    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree391Likes
Old 05-28-2014, 09:50 AM   #2701
locked's Avatar
Originally Posted by DBM View Post
Howdy USGT folks. The USGT class isn't supported in my local region (our club is small so we don't want to have too many classes with only a few cars in each, so we only run VTA and 17.5 blinky touring). I do like the USGT rules though, so my friends and I who parkinglot bash after work on fridays roughly set up our cars around usgt rules.
We aren't implimenenting the spec ride tires, but do use treaded tires in any size. We run on a dusty unprepped asphalt parking lot. What tires have you guys found to work best in these conditions?
Very little will work in unprepped dusty conditions. Rally block or a soft pin type of tire would likely provide the most grip in those conditions. No slick tire will work well. Within a few feet, a layer of dust will coat the tire and remove most of the grip. The grit getting kicked up will also chew up your belts rather quickly.
Rather than trying to find a tire that will work in crappy conditions, I would suggest fixing the crappy conditions instead. Bring a leaf blower and clean the surface off. Buy a couple 2 liters of coke and cut a small slot in the cap, shake it a little and spray yourself a nice and sticky driving line on the parking lot. You'll enjoy it way more if you have some grip and don't have to worry about crap getting into your drivetrain and ruining your cars.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 05-28-2014, 10:22 AM   #2702
For our Hobbytown parking lot series, that's what we do. Blow off the asphalt best we can. Then 99 cent 2-liter grape pop. No need for Coke!
I use 48 pitch gears in my asphalt car which is a $120 Spec-R by the way, don't have to worry about that fiberglass chassis that way.
The best tires are the most worn out tires you have. After about three runs on asphalt, they're good to go until worn out.
.crispy is offline   Reply With Quote
Old 05-28-2014, 01:55 PM   #2703
DBM
The lot that we use belongs to a automotive service shop. I don't think the owner would appreciate having a sticky lot that he would have to walk through/drive customers cars through. We will likely just have to run on it as-is.
I did find the lot to be hard on the belts/pulleys in my spec-r s1, but the lot is much cleaner now since we've run on it a few times. Plus I bought shaft drive tc4 for bashing duties and made the s1 into a vta car.
Thanks for the suggestions thus far. I'll order up a few more sets of treaded tires to see if I can find something that works ok.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 05-28-2014, 02:03 PM   #2704
Trader Rating: 25 (96%+)
our local track uses the parking lot in front of a liquor store that is closed on Sundays (per state law).
They first blow the area with a gas powered leaf blower to get all the small chunks of asphalt/debris out of the way. Then they lay the track boards and finish off by using a garden sprayer with a mixture of 1 pound of sugar per 1 liter of soda.
Yes, it's a little sticky, but not to the point where your feet stick to the ground, nor have we seen any ant problem either. The tackiness of the solution tends to wear off over night and is completely washed away during a rain storm.
billdelong is offline   Reply With Quote
Old 05-28-2014, 06:45 PM   #2705
gooba's Avatar
Last time we raced outdoors in a parking lot we blew it off with a leaf blower and sprayed it down with dollar store grape soda(faygo for u ICP fans) let it sit in the sun for an hour and good to go. Once we were done for the day grabbed the hose and sprayed the area down. Never had any complaints about it still bring sticky. For tires ive really started to like the tires off associateds apex. They have a cool looking tread pattern and hook and wear surprisingly well.
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 05-28-2014, 07:06 PM   #2706
gooba's Avatar
Have to show off my new body too. 190mm HPI Viper GTSR. Paint is pactra Florescent orange and green.
Old 05-29-2014, 06:52 AM   #2707
JCarr's Avatar
That looks good GOOBA. I have always liked that Viper body, but haven't run it in fear it would make the car push horribly. lol
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 05-29-2014, 07:05 AM   #2708
gooba's Avatar
Ive ran a viper as a bash body for a long time and didnt notice any ill effects. I am thinking it will be similar in handling to a corvette.
Old 05-29-2014, 09:51 AM   #2709
NutDriver's Avatar
Trader Rating: 15 (100%+)
Part # for 190mm HPI body?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 05-29-2014, 10:41 AM   #2710
Click for part #
Old 05-29-2014, 01:07 PM   #2711
klaymon's Avatar
Trader Rating: 71 (100%+)
Originally Posted by .crispy View Post
It took you longer and more effort to be a smart mouth than to just put the item number down.
klaymon is offline   Reply With Quote
Old 05-29-2014, 01:52 PM   #2712
I think that's the point of MY reply...
Old 05-29-2014, 01:58 PM   #2713
1gdsmracer's Avatar
Trader Rating: 96 (100%+)
Remember this is a forum that is intended for helping people, you keep up the smart ass reply's people are just going to stop coming here for advice and this site will go down the shitter.
1gdsmracer is offline   Reply With Quote
Old 05-29-2014, 02:02 PM   #2714
howardcano's Avatar
Trader Rating: 35 (100%+)
Tower shows #7373 for 190mm Viper, #7419 for 200mm Viper.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 05-29-2014, 02:59 PM   #2715
NutDriver's Avatar
Being the one who asked the question, I wasn't offended. I'm a smart@$$ myself. Thank you for sharing the link. I have a 7419 Viper. Thanks for the 7373 part # so I can run it in narrow config for my USGT car.
USVTA member #111
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4324 Yesterday 04:44 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
