    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree511Likes
Old 09-25-2014, 06:47 AM   #3136
robk's Avatar
Trader Rating: 22 (100%+)
I absolutely believe in aerodynamics in 1:10 but I do not believe that a successful full scale design involving elements unavailable in 1:10 (like the specifics of the underside of a full size racer) will translate 100%. I think, from my experience, that as long as certain elements are present a body will be good. A decent splitter, a non ginormus cab area and a decent wing are most of the ingredients. How long or short the body is will determine a lot as well.
I have tried a lot of stuff that doesn't work. I had an old Protoform 3 series BMW from the early days of touring car that looked wicked but pushed off the track..too tall no splitter. The HPI Saleen S7 looks awesome but is a limo because it's too long. It can work on really big tracks though. HPI RX7...meh, kinda pushy. Tamiya Skyline...long, kinda pushy, not much front end downforce. Might be too boxy.
The thing is I will take any and all Protoform Corvettes (non-WGT) that you can find, over any prototype or anything else. It's like Mazda 6, it just feels good and works in almost all situations and they are all gone
Old 09-25-2014, 06:51 AM   #3137
robk's Avatar
Originally Posted by .crispy View Post
This.
Words like that should never be found in a rule book.
Thats your opinion
Old 09-25-2014, 08:52 AM   #3138
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I ran the Tamiya Nissan GT-R (sumo power version) and it felt perfect all weekend at the Southern Nationals...plus it was heavy enough that I didn't have to add any weight to my Tamiya Ta05V2 - whereas if I went with my HPI Porsche GT3, I had to add weight
both had scale (ie, kit wings) that were pretty much straight and didn't have all the aerodynamic bends and such that some of the molded HPI wings offer - nor did it have the huge scoop or side dams like the TC-based wings offer
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-25-2014, 11:19 AM   #3139
beemerfan's Avatar
Trader Rating: 34 (100%+)
What is the eBay seller "Team Blue Groove" 190mm Corvette a reproduction of? Maybe Tamiya? I know I've found all kinds of discontinued bodies that they reproduce, only thing is they don't include any mask or decals.
http://www.ebay.com/itm/CORVETTE-C5-...item2333d57758
USVTA Member #155
Associated TC3 Faithful
beemerfan is offline   Reply With Quote
Old 09-25-2014, 11:24 AM   #3140
robk's Avatar
It's probably the Tamiya. The Hpi has no splitter at all if I remember right
Old 09-25-2014, 11:25 AM   #3141
That body appears to be an HPI corvette.
Goals Achieved....Running at the End and Not Dead Last.
mooby64 is offline   Reply With Quote
Old 09-25-2014, 05:12 PM   #3142
tdu verney's Avatar
Then it's a 200 mm....???
tdu verney is offline   Reply With Quote
Old 09-25-2014, 05:28 PM   #3143
DARKSIDE's Avatar
90% of all the bodies work....it all depends on your chassis setup....if the body gives your ride a push, give it more steering ect...it can work...just got to do the work to make it work
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 09-26-2014, 10:04 AM   #3144
Racer X's Avatar
I'm SURE bodies make a difference, which is why I originally asked the question as to what bodies everyone was running now. Back in the day, almost everyone ran a NSX...there was a reason, it was faster. With the NSX gone, I was just wondering if there was a definitive body that everyone was running. Sounds like there isn't (except ALMs bodies seem to be quickly growing) and it seems to make some sense as to why.
Aero is aero...if you don't think that aerodynamics plays a big part in RC cars racing, take off your TC wing and try (and I do mean TRY) to do one lap at speed without spinning out. If you are running a body with a very wide and high windshield, you are pushing more air and it will be slower on a large track (but the higher downforce may make it faster on a small tight track). Underbody areo (ground effects) don't make much of a difference in RC because instead of having several inches between the nose of the car and the ground, and a large distance to the rear of the car, we generally have maybe 1/2 inch (or hopefully less) to the ground and a foot or so to the rear of the car. There just isn't much air getting in there and it doesn't have very far to move to create much of an effect.
In USGT, the motors limit how fast the car can go which makes aero at speed about the same (if a car is going 25mph and another is 10% slower, that's much less noticeable than a car going 45mph and another 10% slower). I'm SURE that there is a difference in lap times depending on the body, but it is most likely measured in the 1/10ths of a second, but it could still be significant (maybe up to 1/2 second a lap) depending on the track type and length, but that isn't easy to see unless its the same driver, same car, same everything except the body and I'm not convinced that it has really been tested. Also, being slightly slower in the straight may be compensated by the increased downforce in the corners (making a car faster on the infield). The trick is finding a body that is low profile enough to be fast in the straights yet still enough downforce to be planted in the corners. The NSX had that combination...sounds like the 350z may also have qualified (low profile but good downforce).
I just don't want to see the class taken over with ALM bodies. I agree, discouraged is a word that should always be discouraged, especially in rules. What it says to me is 'this may be an advantage, but we hope you will choose not to use it'. Rules are supposed to be YES and NO, not maybe. Still, I've noticed that there are more and more people running the ALM bodies in USGT. If they are not better than current USGT bodies, why run them? If bodies don't make any difference in RC racing, try running a TC with a Alpha Romeo body and then a Speed 6 or LRT or any other TC body and tell me you don't notice the change in the car.
Rant over (this didn't start out to be a rant)...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 09-26-2014, 10:37 AM   #3145
robk's Avatar
Yes aero is important but ALMS bodies are not magical. A lot of people seem to think they are for some reason, yet the races I go to I almost never see them in the A main.
Old 09-26-2014, 10:39 AM   #3146
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I am going to be outside of the norm? I am going to run a skyline R34 from HPI this weekend and let everyone know how it goes. I am running a one way in a shaft drive car also. Weight transfer has a lot to do on tight tracks, guess if I can't make it work, it just won't? LOL
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-26-2014, 10:46 AM   #3147
howardcano's Avatar
Trader Rating: 35 (100%+)
I've noticed many guys don't take the time to (or even know that they can!) adjust the wing on the body they use. This is a very important tuning tool, yet some guys put on a body, notice that it makes the car too pushy or loose, then dump it for another body. When I ask if they tried to adjust it, they just give me a quizzical look.
Even a good body can be a turd if it's not adjusted properly.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 09-26-2014, 01:25 PM   #3148
Moderator
Ready to rip!
SMC Racing
Old 09-26-2014, 08:30 PM   #3149
Dobbs's Avatar
Trader Rating: 26 (100%+)
Originally Posted by StephenSobottka View Post
Ready to rip!
That is awesome! Nice job
Dobbs is offline   Reply With Quote
Old 09-26-2014, 08:31 PM   #3150
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
This whole body issue has been talked about ad nauseam. The core issue is perception VS reality. Look at some of the "GT" bodies they are not too far from ALMS bodies people are concerned with. Then look at the results from some of the larger USGT races and see what is "actually" being raced. Dont let your preconceived idea about a body's shape or aero fool you. Racers will always end up with what works....look at the results.
In the end just have fun with the body that you like and works for your driving style.
Originally Posted by Travis S View Post
A lot of different bodies will work fine. Here are the last 2 big races and the bodies used in the A's.
Round 1 of the Triple Crown Scale Nationals in Nashville: (40+ cars)
1. Corvette
2. MRS
3. 350z
4. NSX
5. 350z
6. NSX
7. Mclaren f1
8. ??
9. Mclaren f1
10. Corvette
Round 2 in Fort Wayne (30-40 Cars)
1. NSX
2. Corvette
3. Shaken 408R
4. McLaren F1
5. McLaren F1
6. 350z
7. McLaren F1
8. BMW M3
9. ?
10. Nissan GTR
Ahhh good eye. The GTR-35 looks kind of like the HSV-010.
Some GT300 car pictures
Some GT500 car pictures
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4446 11-15-2017 09:48 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 10:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 10:24 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
daktulos
