    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree508Likes
Old 11-16-2013, 12:52 AM   #1831
alloyslash's Avatar
Trader Rating: 19 (100%+)
Originally Posted by snoopyrc View Post
I just got a package from Mr. Lemieux. That really is a great deal for four tires and some stickers.
Mine are scheduled to be delivered today I also bought the 24mm wheels that he is stocking. Im gonna order that set of RSD spacers from Reflex, It has 4 different thicknesses in it to choose from. Once I figure out what added offset works for my body I'll get the right hexes then.
http://www.reflexracing.net/RSD-12mm...m-_p_1063.html
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 11-16-2013, 06:16 AM   #1832
Originally Posted by Kevin K View Post
The changes that I always made when going from X-patterns to the Rides was with the Ride tires I ran my inner camber link longer and lower on the bulk head. I even added more spacing on the top of the castor block...so more angle down towards the center of the car from the outside. From there if I needed even more I would go down in front OIL and lean the shocks in more on the tower. Narrow up the front end of the car or widen out the rear end of the car....at the hex is the fastest way on most cars. I would mainly play with the front end of the car but if I was out of options in the front I would move the rear shock in 1 hole on the lower arm. After that if I still needed more I would raise the rear inner camber link. best of luck....
goood info
i didnt do anything different to run the ride tires..but.. go up on my D.R & BROKE the tires in & they work the same for me...but i may try what you suggest just to see if anything feels different
starrx is offline   Reply With Quote
Old 11-16-2013, 08:00 AM   #1833
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
The ride tires wouldn't turn for me the rear felt too locked in . And the day I ran them incident have the time to tune on set up ...
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-17-2013, 12:51 PM   #1834
SS LS1's Avatar
Trader Rating: 23 (100%+)
Yeah I know Im one of the guys who went out and picked up a D3.5 21.5 when the 17.5 hit the market and punched everything else in the face with its speed. I ASSUMED that the 21.5 would be the same....but nope its not even close.........
Kevin, I have also not been impressed with my 21.5 D3.5 for USGT racing.
So which 21.5 have you seen/used that was the fastest and USGT legal? If you were going buy a new 21.5 today which one would it be (not worrying about cost either)?
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 11-17-2013, 01:15 PM   #1835
alloyslash's Avatar
With the new Ride tires, it looks to me like there is a small groove in the center of the tire but on one side of it is the mold line. Do I need to attempt to file down the mold line or run them as is? I haven't mounted them yet, so it would be easy to remove the foam and pinch the sides of the tire together to make the mold line stand up, making it easier to remove. Do I need to spend the time it would take tho?
Old 11-17-2013, 02:28 PM   #1836
i ran them out the pack...it took about 3-5 runs on them to break them in...so if your not racing just practice i wouldnt worry about the seem...but if you tryna run a fresh set on a race day i would file down the seem & soak them in compound to soften them up alil...i got well over 20+ runs on mines & they still look new
Old 11-17-2013, 05:09 PM   #1837
rcman182006's Avatar
Send a message via Yahoo to rcman182006
So we have a local track looking to get a class of these going and I've been wanting to try so a couple questions:
1. What's the "Go To" body or does it really matter?
2. Coming from a 17.5 Buggy, is gearing the same basic theory of smallest spur/largest pinion that I can put on as it is with the buggies?
Thanks!
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 11-17-2013, 05:17 PM   #1838
Tommy R's Avatar
Trader Rating: 20 (100%+)
Thanks!
1. Personally, I don't see a clear body that's a front runner over others. People locally (med-large asphalt) seem to like the Civic and GTR. Personally, I've really liked the BMW GTR.
2. I've run as tall as 3.3 FDR, but beyond that temps and lack of low end grunt became an issue. So I wouldn't say it's just a matter of gearing up as high as you can. My experience was with a Thunder Power 21.5, FWIW.
Good luck!
Tommy R is offline   Reply With Quote
Old 11-17-2013, 06:13 PM   #1839
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
So we have a local track looking to get a class of these going...
Chuck, where's your local track? I'll be in Logan during the week of Christmas and am debating whether or not to bring any of my RC gear.
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: XRay & XRay
Rodarbal is offline   Reply With Quote
Old 11-17-2013, 06:17 PM   #1840
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Thanks!
I have a body illness I have tried many bodies but to make a long story short you can't go wrong with a Acura NSX Tamiya are hard to find but the HPI HSX is very good. I've also had good performance from Protoform Camaro. I have run the fastest with Protoform LFA This body is great on our 135/x70 open flowing asphalt track.
Look at my photo album and you can see some of my body addiction.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 11-17-2013, 06:20 PM   #1841
We've got 3 local Off Road tracks, 2 in Columbus, 1 in Jeffersonville. The Loft and Sparks Park are the Columbus ones, The R/C Factory is the other. Sparks is the one putting in the carpet track but I don't know when it'll be done for sure
#NoChuck2015
Old 11-17-2013, 06:28 PM   #1842
Rodarbal's Avatar
Oh yeah, I've run the HPI NSX and like it very much, although in our club we've seen quite a variety of bodies be competitive.
Cool, man. Ben Cook has me in the Ohio RC Racers FB group so I'll try to stay updated through that. Thanks!
RJ Labrador
Old 11-17-2013, 07:19 PM   #1843
Here is a link from this weekends Hurricane Series round 2. I believe 5 out of 8 in the A were on Ride/Gravity RC tires. The Gravity tire TQ'd
2013/14 Midwest All-Star Carpet Series
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 11-17-2013, 07:45 PM   #1844
& for carpet onroad
we have
access hobbies...springsfield ohio
red mosquito raceway...batavia ohio
the gate...cleveland
ovrccc...belpre ohio
Old 11-17-2013, 07:46 PM   #1845
tc3 racer sc's Avatar
i saw those suppose to be spec tire at the track today those tires to me dont have a real good tread in them they look fake personal i like the x pattern for usgt
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4435 10-21-2017 06:07 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
