    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree2Likes
Old 05-19-2014, 06:35 PM   #2686
Trader Rating: 22 (100%+)
Originally Posted by billdelong View Post
I'm running 3.23 on a large outdoor asphalt track with medium grip
Thank you~
JoeyE is offline   Reply With Quote
Old 05-19-2014, 07:32 PM   #2687
moparSRT's Avatar
Originally Posted by JoeyE View Post
What is the final drive for 21.5 motors? Or somewhere i can start with and temp it from there. Thanks~
start somewhere between 3.5-4 fdr depending on track size, check ur temps every couple laps and gear from there.
moparSRT is offline   Reply With Quote
Old 05-19-2014, 08:19 PM   #2688
NutDriver's Avatar
Trader Rating: 14 (100%+)
Mopar,
I keep reading people talking about 150F being the limit on motor temps. Can you tell me why?
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 05-19-2014, 08:48 PM   #2689
moparSRT's Avatar
Originally Posted by NutDriver View Post
Mopar,
Scott
150?? no clue, I run mine 21.5 at 160-170 no problems.
Old 05-19-2014, 08:52 PM   #2690
scirocco14's Avatar
Mopar,
Scott
NOVAK actually puts the maximum temp at 175F
Brushless Motor Gearing & Over-Heating Notice
Novak motors have been designed to handle the rigors of the various forms of electric racing. Through multiple forms of testing, customer reports, and inspection of damaged motors, we have determined the the maximum external safe operating temperature for Novak brushless motors is 175 degrees F (80 degrees C). Motors that have been run at higher temperatures have most likely already sustained internal damage.
This internal damage can render the motor inoperable if you continue to run it and will ultimately result in burned or melted coils inside the motor and can in turn result in speed control failure. This type of damage to the motor is not covered under the Novak product warranty.
From our testing and experience, keeping the external operating temperature under 160 degrees F (72 degrees C) will provide the best performance when the car is handling well. At this temperature, the racing life of the motors will be quite a long time and should require only occasional replacement of the bearings and rotors.
Precaution about Advanced Timing:
Use of Novak brushless motors with ESCs that have advance motor timing can reult in excessive current draw, which will rapidly increase the motor temperature above the safe operating limit. As most of these racing ESCs do not have a thermal overload protection for motors, continued operation will result in internal damage to the brushless motor. This type of damage is not covered under the product's warranty.
Precaution about Over-Gearing:
Motor temperature is the ONLY way to properly set the vehicle's gearing. Over-gearing the motor will result in excessive operating temperatures, which may result in internal damage. This type of damage is not covered under the product's warranty.
Results of Overheating a Brushless Motor:
All Novak Brushless Motors are hound-wound, and are assembled and tested at the Novak facility in Irvine, California. Each motor (yes, 100%) is meticulously inspected and tested for internal shorts, and is run extensively before final packaging.
Please follow these important operating temperature guidelines. Thank you.
Mark
scirocco14 is offline   Reply With Quote
Old 05-19-2014, 10:20 PM   #2691
DARKSIDE's Avatar
hi
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 05-19-2014, 11:44 PM   #2692
Awsome, thanks~
Old 05-20-2014, 04:20 AM   #2693
Hey Myron!
mackin is offline   Reply With Quote
Old 05-20-2014, 08:20 AM   #2694
NutDriver's Avatar
Awesome! Thanks, Mark! If I read my manuals, I might know, huh? I'll have to call Novak about their "hound wound" motors. Do you think they use Bassett Hounds?
Scott
USVTA member #111
Old 05-26-2014, 01:02 PM   #2695
JCarr's Avatar
Just wanted to show my latest entry in the USGT world. It's hard to see, but it is a flipflop paint.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 05-26-2014, 10:02 PM   #2696
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to AudioStylz
Looks good!
Mike Zadler
Associated TC3 VTA & TC6 USGT
Tamiya M-05
AudioStylz is offline   Reply With Quote
Old 05-26-2014, 10:16 PM   #2697
snoopyrc's Avatar
Really is a gorgeous shell. Your paint but also just the shape of it. Is that the Tamiya? I think maybe they are the only ones right now that will pay for the extravagant license. I love painting pretty shells, but I find that if I do an exceptional job and it looks really good then I don't have the heart to race it. On the other hand if I botch it in some way then I'm all too glad to beat the hell out of it as quickly as I can.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 05-27-2014, 06:39 AM   #2698
JCarr's Avatar
Thanks guys, I am pretty happy with the way it turned out. Yes, it is a Tamiya shell. I like their stuff not only because it is a very good looking body, but also because they are 190 and I don't have to run crazy offset wheels or spacers to make them look right. I can't wait to run it this weekend and see how it compares to my R8 that was running. The wing struts are from the HPI wing kit and the wing is from a speed6. I had a couple of those wings laying around so, I cut them down to legal height and used that since the body doesn't come with one. I have one wing with the slots cut out and one that I left solid, I hope now I can tell a difference between the two.
Gorilla Size Racing
Old 05-28-2014, 10:05 AM   #2699
DBM
Howdy USGT folks. The USGT class isn't supported in my local region (our club is small so we don't want to have too many classes with only a few cars in each, so we only run VTA and 17.5 blinky touring). I do like the USGT rules though, so my friends and I who parkinglot bash after work on fridays roughly set up our cars around usgt rules.
We aren't implimenenting the spec ride tires, but do use treaded tires in any size. We run on a dusty unprepped asphalt parking lot. What tires have you guys found to work best in these conditions?
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 05-28-2014, 10:32 AM   #2700
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
probably the HPI x-pattern ones will work best. I know I've used them on parking lot racing (blown off, but not 'prepared') and had good luck with them. the pro-compound ones will give the best grip but will wear out -- the D compound ones have a little less grip and better wear life.
that being said, I've had better luck running the D's then the pro's
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4101 Yesterday 12:59 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 10:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 10:24 PM
