    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree2Likes
Old 10-29-2013, 04:58 PM   #1711
Originally Posted by snoopyrc View Post
And Black. Black tires are the fastest ones.
When are they back in stock? I still don't have a set yet. I guess I don't need them until the year rolls over, but still I would like to have them glued up an get a feel for them.
Paul said maybe 2 weeks at the soonest. Send me a PM if you want me to send a set to you.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 10-29-2013, 05:23 PM   #1712
Travis S's Avatar
Trader Rating: 46 (100%+)
I used them all weekend at the classic and they worked very good. I didn't do as well as I hoped, but that didn't have anything to do with the tires. My main issue was that my motor went out and I tried a different brand and didn't know what to gear it at and setting the timing wrong. (Found out it was set about 20 degrees low! I didn't have the speed I should have and came off just over 100 degrees after the main.)
Here is a picture of the tires next to a pair I haven't used yet. The outsides are the ones I ran vs the middle are just mounted with a little bit of seem removal. As you can see they will round out more after some use.
Travis S is offline   Reply With Quote
Old 10-29-2013, 05:53 PM   #1713
DARKSIDE's Avatar
I had better luck with them this weekend than last time I ran them....Im still think my Xpatterns are faster, but Ill be doing some deep testing Wed at the track...
I had a busted bulkhead and my car never got back right, plus I had to leave before my main to catch my plane back to Nashville....
Im sure that this is the right direction for the class....Im going to put a pair on my HPI rims too to see how they act...3 and 6 offset, 26mm that is
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 10-29-2013, 06:13 PM   #1714
Trader Rating: 49 (100%+)
just to clarify part of the motor rule..... I know the rule states this:
"ROAR approved 21.5 + 2s lipo batteries No tuning rotors, must use OEM rotor 12.3-12.5mm"
Does that mean we can use any tuned motor from one of the several tuners to we all know are good (EA, Tag, Fantom etc)? Am I misunderstanding the rule or are these legal? I've seen fully tuned motors and what they can do on the track compared to one straight off the shelf.... just looking to clarify for my understanding.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 10-29-2013, 06:18 PM   #1715
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I was told that if trinity/Novak/whoever makes a motor and they have it approved by roar with the 12.5mm tuning rotor then its legal . but let's say u have a trinity D3 21.5 and add a 12.5tq rotor (which wasn't ever approved by roar as a unit) or u buy a EA/fantom D3 based motor as a Tq tuned motor , no its not legal .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is online now   Reply With Quote
Old 10-29-2013, 06:20 PM   #1716
I don't even think the D3.5 had a 21.5tq approved did it ?
What about the kill shot was there 2 different 21.5 submitted ?
Justin & Matt Lyons
a800s sanwa m12s
Old 10-29-2013, 06:40 PM   #1717
Trader Rating: 25 (96%+)
Originally Posted by howardcano View Post
I only got to test them, as there was no racing here, but they worked well, and were at least as fast as the X-patterns on our medium-sized track with CRC carpet. They will probably be faster once I get the gear ratio changed to match the smaller diameter.
I think they hook up even better than my belted X-Patterns if your track allows you to run Sweep 24mm closed cell foams. I used to have to sauce my HPI tires before to get decent grip, now I don't have to use any sauce with the RIDE tires + Sweep foams and I still get faster corner speed to boot. I also feel that by not having to use any sauce stands to reason the tires will last considerably longer to possibly save even more in long term expense, though longevity is pure speculation at this point.
billdelong is offline   Reply With Quote
Old 10-29-2013, 07:00 PM   #1718
waltss2k's Avatar
I mounted up a set of Rides on Hpi wheels 3mm offset front 6mm rear offset, and after 9 runs they are showing no wear. I didn't sand the seam at all just ran them straight out of the bag and they were hooked up the whole time, even the first lap. Now I am going to mount up a set on Tamiya +3 offsets and see how they do.
waltss2k is offline   Reply With Quote
Old 10-29-2013, 07:08 PM   #1719
waltss2k's Avatar
I did ordered ten sets for my Hobby shop and didn't get them so now all my racers are asking when I might have them. This is the one thing everyone is wandering about is the "Supply and Demand" of a new tire. How do we know that the makers of the Ride tire and keep up and not end up like Hpi.
Old 10-29-2013, 07:13 PM   #1720
DARKSIDE's Avatar
we don't...like anything in RC...companys are run by humans...they can drop the ball....but Im sure Robk Kevin and Eric have done their homework on this and Im sure this is going to work out fine
April 8-9
Old 10-29-2013, 07:32 PM   #1721
robk's Avatar
Trader Rating: 22 (100%+)
It means no tuning rotor. What comes in the base motor is what is to be used.
Old 10-29-2013, 07:37 PM   #1722
robk's Avatar
100 sets were ordered and sold out in a week. Another 100 sets have been ordered. This being a brand new venture, Gravity RC had to gauge response. Kevin K Eric and I were confident there would be a good response, but selling out that quick is crazy. There is no problem getting the tires, but Gravity has to get a feel for how many sets they will sell per month.
Old 10-29-2013, 07:40 PM   #1723
Thanks Rob. Just wasn't sure as I thought some motors could come with both rotors, and didn't know what would be considered stock, wasn't trying to muddy the situation. Thanks again.
SpeedMerchant Rev7
Old 10-29-2013, 07:48 PM   #1724
moparSRT's Avatar
wow they look swelled up quite a bit
are they on 24 or 26mm wheels ?
moparSRT is offline   Reply With Quote
Old 10-29-2013, 07:59 PM   #1725
SS LS1's Avatar
Trader Rating: 23 (100%+)
Wow, they really swelled up didn't they?! (just like the VTA tires do)
What traction compound were you using?
Did you change you overall gearing FDR with the increase in overall diameter?
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4088 Today 05:18 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 10:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 10:24 PM
