to VTA in overall laps and times, but seems to be a nice step in between both.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4144 03-20-2017 11:45 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
