USGT
#1639
I know that the Scion Challenge Series in So Cal all used the same body, and they were available at the tracks / shops that hosted the series. (TQRCRACING.COM) was one.
I believe they were all HPI Scion FRS bodies -
http://www.hpiracing.com/en/part/108064
I really wanted to run in the series, but do mine up in the Subaru BRZ colors
#1641
If they haven't already done so, I would get them in contact with Gravity RC, [email protected]
#1644
#1647
I also love the decals that come with the wheels and tires to help you remember car setups, very cool
Only question I have is the included foams appear to be closed cell, are you guys slicing them with a hobby knife before inserting and then re-gluing to make it easier to balance the wheel? Or did the rule change to allow for closed cell foams too?
#1648
My order arrived in only 2 days shipped to ATX, very fast shipping... Thanks Paul
#1649
I found this link here which explains the difference between open and closed cell foams, and frankly it's nearly impossible to tell the difference to an untrained eye:
http://www.foam-tech.com/products/ur...losed_cell.htm
How is an entry level racer going to figure out what to select when manufacturers don't specify, for example these foams here are billed specifically for asphalt racing:
http://www.sweepracingusa.com/110-TC...et_p_207.html#
then these foams here are billed for carpet racing:
http://www.sweepracingusa.com/110-TC...set_p_412.html
Now I can't tell the difference whether it's open or closed cell (they don't say anywhere in the product details that I can see), but it would make more sense to me to use the appropriate foam for the intended application by the manufacturer to get the best possible wear and performance out of the tire. Both from an economical and performance point of view.
I've been running the first set of foams in my 24mm RIDE tires on an asphalt track for a few race days and my car has hooked up like it's on rails with nearly no signs of tire wear. Nothing close to what I was seeing with the HPI tires.
It will be interesting to test and see both in performance and wear with the new spec tire/foam combo and contrast them with what I've been using lately.
#1650
Bill, you can definitely see and feel a difference between open cell foam and closed cell. Open cell is what you typically find used for egg crate foam, or room sound deadening material. Closed cell feels more like foam rubber or rubber matting.
Both of the Sweep foams you've shown above are closed cell. They're just different durometers for different applications.
