    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Old 04-04-2012, 03:25 PM   #526
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by Nexus View Post
Hmm do I need to wear the GoPro mounted helmet for the USGT Nats race?
Thats the only way you should race!!!
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-04-2012, 03:29 PM   #527
Body of choice?
350 z looks cool, I assume it works well.
Josh Hohnstein is offline   Reply With Quote
Old 04-04-2012, 03:45 PM   #528
Kevin K's Avatar
Originally Posted by Josh Hohnstein View Post
Body of choice?
NSX or 350Z have been the most popular of late
Yes it does...maybe you can take down the best in USGT....RJ...RICH or Battman!!!
Old 04-04-2012, 04:30 PM   #529
Norman2's Avatar
Hi, The Porsche GT3-RS 200mm body by HPI is also a very good body
for USGT. My Kyosho TF-5S handles very well. Photos Attached.
Norman2
Norman2 is offline   Reply With Quote
Old 04-04-2012, 04:55 PM   #530
Trader Rating: 38 (100%+)
The wheelbase of my tc6.1 doesn't seem to be anywhere close to the HPI body wheel wheel cutouts. How are you guys handling that? They don't seem to work well making my own cutout as the lexan that is left is a different texture.
Does anyone make bodies that might work better besides HPi and Tamiya?
or8ital is offline   Reply With Quote
Old 04-04-2012, 05:19 PM   #531
Kevin K's Avatar
Did you try to change your wheelbase to fit inside the wheel cutouts or are you just going off how your car is setup? There is enough adjustment on most cars to get the wheels to line up with the wheel cut outs. I have never had any issue when mounting an HPI body on my TC5 when I had one and I dont think the TC6 is that far off.....I have seen a few TC6's raced in USGT and they didnt apear to have any wheelbase issues that I could see as far as looking at the body being all cut outside the wheel markings. Im not really sure what you have going on.....
Old 04-04-2012, 05:31 PM   #532
Norman2's Avatar
Hi, I agree with KevinK, Something has to be mounted wrong as the
Associated TC6.1 has a wheelbase of 255mm (10") and all HPI bodies
that I have used have that exact wheelbase. Very strange. Regards
Norman
Old 04-04-2012, 06:00 PM   #533
I'm using the stock wheelbase and wanna match my setup rather than the body. It fits in the wheelwells but the front tire is at the front edge and the back wheel at the very back edge (close enough that it's gonna cause body tuck issues). Certainly not centered on each opening.
My wheelbase is 10.25 inches. It is 1mm to the edge from center front and back which is the kit setting. So the wheelbase on the TC6.1 must be 4mm longer than 10 inches. Though I see the specs list it has 10.04.
Old 04-04-2012, 06:15 PM   #534
this body is 1 or 2mm too far forward but despite that you can see how far to the back edge the rear wheel is.
Old 04-04-2012, 06:23 PM   #535
Kevin K's Avatar
Looking at this picture it looks like the body is mounted like you said too far forward. If you mounted it another 2 mm back like you said it would be much closer...then maybe you could add 1mm to the back side of your rear arm to get it to "look" better. Aside from that it doesnt look to bad wheelbase wise. Trying to match up wheel wells is a PITA...ever try to match a protoform Speed 6 left to right....good luck. If your unwilling to change your setup then there isnt much more you can do but start cutting into your fenders....1mm in wheelbase isnt going to change your setup that much.
Old 04-04-2012, 06:47 PM   #536
Buckaroo's Avatar
Mark your wheel wells AFTER you get the body post holes set. That way you're adjusting the wheel wells to the chassis wheelbase set up, not the other way around. 2mm of wheel base change to your car to get the "look" could very well dork your suspension bias.
Function over form!
Run it like it is, and do differently next time. At speed on the track, no one will see it or even care.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 04-04-2012, 06:48 PM   #537
I have a painted body that is drying where the body is mounted further back. Still seems like it is gonna look a little weird with a huge gap in front of the rear tire. I even, as you said, tried moving the rear wheels forward by a mm (I needed a little more rear traction anyway) but it made little difference. I'll post a picture of the new body when it's dry and cutout tomorrow.
Old 04-04-2012, 06:50 PM   #538
Function over form!
As I said in the original post that doesn't work with the HPI bodies as they use a different texture lexan around the wheels. If you don't cut it all out then it looks really weird. That's why I wondered what other bodies beside hpi and tamiya were out there.
Old 04-04-2012, 06:56 PM   #539
Trader Rating: 36 (100%+)
Body of choice?
Josh is running? Fak move me down another main because the GT class gonna be stacked. Lol
So we have the former USGT Nationals winners, a US Indoor Championship TQ and winner, multiple TCS race winners, and probably others I'm missing.
Awesome for USGT.
Nexus is offline   Reply With Quote
Old 04-04-2012, 07:33 PM   #540
Buckaroo's Avatar
Try some other bodies. The HPI S2000, Celica, McLaren F1, Porsche 911, Subrau Impreza, both models of the Lotus Elise , and the C5 Corvette have all worked for me with no issues.
Tom Keith
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4074 Today 11:06 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 10:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 10:24 PM
