    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree280Likes
Old 12-23-2013, 09:19 AM   #2026
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Originally Posted by moparSRT View Post
carpet or outdoor ?
camber & toe in ??
softer rear, lower rear inner camber, narrow rear width will all increase traction.
What tire sauce u using and how much ??
carpet indoors. temp about 60 degrees on the track.
SXT Traction compound
Originally Posted by Tommy R View Post
I think a bit part of that may be the increased power. I know my USGT car was way more powerful than my VTA. But that should only be a factor when on power. In order for any of us to be able to offer some tuning assistance, I'd say you should try to narrow down when the back end is coming around. Is it on corner entry, mid corner, corner exit, etc.? That would be a big help!
Part of me is thinking tires. my VTA tires at least feel more "sticky" than the x-patterns I got on there right now.
This would be corner entry I am thinking. But, in general I can literally drift it completely around the corner. Front end bite feels spot on however.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 12-23-2013, 09:45 AM   #2027
moparSRT's Avatar
full front & rear ?? if so try only inside 1/2 on front.
moparSRT is offline   Reply With Quote
Old 12-23-2013, 10:22 AM   #2028
Tech Legend
Cain's Avatar
initial sauce full front and rear to condition, then full rear and inner edge (say 1/3) of fronts.
Really think its either the tires or possible setup. Thinking of just buying the Ride ones and go from there.
Old 12-23-2013, 10:23 AM   #2029
moparSRT's Avatar
are u using the same car for vta / usgt and just swaping wheels, body and motor ??
Old 12-23-2013, 10:34 AM   #2030
Tech Legend
Cain's Avatar
nope different cars.
setups I started with were basically the same as I figured at least give me a starting point. I also stiffened up the rear on my VTA as I wanted less bite in the rear.
Old 12-23-2013, 11:18 AM   #2031
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
No just narrow rear with hagburg mod to RF mounts. And use only a 1mm shim on RR . this gave my car stupid rear corner bite . if this don't make ur car push u Will traction roll! So usuallythis change also iinvolves raising role center in rear to loose some traction .
I had 2 cars identical in usgt except for this mod and it was insane the difference in rear bite
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-23-2013, 11:18 AM   #2032
DP. Sorry
Justin & Matt Lyons
a800s sanwa m12s
Old 12-23-2013, 11:23 AM   #2033
IndyHobbies.com's Avatar
Originally Posted by nrtv20 View Post
Scott from indyhobbies.com painted this up for me, hpi Honda prelude. He did a fantastic job. I almost didn't want to cover it with any stickers. Much thanks!
Thanks! Glad you liked it. I love those Prelude bodies too. Here's a picture of it on my front porch before I shipped it. Fresh Faskolor paint.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 12-23-2013, 11:24 AM   #2034
Tech Legend
Cain's Avatar
got a link explaining this mod?
Thanks to you and everyone else for your help!
Speaking of molded wings, which ones are the most popular to use and any stocked at amain?
Old 12-23-2013, 04:34 PM   #2035
The hagburg mod is I believe removing .75mm of material from the outside of both RF aluminum mounts . this effectively reduces track width in rear giving me tuning options .
Another option with the 2012 is using the 2.2mm flex chassis xray offers . it defiantly gives more traction in low traction conditions with its softer setup .
This might sound really weird but in med-high traction conditions I've swapped front and rear shocks& springs (tho it was accident at first) it kept car from being on edge wile still allowing it turn in hard .
Justin & Matt Lyons
a800s sanwa m12s
Old 12-23-2013, 04:34 PM   #2036
Justin & Matt Lyons
a800s sanwa m12s
Old 12-23-2013, 05:26 PM   #2037
Tech Legend
Cain's Avatar
thanks for the info!
now I think about it, the vehicle has the standard chassis I beleive and my VTAs have the thinner one. totally forgot about that so will need to play with that there too.
Old 12-23-2013, 07:39 PM   #2038
big_ads's Avatar
Trader Rating: 77 (100%+)
Send a message via MSN to big_ads
Before you get to wild and crazy Cain was this the first time you ran those tires? Watching while marshaling your setup is close but new tires would cause it to behave like yours was. I'd just try moving your camber links so they are as short as possible and no shims under them on the inside, 2mm shim under ball stud on the hub.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Team Genesis R/C Products - Big Head Racing - Team PRCP
big_ads is offline   Reply With Quote
Old 12-23-2013, 07:50 PM   #2039
Tech Legend
Cain's Avatar
thanks, I'll give that a look. the tires aren't new, but they are "new' to me lol.
Old 12-23-2013, 10:56 PM   #2040
DarthRacer's Avatar
did my first USGT race. had the following setup in it:
- Xray T3 2012
- Speed Passion GT2.0 Pro in Blinky mode
- Savox low profile servo (forget the model)
- Speed Passion 21.5 Motor 30 degree board
- IP 7200 mah lipos
- Mcallister Corvette Body
- X Pattern tires (still legal here)
had to add a bit of weight to make minimum but was quite fun.
One thing I am questioning though is that coming from my VTA car, I have it such that I can rotate quickly through the turns, even got some comments on that. My USGT though feels like its drifting the rear end versus planting and turning if that makes sense.
Part of my wonders if its the body, other part, setting.
When you guys see a condition like this, where the rear end is "drifting" around the track, what do you guys do to get more traction on that end? I was going to soften the suspension up a tad back there, maybe some roll center changes.
Do you have enough steering??
When I raced VTA on carpet for the first time two weeks ago (normally run on concrete) I had a very loose rear end, just about undriveable. Several things were suggested to me to gain traction. For me I tightened my rear diff and that took care of most of it for me but other things that you can try are:
move the tops of the rear shocks in a location or two
move the tops of the front shocks out a position or two
softer rear springs
stiffer front springs.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4288 Today 09:45 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
30Tooth, pphaneuf
