Like Tree6280Likes
USGT
    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech ForumsThread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Old 01-02-2014, 07:36 PM
  #2056
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Kevin Marcy
Interesting. How will they meet this part of the rule?
8.5.2.1.1 Product availability is required to no less than three retail outlets prior to publication on approval list.
As far as I know, they only sell through Hobbyking's web page, not through retail outlets.
Integy I believe is carrying their product, and I would expect they have others as well
robk is offline
Old 01-03-2014, 05:24 AM
  #2057
nrtv20's Avatar
21.5 - Turnigy Trackstar - 9192000034
Is this different from the silver can version they used to sell? I've not seen a red one yet.
Will the silver can version be legal? I hope so; I have 3 of them =)
nrtv20 is offline
Old 01-03-2014, 06:23 AM
  #2058
rcwck's Avatar
Come to Klunk's Korner to see the red can version. I believe red has replaced silver for no apparent reason. I assume that the latest (red can) was submitted and technically silver would not be included as it is an earlier version but maybe not. HK's have only been banned in the UF1 series as far as I know for H.S.W.R. You'll be just fine in Northwood with any color can when/if you race. I know you got diapers to change. Lol
rcwck is offline
Old 01-03-2014, 07:13 AM
  #2059
nrtv20's Avatar
Planning for this Sunday! USGT and F1; as much fun as you guys are having in 17.5 I might have to get another car set up!
nrtv20 is offline
Old 01-03-2014, 10:16 AM
  #2060
tc3 racer sc's Avatar
Default here my camero with the new spec tires
my usgt car hotbodies tc with with a exotek chassia 21.5 thunder power motor speed passion esc 2.1with the new spec tires only ran them once still trying to get them dial in the rims are from proline i found there are few yrs old
tc3 racer sc is offline
Old 01-03-2014, 10:34 AM
  #2061
theproffesor's Avatar
Trader Rating: 66 (100%+)
Good ol proline gumbys. Man they look good. I put them on the wheel of my old jr radio. Along with a proline treaded on road tire. Maybe more companies will get back in the game with rising popularity of theGT and VTA classes.
theproffesor is offline
Old 01-03-2014, 10:59 AM
  #2062
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by jlfx car audio
Yjimk ur backwards on ur droop thinking ...
More droop = more weight transfer which is not the cure for a loose on entry car
Not in all situations or we would all be running 0 droop!! Weight transfer can equal more grip in situations where grip is needed (spec tires/limited downforce!!)
"Limiting suspension droop has another interesting effect: you can use it to reduce traction rolling. Often it's a better solution than using stiffer springs and harder tires, it's even better than reducing ride height or adding anti-roll bars. " (both of which reduce traction)
I read this as by decreasing droop you can take traction away which would and can make the rear loose on entry due to less traction. Obviously there is a point where you can have too much droop and thus loose traction too.
On my Spec R it doesnt like full droop but it also doesnt like 2.5 droop so I am about 4 right now and it feels good and planted. Since these tires are not as grippy or rounded as the normal TC type tires i think they work better with weight transfer. But to each his own, its a simple test that can be reversed quite easily!!
MantisWorx is offline
Old 01-05-2014, 12:24 PM
  #2063
IndyHobbies.com's Avatar
Here's the new body I did for my son's USGT car. Its a PROTOForm Camaro ZL1 and he said he wanted a "Metallica" body. He's got good taste in music! More pictures in the custom paint thread.
IndyHobbies.com is offline
Old 01-05-2014, 12:25 PM
  #2064
Its mounted on his Associated TC6. The Metallica Black album snake is on the hood. Just got to get James Hatfield scaled down inside!
Old 01-05-2014, 01:43 PM
  #2065
alloyslash's Avatar
Trader Rating: 19 (100%+)
Now that's some nice paint! Very impressive! I was curious about how you was gonna do a Metallica theme paint job. That would also look good with some electric blue lightening bolts flowing across it ( Ride the Lightening album ).
Have you driven the Camaro body yet? If so, how does it handle/feel?
alloyslash is offline
Old 01-05-2014, 02:25 PM
  #2066
SS LS1's Avatar
Trader Rating: 23 (100%+)
Curious to know this too! (specifically how it works compared to others you have tried)
SS LS1 is offline
Old 01-05-2014, 02:56 PM
  #2067
Bigz84's Avatar
I thought the body felt pretty neutral. i ran on brand new tires, and the car was stupid loose. after a few more packs the car started to settle in and felt planted. the next time out, i am going to try to get the rear end to loosen up a tad, to rotate in the corners and keep the speed as i think my setup had the car stopping in the corners. the body looked awesome going around the track.
btw, the black metallic body looks awesome...kudos
Bigz84 is offline
Old 01-05-2014, 09:17 PM
  #2068
I'm new to this GT class and just got some tires. With the directional tread pattern you now have a left set and right set. Has anyone noticed a difference when reversed or are these tires like the HPI VTA tires where when the tread is not seen they're starting to be broken in?
daveb is offline
Old 01-06-2014, 04:07 AM
  #2069
rcwck's Avatar
Originally Posted by daveb
I'm new to this GT class and just got some tires. With the directional tread pattern you now have a left set and right set. Has anyone noticed a difference I'm jangling or are these tires like the HPI VTA tires where when the tread is not seen they're starting to be broken in?
Speaking of indoor carpet track w/traction compound.
VTA tires take a few runs to break in then with traction drugs they are good for several race days. They reach a point when they become too soft/thin and roll over too far making ill handling. Once the tread is gone they are junk at out track for competition and probably illegal at most tracks. I believe this is partially due to the high profile/ballon style VTA tire design.
I have tried 3 different USGT tires and some do and some do not require a break in period but they are no where close to becoming a slick tire to perform.
rcwck is offline
Old 01-06-2014, 08:48 AM
  #2070
Ed Delgado's Avatar
New Corvette C7R testing at Daytona recently.
Ed Delgado is offline
