    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree454Likes
Old 11-04-2013, 07:22 PM   #1756
Trader Rating: 44 (100%+)
Anyone run a reedy mach 2 in a t3 what kind of gearing and timing are you using? I'm usin a 96 tooth 64p spur gear.my track has a 60 foot straight. Thanks
Justin33 is offline   Reply With Quote
Old 11-04-2013, 07:56 PM   #1757
Ray k's Avatar
Trader Rating: 46 (98%+)
38 degs. timing , 44 pinion , 4.15 FDR. Up or down a tooth depending on the heat .
Ray k is offline   Reply With Quote
Old 11-04-2013, 08:09 PM   #1758
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by Essnowyt View Post
Exotek 24mm
http://www.redrc.net/2013/11/exotek-...ls/#more-73489
If only these came in white.
Snowy.
If these are made with the same plastic as the F1 rims I would hold off on a track with hard boards. The F1 rims broke and bent rather easy from what people have said. You can always paint them if you want them in white.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-04-2013, 11:05 PM   #1759
MikeR's Avatar
Trader Rating: 15 (100%+)
For the record these are made at a different factory then the F1 wheels. These wheels actually may be a couple grams heavier then say an HPI wheel which reflects the extra back ribbing for reinforcement (see photo). As noted in the specs;
Heavy duty GT style 1/10 sedan wheels. Special US spec formulation for Exotek contains 100% nylon with no fibers for just right rim flex and increased traction on asphalt or carpet.
The 10 spoke wheel pattern maintains durability for high impact indoor racing.
Regarding the F1 Wheels- the first batch is when a few racers reported some breakage even though our testing didn't result in any weaknesses. As result the follow up batches was a softer nylon. Once we went to the softer nylon the reports of problems to us stopped. The F1 wheels are selling very well and we are on our 4th production run so they are going strong
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-05-2013, 12:57 AM   #1760
Kevin K's Avatar
Cool best of luck!
Old 11-05-2013, 03:45 AM   #1761
nrtv20's Avatar
For the record these are made at a different factory then the F1 wheels. These wheels ....
Any chance of making them in white or different pattern?
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 11-05-2013, 07:24 AM   #1762
DARKSIDE's Avatar
yeah...but screw the color...how about a 3-6 mm offset...please
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 11-05-2013, 07:30 AM   #1763
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
What he said. ^^
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 11-05-2013, 07:35 AM   #1764
moparSRT's Avatar
plenty of offset wheels in 26mm to choose from ...
moparSRT is offline   Reply With Quote
Old 11-05-2013, 07:43 AM   #1765
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Ouch! Oh that hurts... Just twist the dager there.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 11-05-2013, 07:49 AM   #1766
NutDriver's Avatar
I am asking this honestly, do you reallly think that 2mm in rim difference is going to make that much of a difference? That's less than 1/12th of a inch.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-05-2013, 08:02 AM   #1767
MikeR's Avatar
Cool best of luck!
Thanks!
I want to see how these sell in the US before offering more colors and wheels
Old 11-05-2013, 08:11 AM   #1768
moparSRT's Avatar
Snowy.
LOL just saying
A 24mm tire would not have been my first choice for usgt
Old 11-05-2013, 08:16 AM   #1769
DARKSIDE's Avatar
Thanks!
USGT is 90% looks, and most racers run 200mm bodies...zero offset looks horrible, and spacers look much worse...start with at least a 3 mm offset, and Im sure 6's will follow...
But don't stick your neck out for one racer, see if its possible to pull a 3mm offset, and see if it sales
Battman
Old 11-05-2013, 08:21 AM   #1770
moparSRT's Avatar
Battman
Also might be a better idea to start with a popular color like white that can be easily dyed black or any other color.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4392 Yesterday 06:17 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
glennhl
