    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree391Likes
Old 04-07-2014, 03:12 PM   #2416
The One They Call Dirty's Avatar
Trader Rating: 57 (100%+)
Originally Posted by snoopyrc View Post
I am not sure that I understand you here. Are the body post too short? Are you trying to set it so low that you have to shave all the ground effects off the bottom?
I'll take a picture tonight to show you what I'm talking about
92zero Designs -Diggity Designs
Fantom Racing - Lunsford
MIP - Windy City RC
The One They Call Dirty is offline   Reply With Quote
Old 04-07-2014, 04:16 PM   #2417
snoopyrc's Avatar
It looks like it would make a great shell for USGT.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 04-07-2014, 05:57 PM   #2418
Default ZL1 Fitment
Ok, so here's a few pictures to somewhat give you an idea of what I'm talking about. There are two side skirt cut lines, the lower is highlighted with red sharpie, and the upper is highlighted with black sharpie (hard to see). I know the side skirt cut line will be the black, but that's not my issue. The issue is the front splitter, how low it is. As you can see from the masking tape line, in order to have ground clearance the splitter would have to be cut off, and that defeats the entire purpose of the front end. Bare with me please, I'm just trying to not only figure this out for myself, but for others that may have questions as well.
MIP - Windy City RC
Old 04-07-2014, 06:02 PM   #2419
gooba's Avatar
Why not just get longer body posts for the front? I had to do that for my tc4. I got mine from my LHS but they were HPI
gooba is offline   Reply With Quote
Old 04-07-2014, 06:07 PM   #2420
I get what your saying, I do. But raising the body another hole is not only going to affect performance, but it's going to look goofy as well. It'll have the same size fenders and quarters as my short course.
MIP - Windy City RC
Old 04-07-2014, 06:46 PM   #2421
hotrodchevy14's Avatar
Trader Rating: 106 (100%+)
Any chance you'd have a part number? I'd like to put one on my tc3. Thanks
...oh our lady of blessed acceleration, don't fail me now..
sponsored by:Team lint in my pockets racing...
hotrodchevy14 is offline   Reply With Quote
Old 04-07-2014, 07:01 PM   #2422
For the Durango?
MIP - Windy City RC
Old 04-07-2014, 07:08 PM   #2423
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
If it was mine I would line up top of fender wells with adequate clearance , cut body along ur black line,then remove wheels and set car on flat surface and draw another line around the body with sharpie on its site to get ur proper ground clearance . If that looses the splitter so be it I agree low profile should over come the missing splitter
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 04-07-2014, 07:12 PM   #2424
incase u dont understand my discription
im doing exactly that to my bodies
Justin & Matt Lyons
a800s sanwa m12s
Old 04-07-2014, 07:22 PM   #2425
I do the same thing. Losing the splitter would be a double whammy, I'd lose a lot of steering, and it's going to weaken up that front end of the body a lot. Its going to be a spray bomb, so I'm thinking about cutting the body before I paint...
MIP - Windy City RC
Old 04-07-2014, 07:49 PM   #2426
mikel33's Avatar
Trader Rating: 2 (75%+)
The body sits up fairly high. you're going to need longer body posts.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 04-07-2014, 07:55 PM   #2427
snoopyrc's Avatar
Personally I would cut it on the molded line. If it rubs, I would trim it a little more. It should work. It was designed to work with a chassis of those dimensions and it should work.
Old 04-07-2014, 07:56 PM   #2428
theproffesor's Avatar
Trader Rating: 56 (100%+)
Dont cut before paint. Paint it, mount it, then trim as neccessary. It also looks like your ride hight might be a little low? That would have a big difference on mounting. If you get longer front post, you should be able to mount with the wheel wells not being to high. No matter the maker of the car, the shock towers being to high is usually the only thing that gets in the way of mounting bodies. But thats when too low, not too high. And did I see a 17.5 in the pic???
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 04-07-2014, 07:59 PM   #2429
Before painting the body....cut the body on the trim lines, take the wheels off the car, set the chassis on a flat surface, put the body on the car and measure how much longer the body mounts need to be.
If the body is too low, it will drag while cornering.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 04-07-2014, 08:04 PM   #2430
Travis S's Avatar
Trader Rating: 46 (100%+)
Just use some longer screws and some spacers under the body posts in the front to jack that sucker up.
Travis S is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4324 Yesterday 04:44 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
