    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree194Likes
Old 08-02-2014, 03:45 PM   #2971
Loco4G63T's Avatar
Trader Rating: 23 (100%+)
They don't have a true USGT class so I don't have a choice but I figured the 17.5 action would make me a better driver. I can keep up with some of the 17.5 guys with my VTA car so I'm hoping the 21.5 would be awesome to run against them. Thanks for the FDR advice. I'm gonna shoot for 3.1 to start.
"D" TTRC - RCRNV and Mimi's "The TRACK".
OFF ROAD - B5M CE, TLR22T 2.0, and Mugen MBX7R Eco.
ON ROAD - 13' T4(VTA), 14' T4(MOD), 15' X1(21.5), CRC X10LE (WGT), Tamiya Euro Semi-Truck and Serpent 977e Evo 2.
Driving through hell and back! Phoenix Raceway, Afghanistan 10'-11'.
Loco4G63T is offline   Reply With Quote
Old 08-02-2014, 08:46 PM   #2972
gooba's Avatar
If your a good Clean driver you could probably do decent and run ahead of the "slow guys" but you probably arent going to beat say top 3 -4 drivers
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 08-09-2014, 05:17 PM   #2973
NutDriver's Avatar
Trader Rating: 15 (100%+)
The USGT rules allowing for an almost 14% weight reduction for FWD cars (1250 from 1450) Does/has anyone run one? All I can find so far is a Tamiya TT03 for a FWD car. Just curious.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 08-09-2014, 07:39 PM   #2974
gooba's Avatar
There are a few people Who converted the Sakura d3 drift car to fwd. I don't know how they've done but if you look in their thread theres some info on it
Old 08-09-2014, 09:01 PM   #2975
NutDriver's Avatar
Do they work?
USVTA member #111
Old 08-09-2014, 09:32 PM   #2976
TB03Racer09's Avatar
tamiya, serpent, 3 racing, vbc all have fwd touring cars.
TB03Racer09 is offline   Reply With Quote
Old 08-10-2014, 01:43 AM   #2977
Originally Posted by OttoKrosse View Post
Picked up a Hacker 21.5 and was told that I needed to turn the timing all the way up and then 1 more 'tick' to get top performance from the motor. Well, the little extra 'tick' gave me all the speed I was sorely lacking but now my motor temp was at 185 F when I checked it about 20-30 seconds after the end of the heat race.
Track temps were around 110-120f, air temps were about 105f, so the motors were starting out already warm. I do run a fan on the motor as well
1: What temp would be considered too hot?
2. Running a 5.5 fdr for our class, and I'm running a 113t spur and a 40t pinion (5.65 fdr). Would dropping down a tooth on the pinion be advised to reduce the temps, or are the 185 degree temps within a safe parameter?
Thanks in advance for your input.
Did anyone help you? That would be on the high side of what I would let my motors go (with a fan). Experts don't agree on the max temp for motors. Some say in the 160 -170 range others in the 170 to 180 range. but probably all would agree that 185 is pushing it. Motor timing gives you more RPM & AMP Draw and more AMP draw gives you heat. Is there any way to check the amp draw at the timing you have set in the motor (or just check the ESC temp and or check to see how much battery you consume during and calculate the amp draw)? If ESC wasn't hot too, do you have to run that FDR for your class? These brushless motors don't like to over rev, so if the ESC wasn't hot, I'd add gear and check the temps FREQUENTLY. If the motor temps don't drop, take the motor apart and see if there is anything inside that is binding (grit, bad bearing, etc.). Lowest FDR I've heard of in USGT is 4.25 with the high revving R1 motor on a small track, everything else seems to be in the 3.0 to 4.0 range. 5.5 FDR is really low. At least that's my experience. Hope that helps
John Wallace2 is offline   Reply With Quote
Old 08-10-2014, 03:10 PM   #2978
vivo quevas's Avatar
Trader Rating: 18 (100%+)
My mcAllister Jaguar USGT 417V5 Smokem conversion . I'm selling this car just built a Tamiya EVO6 to replace my reliable 417. If you are interested pm me.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 08-11-2014, 07:09 AM   #2979
JCarr's Avatar
Out of curiosity, why were truck bodies not allowed? Not trying to stir the pot, i'm just wondering why, since they would hold no advantage over any other body.(that could see anyway)
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 08-11-2014, 07:30 AM   #2980
Trader Rating: 25 (96%+)
nobody at my local club had any problems when I raced this body a while back:
billdelong is offline   Reply With Quote
Old 08-11-2014, 08:44 AM   #2981
Don't go there... because the the only possible answer pertains to appearances and if appearances matter, then why allow racing prototypes...?
.crispy is offline   Reply With Quote
Old 08-11-2014, 08:46 AM   #2982
howardcano's Avatar
Trader Rating: 35 (100%+)
We run a local Nastruck class using bodies like these, and it's both fun and popular. The rules are the same as for USGT except for the bodies and tires. We use HPI Vintage Slicks with Vintage stock car wheels. The tires have very little traction, but last the whole season.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 08-11-2014, 11:56 AM   #2983
IndyHobbies.com's Avatar
I like the truck bodies too. I'm fine that they aren't legal for USGT, but I wish there was an on-road class where we could use them. Maybe an open sportsman class like they used to run in Indianapolis during the RCAR days.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 08-11-2014, 12:52 PM   #2984
J-milz's Avatar
Trader Rating: 37 (100%+)
I bet if you were to dominate week after week, you'd hear it! Lol
Ps. Nice body!
💫XRAY addict💫 sponsored by the secret stash.....tee-hee-hee.
J-milz is offline   Reply With Quote
Old 08-11-2014, 01:44 PM   #2985
robk's Avatar
Trader Rating: 22 (100%+)
No matter what type of racing it is, people try to run trucks. This drives me insane, since there are no trucks raced in any gt or prototype road racing events (nascar notwithstanding). Trucks at Lemans...?
((counting down the seconds until someone produces pictures of trucks at some full size event)(I will not be swayed!!!!!))
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4283 07-18-2017 10:02 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
Currently Active Users Viewing This Thread: 9 (2 members and 7 guests)
Kevin K, mariob62
