Old 06-12-2010, 12:49 PM   #1
ugglasdav's Avatar
Default TCR5 diff nut
hi there just a small question on the front diff of a TC5r, does anyone know were you can get the little black thing were the tiny nut sits into when asseblying the diff . i need a replacment of both the nut and th black thing. thanks
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 06-12-2010, 03:49 PM   #2
Rick Hohwart's Avatar
Instead of using the stock diff nut and housing, try the B4 diff nut #6575. This nut will not strip as easily which will allow you to run your slipper spool tighter so that it works more effectively.
If you use a diff in the front this part will not make any difference. However it is one piece which makes it easier to deal with.
Rick Hohwart is offline   Reply With Quote
SEO by vBSEO 3.5.0
