    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree90Likes
Old 06-13-2014, 09:13 AM   #2791
Jorge T's Avatar
The problem is not front to rear tire wear difference, but left to right wear. We have a double sweeper layout and the left side tires wear more than the right.
RSD MS
Jorge T is offline   Reply With Quote
Old 06-13-2014, 09:48 AM   #2792
moparSRT's Avatar
my fronts wear out faster then rear, also at most tracks one side will wear faster then the other ... always more left or right turns on a track depending on layout and direction.
At $15 a set not worried about rotating them to extend the life by a little, also rotating changes the way they handle untill they wear in again.
moparSRT is offline   Reply With Quote
Old 06-13-2014, 11:02 AM   #2793
I have run these tires and swapped them all around and I can't tell a difference.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 06-13-2014, 11:32 AM   #2794
howardcano's Avatar
Trader Rating: 35 (100%+)
Same here, indoor on CRC carpet, outdoor on asphalt, I find no perceptible change in handling depending on tread direction. The balance remains the same even if I only swap one end side to side.
And I finally had a set give up on grip... they were from last year! Mostly run on carpet, three days on asphalt. They still had plenty of rubber left, so I gave them to a newbie to run in our Breakout class, with instructions to run the worst pair on the front for stability.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 06-13-2014, 12:05 PM   #2795
Jorge T's Avatar
I don't worry rotating for the same reason. But when I tried swapping thread direction, lap times told the difference.
RSD MS
Old 06-13-2014, 02:37 PM   #2796
Lap times?? What are lap times? I'm more worried about being a rolling roadblock than lap times.
Old 06-13-2014, 03:59 PM   #2797
Rodarbal's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to Rodarbal
LOL... Lap times are overrated. All they do is remind me of how inconsistent I am.
RJ Labrador
On Road: Tamiya & XRay
Off Road: Losi, Mugen & XRay
Rodarbal is offline   Reply With Quote
Old 06-13-2014, 04:21 PM   #2798
+1
Old 06-14-2014, 07:46 PM   #2799
If RJ is inconsistent, then I'll have to go back and race with the novice racers.
John Wallace2 is offline   Reply With Quote
Old 06-15-2014, 04:37 AM   #2800
At The Gate we have been running 15 minute mains in preparation for the Tuning Haus Party race in two weeks. 15 minutes with two pit stops makes it real interesting. No problem with run time or motor temps. If you guys want to try something different give it a shot. We do this in USGT, VTA and F1.
mackin is offline   Reply With Quote
Old 06-15-2014, 07:53 AM   #2801
Trader Rating: 25 (96%+)
I'm not a fan of the pit stops, if I wanted to do that then I'd run nitro
Here's a better idea, how about you have each driver jog one lap around the track, and make THAT your pit stop!
billdelong is offline   Reply With Quote
Old 06-15-2014, 11:40 AM   #2802
Have you ever noticed the condition of a lot of racers. A jog around a track may kill someone
Old 06-15-2014, 01:05 PM   #2803
kinda sad really, regardless my vote is to leave pit stops for nitro unless we run a 30 min main and have to swap out a battery pack... but pushing a button and waiting for a light to turn green is plain silly to me, I get about the same amount of excitement as waiting at a stop light when driving home from the track... woo hoo...
Old 06-15-2014, 01:18 PM   #2804
joelwhite's Avatar
Trader Rating: 55 (100%+)
With 21.5 and 7200mah packs. It would prolly havta be more like an hour main.
HEART OF A HUSTLER RACING TEAM
Trick Graphics--see spdrac430 on this forum for all your painting needs
Team Pit Racers-Fastest Guys In The Pits!
joelwhite is offline   Reply With Quote
Old 06-15-2014, 01:43 PM   #2805
Having pit stops plays more into stategy of the race, and not who has the best or fastest car. I have been to UF1 races, and planning "when" to pit has a lot to do with the outcome of the race. With the longer race format, you can overcome mistakes, made early in a run.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4259 05-15-2017 05:20 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
