    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree31Likes
Old 02-24-2014, 07:50 AM   #2191
Tommy R's Avatar
Trader Rating: 19 (100%+)
On my T4, yes, I have enough threads. I think a standard hex thickness is 4 or 5mm, depending on the car?
Tommy R is offline   Reply With Quote
Old 02-24-2014, 07:51 AM   #2192
Trader Rating: 84 (100%+)
Cool thanks! I'll give the 7mm hexes a try.
mike_d is offline   Reply With Quote
Old 02-24-2014, 09:14 AM   #2193
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Any comments or input regarding the Hobbywing Xerun 21.5 motor? I'm getting into the class and looking at all the options. Will need something that has good speed on large, flowing track.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 02-24-2014, 09:26 AM   #2194
Butler02's Avatar
Ya on my spec r 4mm is standard and 6 mm is the biggest I can go with the wheels and wheel nuts I have. I run out of thread after 6. I'd prefer to use 3mm offset wheels on my 4mm hexes but I can't find any good 24mm rims with that offset.
Lou's Speedway and Hobbies
Spec-R R1 USGT, R2 Stock TC, S1/R1 hybrid "Mod"
Airtronics MT-4
Butler02 is offline   Reply With Quote
Old 02-24-2014, 10:25 AM   #2195
nrtv20's Avatar
For the Spec-R you can change your suspension inserts to move the width as well if you want more to go even wider.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 02-24-2014, 11:36 AM   #2196
Butler02's Avatar
Yep. I did that on the rear of mine. The fronts filled out my body ok but he rear still seemed too narrow. I added another couple mm to the track width and it's good now. That's a pretty handy tuning option. The r1 suspension holders are on my list of upgrade for my s1.
Airtronics MT-4
Old 02-24-2014, 11:54 AM   #2197
theproffesor's Avatar
Trader Rating: 55 (100%+)
I am curious to know if you guys that are trying to widen your car to fit 200m bodies realize that it completly changes the way the car handles? Also changing track width from the rim has different handling characteristics than changing it at the hinge pin holder. If your taking this into account when you work your suspension, thats great. If not, it would probably be a good idea to look into what widening a car does. Wider is not always better.
I only say this because of all the post of "I want to fill up my wheel wells". It seems that there is no regard for what widening actually does. But I could be wrong. Hope this does not offend anyone.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is online now   Reply With Quote
Old 02-24-2014, 11:58 AM   #2198
moparSRT's Avatar
+1
Widening wll reduce traction.
moparSRT is offline   Reply With Quote
Old 02-24-2014, 12:23 PM   #2199
NutDriver's Avatar
Trader Rating: 14 (100%+)
I run a TC4 in VTA with the standard wheels (26mm, 0 offset fronts with 31mm, 6mm offset rears). I have a TC4 that I plan to run in USGT. I have Tamiya 2mm offset 24mm wheels with 3mm offset hexes for the USGT car (as I want to "fill up the wheel wells") for the 200mm body. While the looks aren't completely unimportant to me, I would prefer to not look like an idiot on course (at least not a bigger idiot than I already am). Suggestions? Should I go with 0mm offset 24mm wheels and 190mm bodies?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 02-24-2014, 12:41 PM   #2200
moparSRT's Avatar
On carpet my vta with wide hexes was great, on asphalt it sucked.
Have not run usgt on asphalt yet so no clue what works, have a race at Kissimmee mid March so will have time to test
Old 02-24-2014, 01:33 PM   #2201
There is nothing wrong with running a wider car, just be aware of how it will affect handling. Generally as track width increases, traction decreases for a given set-up. But you can use track width along with other changes to get the desired effect. Since you are running narrower wheels/tire similar to TC I would stick with 190 bodies if you could. But if you can only find the body you want in 200 get it and limit the amount you widen the car to fill the wheel wells. Or just fill them wheel wells on up, and tune the suspension around the wider car, just keep the same width with every set of wheels you buy.
Old 02-24-2014, 01:45 PM   #2202
Tommy R's Avatar
Can't speak for anyone but myself, but yes, I'm certainly aware of the handling characteristics of track widening, either from wider hexes or relocated hinge pins. I will fill the wheel wells reasonably well and then tune the car from there.
For me, USGT is about scale appearance and without it, this class holds zero appeal to me. It's all about the aesthetics first and foremost or I'd run only touring cars. Running super narrow offset wheels that tuck far into the body absolutely kills the look for me. For that reason alone I'll never run a 200mm body in USGT.
Thankfully, our club runs USGT rules, but with allows any treaded tire so we're not limited to such a lackluster wheel/offset selection.
Old 02-24-2014, 02:44 PM   #2203
Travis S's Avatar
Trader Rating: 46 (100%+)
Just wanted to post something about the 10mm lexan rear wing rule.
The wing some of us were using this past weekend that was in question of being legal. It is the TCS legal Tamiya optional wing. A lot of people run the Tamiya bodies they use in the TCS races. I had Rob King check the height for me after the race to see it it was under 10mm and it was. It mounts at a bit of an angle so it looks much taller then it is. Tamiya optional wing = legal. It is known.
Travis S is offline   Reply With Quote
Old 02-24-2014, 03:36 PM   #2204
Tommy R's Avatar
Travis, can you elaborate a bit on this wing? I just picked up my first Tamiya body (Subaru BRZ R&D) and it includes only a rather ordinary wing. Not familiar with the optional wing.
Thanks!
Tommy
Old 02-24-2014, 03:42 PM   #2205
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
When Rob and I set up the rules this was the wing that we used and thats where the 10mm rule comes from.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4230 04-19-2017 09:37 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
