    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree101Likes
Old 01-26-2015, 08:54 AM   #3361
Butler02's Avatar
I also run on a budget and I started with the TC4. It's a decent starter car but it's not really up to date with current design. Because of that I ended up switching to Spec-R. They are very good cars for the money and you can upgrade the S car into the R car over time or just make use of certain upgrade parts. I HIGHLY recommend looking into the S2, or even the R2 if you are able to drop a bit more cash on start up. After building my new R2 I'd say it's a considerable upgrade over my R1
Another car you could look at would be the Sakura XI Sport. Also a very capable and price friendly car.
Lou's Speedway and Hobbies
Spec-R R1 USGT, R2 Stock TC, S1/R1 hybrid "Mod"
Airtronics MT-4
Butler02 is offline   Reply With Quote
Old 01-26-2015, 08:59 AM   #3362
Originally Posted by mooby64 View Post
Take a look at the Spec-R S2, it's $120 at TQRCRACING.COM. Add the Alum. shock bodies ($12) and the soft spring set(spr022-20ki $16) and you have a very capable car. Parts are inexpensive and the car is very upgradable.
I agree with this recomendation. I have the Sukura Ultimate that I run in USVTA. Fit and finish are extremely good, and the car runs up front, but their Front A-arms and steering knuckles are designed poorly and are a definate weak spot.
In addition to any kit you decide on, I would strongly suggest you get 2 of these shim kits, or another set like them:
http://www.tqrcracing.com/shop/produ...w.asp?p_id=534
.... to be able to adjust your role centers, anti-squat and other setup changes that will need to be done to the car to make it competitive.
Rhymenocerous is offline   Reply With Quote
Old 01-26-2015, 09:04 AM   #3363
I have four of the various Spec-R models. I agree, they're the best option on a budget. Much better than the TC4.
In addition to the metal shock bodies, my other must have upgrade is the HD gear diff for the front. You'll need some plastic blades if you switch to the gear diff from the spool.
http://www.tqrcracing.com/shop/produ....asp?p_id=5234
http://www.tqrcracing.com/shop/produ....asp?p_id=7746
http://www.tqrcracing.com/shop/produ....asp?p_id=1669
I also, added the aluminum steering rack and aluminum center pulley, but those are not immediate needs.
One more thing, I found with the short shock towers on the S2, it was a lot easier to get down to 5mm ride height with the correct droop if I used short springs.
These work well:
http://www.tqrcracing.com/shop/produ....asp?p_id=1684
.crispy is offline   Reply With Quote
Old 01-26-2015, 11:36 AM   #3364
Tech Legend
Cain's Avatar
Trader Rating: 232 (100%+)
picked up a couple of XRay T3 2012s used, not cheap mind you, but from what I can tell there is definitely some serious quality there, and with xray doing a once a year version it seems, can get some good deals.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-26-2015, 02:11 PM   #3365
Originally Posted by Gravity Dodger View Post
I'm new to r/c car racing and our local track has a decent sized USGT class that I'd like to participate in so my question is if the 3racing Sakura Zero would be a decent chassis to start with?
I'm trying to stay on a budget and am more concerned about improving my driving skills than reaching the podium. A friend recommended possibly starting with a TC4.
Any thoughts would be appreciated.
Thanks,
Paul
Any chassis can work well when setup properly for USGT. My advice is to visit your local track and see what chassis are supported there. Spare parts availability and others guys with the same car always play a huge factor in your enjoyment. If you buy a car just because it's cheap, and there is no local parts support, you could be caught going home early some race nights. But if the local track and racers have a common chassis, there will always be setup help and spare parts galore. If you have to pay a little bit more than you wanted at first, it may be better in the long run.
My local track supported VBC racing, so I went with a Ghost. The budget version of their high end car.
simple is offline   Reply With Quote
Old 01-26-2015, 06:12 PM   #3366
Gravity Dodger's Avatar
Thanks for the responses, the next race at my local track is Wed. so I'm excited to check it out. The track has a small hobby store so I'll make sure to see what cars they have part support for.
Gravity Dodger is offline   Reply With Quote
Old 01-26-2015, 07:23 PM   #3367
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by NutDriver View Post
I made the comment to MikeR of Exotek about a year ago regarding the resemblance of these wheels with his. IF I RECALL CORRECTLY, he said that they were made in the same molds that his are, but the Exotek wheels are a different plastic.
MikeR, if you are monitoring this thread, please fix any errors I might have made.
Scott
Correct
Special US spec formulation for Exotek contains 100% nylon with no fibers for just right rim flex and increased traction on asphalt or carpet.
Our wheels are a little softer (not too soft) than the Speedmind version.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-27-2015, 04:18 AM   #3368
Originally Posted by MikeR View Post
Correct
Your wheels are the best.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 01-29-2015, 10:37 AM   #3369
I am working on prepping my HB TCX that has been sitting for some USGT action. I found out the guys at my local track usually run between a 3.4-3.6 FDR for the class. My car is currently setup for 17.5 blinky with a FDR around 4.0 so I have a few pinions around the 45-47T (64P) range. In order to use those pinions in USGT, I would have to drop the spur from 96T to somewhere in the 81-85T range. Does anyone run spurs that small? Would there even be enough adjustment range to properly mesh that range of gearing? I know buying bigger pinions is probably easier, I'm just curious if people have tried this in the past.
I'm not an expert, just a truggy enthusiast
kawi650 is offline   Reply With Quote
Old 01-29-2015, 01:44 PM   #3370
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i currently run a 88t in my tcxx.. but i've had as small as a 84 and 86 in the car - that got me down in the lower 3 FDR
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-02-2015, 09:44 AM   #3371
Presently running a TC6.2 at my indoor carpet track med traction...
Im wondering if there are big adjustements needed to race on asphalt...
coolair is offline   Reply With Quote
Old 02-02-2015, 12:12 PM   #3372
tdu verney's Avatar
Default USGT Asphalt
The first one that comes to my mind is ride height. Talk to the guys at the track for set ups and pick one that feels good to you. Outside of ride height and you may wont to fool with that ride height will be higher and suspension will depend on your tracks level of grip? Best to ask...
tdu verney is offline   Reply With Quote
Old 02-02-2015, 04:23 PM   #3373
Probably not as much as you might think. I running TCXXs in USGT and VTA on asphalt with virtually the same setup as the TCXX cars that do very well at the Gate and were in the A Main at Cleveland Indoor Nationals. Most notable exceptions are ride height (I'm at 6 to 6.5mm depending on how rough the track is) and FDR.
John Wallace2 is offline   Reply With Quote
Old 02-03-2015, 09:55 AM   #3374
thanks for the info... will be a whyle till we get to ride outside up here...
-18C/-1F outside today...
Old 02-03-2015, 05:57 PM   #3375
IndyHobbies.com's Avatar
Just finished this HPI Nissan 350Z body for myself. This is the GReddy version: http://www.hpiracing.com/en/part/17218 It comes with a really nice rear spoiler and the standard lexan version too.
Everything is Faskolor except the Novak sticker. Yep, I like orange. I still like the 350Z body most of all for USGT. Looks good on the track and the nose seems to take a beating since its mostly just rounded. Handles well too.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4263 Today 01:17 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
