    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree515Likes
Old 09-26-2014, 09:08 PM   #3151
theproffesor's Avatar
Trader Rating: 57 (100%+)
Well at least 3 if not more of those cars are not any type of production car. And is the Honda HSV 010 a production car? Its def not here in the states. So if this pictoral is to represent the type of cars that should "realisticaly" be in the class, then almost any prototype car thats not an ALMS/wedge (1/12) style body should be accetable. Am I correct?
But I guess there are purist out there that want only production cars. That still leaves the McLaren, the Zonda, Corvette, and other bodies with that kind of shape.
My guess is most of the guys winning races could win with any body. They just happen to be good enough to take advantage of the bodies with a little better areo. My other guess is, the guys that keep asking what the fastest bodies are, are the ones that aren't winning races and arenlooking for exuses as to why.
I am curious though as to why in none of these list, the PF LFA doesnt come up. I ran one for a bit and it handled alot like my mazda 6 GX body. The shapeis also very similar to that of most TC bodies as well. Have people just not tried it out? Only reason I dont run it now is I am going with a theme to my next paint scheme and a lexus just doesnt fit.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-26-2014, 10:14 PM   #3152
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
That would be the correct way to look at it. That is how Rob and myself feel about the bodies.
The PF LFA has some issues its a larger body 200mm not much of a problem but because of its shape it does get alot of rear body tucks. I have seen them raced where the driver taps a corner and the rear fender gets sucked up into the tire and when another driver hits the back of the car it happens too. I personally think the body is ugly and doesnt look "scale" on any car that I have seen it on its just kinda meh. Much like the PF Camaro it needs to be about a half inch lower and it would be a really good body but its too tall and doesnt look good imo being that tall but it does handle just fine its more a looks thing to me.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-27-2014, 05:48 AM   #3153
rcwck's Avatar
Default LFA
I just tested the LFA body on a 36' x 86' Ozite indoor track because others appeared to like it and I like the looks.
I was also running a HPI C6 Vette shell. The LFA is about 1/2 inch taller and a few grams heavier than the Vette also 10mm wider. I had the larger lexan wing installed.
The LFA was really planted with lots more down-force than the Vette. It felt slower and was actually 2-3 tenths slower that the Vette. I also tried the small black plastic wing that comes with the body but the car was too loose with that wing. As mentioned rear body tucks were quite easy also.
I still like the looks and is now reserved for Slip-N-Slide fun.
Crew chief: "It's suppose to work, if not we'll do the complete opposite".
"Team Medicare"
https://www.facebook.com/#!/hobbystopwest
rcwck is offline   Reply With Quote
Old 09-27-2014, 06:12 AM   #3154
IndyRC_Racer's Avatar
Originally Posted by howardcano View Post
I've noticed many guys don't take the time to (or even know that they can!) adjust the wing on the body they use. This is a very important tuning tool, yet some guys put on a body, notice that it makes the car too pushy or loose, then dump it for another body. When I ask if they tried to adjust it, they just give me a quizzical look.
Even a good body can be a turd if it's not adjusted properly.
This is an interesting point. I suggest that a local racer adjust his rear wing as he was struggling with a loose condition. He added a little angle to the wing and it made his car much more stable/predictable.
If you buy the black plastic HPI wings, they come with wedge shaped shims that allow you to adjust the rake/angle of the wing. Of course your can come up with DIY solutions for shimming the rear wing such as a bit of servo tape, scrap lexan, or thin washers.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 09-27-2014, 07:59 AM   #3155
howardcano's Avatar
Trader Rating: 35 (100%+)
Yes, changing the wing angle is one option. Others are trimming the size of the wing, changing the mounting height, and moving the wing forward or aft (which is what I usually do).
When adjusting a new body, I'll leave the wing a bit oversized, and make several mounting hole locations for the wing. I start with the wing in the most forward position, and make chassis adjustments to get the handling dialed for LOW SPEED corners. Then I adjust the wing for high speed corners. If the car pushes at high speed, I trim the wing until it starts to get loose, then stop trimming and move the wing back one position. If the car is loose at high speed, I leave the wing the same size and move the wing back one position and try again. It only takes a few tries to get it right.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 09-27-2014, 08:23 AM   #3156
tdu verney's Avatar
Default USGT
I'm headed to a track that will not allow me to run my Mac Vette. I have three
Choices in my closet and could use some input...
1. Ferrari 458 (love the looks).
2. PF Camaro (Yep its tall)
3. Go buy the Hpi Vette
RBK I'm in doubt and broing out...
tdu verney is offline   Reply With Quote
Old 09-27-2014, 11:40 AM   #3157
Verney I feel your pain. Ran my buddys one off body n got everything from.." hey that body needs to be available to the general public and it has to have 2000+ available".
Now that Mr.Proffesor got his answer on body rules I hope everybody can get in the same mind set as Mr.Robk n Mr.Kevin K & just drill some holes paint a body n shut up n race.
☆smokie p☆
Mr.75MHz is offline   Reply With Quote
Old 09-27-2014, 12:13 PM   #3158
Oh I nver had a questionnon what was and wasnt allowed. Hell right now I'm working on a paint scheme for the HPI 2011 Mustang. I was just trying to clarify what the original poster of the pics was trying to say.
Old 09-27-2014, 08:17 PM   #3159
JimmyMac's Avatar
Do they have a decent class of USGT at Bush River?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-27-2014, 08:35 PM   #3160
scirocco14's Avatar
Yes, absolutely. Usually 8-10 cars show up and they're all FAST.
Mark
scirocco14 is offline   Reply With Quote
Old 09-27-2014, 09:25 PM   #3161
JimmyMac's Avatar
Mark
Sweet, been trying to get down there. Just looking for a good weekend to go since yall race on Sundays.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-04-2014, 10:16 PM   #3162
picco007's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Have a question, just got into USGT. t4 14, Orca VX speed control, blinky, Orca tx 21.5 (brand new). I started with max timing and geared at 46/92. Started out on the track and had to apply brake for a corner and the car would sorta cog (it would stop and i would pull the trigger 2 to 3 times before going again). I tried another sensor wire, that didn't work then I tried a lower timing back down to 10 degrees on the can and no change. If I don't apply brakes its fine but when I do it hesitates but its not consistent. Does anyone have some info about this?
I'm thinking maybe the sensor board is not good?!?
Thanks in advance.
EA Motorsports
picco007 is offline   Reply With Quote
Old 10-04-2014, 11:50 PM   #3163
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Thanks in advance.
You should go to the mfg section and ask Eric of EA Motorsports. He is the most informed person I know on orca products.I run the same setup you are using except I have a VXX. You are suppose to run the timing 2mm past the 20>mark. Do you have the punch setting on max on the ESC?
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 10-05-2014, 07:07 AM   #3164
You might want to try Mac's Jag as it works really well or the HPI BMW in 190 mm. I've been running the BMW and I really like it.
chuck
mackin is offline   Reply With Quote
Old 10-05-2014, 07:59 AM   #3165
picco007's Avatar
Yes I have the punch setting at max and my timing was exactly at the 20 degree mark. I never went past it. I will try that, if not I will see what EA says.
Thanks for the reply
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4462 Today 08:16 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 10:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 10:24 PM
