    Hide Wikipost
Old 01-18-2017, 10:08 AM   -   Wikipost
R/C Tech Forums Thread Wiki: USGT
Last edit by: jlfx car audio
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Like Tree44Likes
Old 10-26-2013, 01:49 PM   #1666
Originally Posted by buckeye dan View Post
ok just to clarify i can fun a 26 mm rim with the ride tire?
Yes, they will fit. The tire will have more of a square look to them as well as a possible slightly shorter sidewall. The insert will also then not necessarily fully support the contact patch of the tire.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 10-26-2013, 02:07 PM   #1667
moparSRT's Avatar
24 & 26mm
moparSRT is offline   Reply With Quote
Old 10-26-2013, 02:47 PM   #1668
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Yes it hardly makes any difference in the profile of the tire . I just mounted a set on some silver jaco wheels my self ..
I baked them @400deg for 15min lol glad I'm single I would be in hot water ...
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-26-2013, 03:51 PM   #1669
Trader Rating: 25 (96%+)
I pulled out the caliper to make some comparisons and used the following speed calculator with the only variable being the tire diameter to get the following results for estimated top speed with each combination:
http://scriptasylum.com/rc_speed/top_speed.html
Although the RIDE spec tires do fit rather clean on the 26mm wheels with 6mm offset, there is clearly a disadvantage in doing so by losing roughly 0.34 mph, and the difference in speed 2.15 mph lost simply by changing over to the new spec tires, I definitely saw this first hand when racing other drivers running the HPI tires at my local track. I have not tried to alter my gearing to accommodate the smaller diameter tire, so I guess it's entirely possible to make up the difference there maybe?
*** EDIT ***
using the calculator, I had to drop 7 teeth on the 64P spur to get the same speed with the Tamiya tire as the RIDE on 26mm wheel.
*** EDIT ***
the more I study the difference between the RIDE spec on 24mm wheel vs 26mm wheel, I'm starting to think maybe that the 26mm might do better overall. The tire on the 26mm wheel is far more flat across the width providing more contact patch and will undoubtedly be less susceptible to ballooning which may provide better traction in corners... however the 24mm wheel feels softer which in turn might make it better. Perhaps it can all boil down to 24mm wheels doing better on carpet with 26mm wheels doing better on asphalt... who knows?
Also recheck your ride height when changing over to the RIDE tires as the whole geometry changes with the car being significantly lower to the ground. There is 0.8mm difference just from swapping between RIDE spec tires on 24mm vs 26mm wheels!
billdelong is offline   Reply With Quote
Old 10-26-2013, 04:09 PM   #1670
howardcano's Avatar
Yes, change the gears to maintain the same roll out.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 10-26-2013, 04:27 PM   #1671
This is me making a 24mm rim . worked great and is strong . still flexible also
Justin & Matt Lyons
a800s sanwa m12s
Old 10-26-2013, 07:49 PM   #1672
snoopyrc's Avatar
That's awesome.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 10-27-2013, 05:10 AM   #1673
buckeye dan's Avatar
I will rephrase my question can i legally run 26 mm rims because our lhs and race track is saying that these rims are gonna be speck rims?
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 10-27-2013, 06:12 AM   #1674
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Yes only the Ride tire with the supplied insert are spec'd you can use any 24 or 26mm non dish wheel. The light weight Ride rims are going to be hard to beat for all out performance just based on weight alone but we understand that guys still want looks or offset.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-27-2013, 06:59 AM   #1675
alloyslash's Avatar
Trader Rating: 19 (100%+)
I haven't been in the race scene since april. I'm now trying to get back to the track, but it seems a few things have changed. I like the look of the new Camaro body. How does its handling compare to the RX8, which is what I ran before?
I run a T3'10, what offset wheels will work best using the Camaro body with the new spec tire?
I was running a d3.5, but understand now its not legal. What is a few of the popular motors that people are having good luck out of? BTW I run a SP Revention ESC.
JLFX CAR AUDIO, is Thunder requiring the new tire yet? Whats my choices there now for club races?
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 10-27-2013, 07:21 AM   #1676
Just my opinion; each track is going to handle the motor thing individually would be my thought. The Southern Nats, made the call to allow any mfg that had a ROAR legal 17.5, their 21.5 would also be legal (however excluded the D3.5 and any mfg's motor labeled as "outlaw"). So each track may vary.
Quite a few mfg's never submitted them to ROAR due to the fact ROAR does not have any 21.5 classes, but built them using ROAR spec's
Old 10-27-2013, 07:37 AM   #1677
Alloy slash . thunder is the only track that I know of that's keeping all D3.5 off the track during big events or point series races. Also these events will also be the only ones that will require treaded tires . I don't seen them going to the speck tire this winter . tho I have already got 3 sets to test
Justin & Matt Lyons
a800s sanwa m12s
Old 10-27-2013, 08:13 AM   #1678
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
*** EDIT ***
*** EDIT ***
So that explains why my usgt 21.5 is much faster top end vs my spoke wheel slicks 24mm. I'm geared at 3.20 fdr and when I put the hpis the car about half way mid straight sounds like it goes in boost which isn't boosted. I am keeping up with 17.5's when we drag race them I wanna say they put a foot gap off the line amd it stays that way, when it comes to the infield they aren't all that great until they warm up
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 10-27-2013, 10:30 AM   #1679
according to my scales, the difference in weight between the spec 24mm wheel and my HPI 26mm wheel is 1.1 grams:
Old 10-27-2013, 03:44 PM   #1680
moparSRT's Avatar
That's awesome.
Thats awesome and crazy at the same time, hope this is not the only option to get offset wheels for a class where most use 200mm bodies on 190mm chassis.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4230 04-19-2017 09:37 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
RC GT Open str8.krooked Colorado Racing 49 04-28-2009 09:24 PM
