    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree90Likes
Old 07-30-2014, 01:01 PM   #2956
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by k_bojar View Post
yeah... just looked at them.. different chassis and suspension setup
guess I probably should have said for the v2 with the in-board suspension
Most everyone I have seen runs the normal type shocks on the TA05. (Well at least the fast guys that I have seen run this car.) So unless you are running an IFS body, it will be easier/better in the long run for setup and for people to help you with the car with standard shock layout.
Travis S is offline   Reply With Quote
Old 07-30-2014, 01:04 PM   #2957
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I understand what you're saying, but not what I wanted to hear
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-30-2014, 02:48 PM   #2958
stro3579's Avatar
Trader Rating: 20 (100%+)
Im thinking of running USGT this year. How do I get the tires to fit flush on a 200mm body? What wheel and offset do I need.
stro3579 is offline   Reply With Quote
Old 07-30-2014, 03:02 PM   #2959
The offset you are looking for is 3mm to 6mm, depending on the chassis and body you want to run. Tamiya 24mm rims w/2mm offset may be your best bet, handling wise. HPI makes 26mm rims with more offset, but the Ride Spec tires do not work/handle as well when mounted on 26mm rims.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 07-30-2014, 03:47 PM   #2960
NutDriver's Avatar
Trader Rating: 14 (100%+)
@Stro3579,
What chassis are you running? There are some tricks specific to particular chassis that we might be able to share.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 07-30-2014, 03:51 PM   #2961
Travis S's Avatar
The IFS is cool, but just not easy to adjust or get a setup for... If you are not great at car setup yourself (I am not) then just spend that $15-20 on the blue crack parts for a front shock tower.
Old 07-30-2014, 07:41 PM   #2962
robk's Avatar
Trader Rating: 22 (100%+)
Travis simply went for the Russian IFS upgrade. It is expensive, but effective.
Old 07-30-2014, 08:11 PM   #2963
theproffesor's Avatar
Trader Rating: 55 (100%+)
Ok im not knocking anyone with this statement, but what is the obsession with having the tires fit flush to the body. I tried it with my LFA body and found the handling horrible push on the front and loose on the rear. I couldnt get enough mechanical roll due to the track width being so wide. Went back to a narrower set - up and instantly found traction. It didnt look that different from the wide to narrow set-up. Especcially on the track, appearance wise you really couldnt tell at all.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 07-31-2014, 04:00 AM   #2964
howardcano's Avatar
Trader Rating: 35 (100%+)
I like to leave the car narrow with a 200mm body, to protect the front tires. It keeps the car from rolling over when I cut a corner too close. If the tire sticks out beyond the body when turning, it can "ride up" on a flapper, and the car goes full turtle. The wide body reduces the chances of this happening.
I don't leave the car narrow because I'm lazy (although I am, indeed, lazy); on my old XRay T1 chassis, I can adjust the width to anything I want with just the twist of a wrench. That's a great feature.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 07-31-2014, 05:45 AM   #2965
stro3579's Avatar
Originally Posted by NutDriver View Post
@Stro3579,
Yokomo bd7 2014
Old 07-31-2014, 05:48 AM   #2966
stro3579's Avatar
So don't run anything wider then a 2mm offset on a 24mm wheel? Correct?
Old 07-31-2014, 07:13 AM   #2967
NutDriver's Avatar
Stro,
I have a TC4, so I can't help you with widening a Yokomo. With the Protoform Camaro being 197mm wide, you would only be 1.5mm short per side with 2mm offset wheels. I'll have to defer to others on handling changes with changing the track/width.
USVTA member #111
Old 07-31-2014, 07:37 AM   #2968
Correct.
Old 08-02-2014, 01:32 PM   #2969
Loco4G63T's Avatar
Trader Rating: 23 (100%+)
I gotta question regarding FDR. My VTA car is running 3.3 and dialed for the track I run. I'm getting into USGT and was wondering if I should maintain a FDR of 3.3 or should I try 3.2/ 3.4? I'm running against RCGT cars with 17.5 VS. my 21.5 as final consideration. I'm basically just shooting for a start up FDR and will adjust for heat afterwards. The track is roughly 100x70. Thanks in advance 8 )
"D" TTRC - RCRNV and Mimi's "The TRACK".
OFF ROAD - B5M CE, TLR22T 2.0, and Mugen MBX7R Eco.
ON ROAD - 13' T4(VTA), 14' T4(MOD), 15' X1(21.5), CRC X10LE (WGT), Tamiya Euro Semi-Truck and Serpent 977e Evo 2.
Driving through hell and back! Phoenix Raceway, Afghanistan 10'-11'.
Loco4G63T is offline   Reply With Quote
Old 08-02-2014, 01:56 PM   #2970
gooba's Avatar
Personally I'd go out for practice and run as is and see if you can stay closeish to some of your competition then adjust down to 3.2 or maybe 3.0 Sadly with the difference in motor your never going to keep up down a straightaway no matter what your gearing if your track is tight and technical you may be able to keep decent pace but if your track is flowy your going to get left behind pretty quickly.
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4259 05-15-2017 05:20 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
