USGT
#6481
#6482
#6483
this works for me
#6485
#6486
#6490
Seems as though Photobucket has done a huge crackdown on everyone. All my pics on the other forums I frequent are taken down as well. Just upload your photos on RCTech. That's what I've started to do.
#6491
Someone else posted this - can't recall who, but there's a simple solution.
- Attach images to your post
- preview your post and open the attachments in new tabs
- copy the URL of your attachment and insert it as an image in your post as you would a Photobucket URL.
I tried it and it worked a treat - R/C Tech Forums - View Single Post - Bittydesign 1/10 TC 190mm bodyshells!
#6492
#6493
hope it's okay if i could ask for further details on the P-Zero specifically on handling characteristics. And if possible, compare the handling characteristics of it to the NSX 2007 of Tamiya?
Not running USGT but some races in Asia for 17.5T blinky have certain body rules (race bodies such as PF, bittydesign, montech aren't allowed) that should be in 1:10 scale and I'm looking for an equal or better alternative to the NSX.
thanks in advance.
thanks in advance.
#6494
I have a question for you USGT guys. I am currently bashing a TT02 and having a ball. 99% of the time I run it at the High School Tennis courts and set up a make shift course using field markers. The tennis court are pretty slick and dusty so traction is not what you would expect but it is pretty smooth. I run two different bodies, the first is the Tamiya Carrera RSR body and for that I am using a staggered wheel set up with the USGT/Ride tires, the second body is the Suzuki SX4 WRC Rally body and on that I am running a square wheel set up with the Ride 26MM Radials. The SX4 feels like it handles a bit better and I wonder it the rear wing is the cause as it feel much less tail happy at speed. What I am curious about is if there would be a drastic difference in handling going with something like the P-Zero, C7, or CTS bodies or some of the GT style tamiya bodies like the NSX or something like that?
P.S. I have played a bit with the set up of shocks, springs, pre-load, and toe to get where I am. I have some full scale racing experience so I do have a basic understanding of set ups.
Thanks.
Cheers,
Jim
Thanks.
Cheers,
Jim
