Surikarn cyclone question
just use the moorespeed edition manual..
I don't think there's a complete rebuild kit for the older diff design. You'll have to piece together the 2mm and 2.4mm balls, rings, washers, diff screw and such to rebuild it.
I would suggest you look at getting a complete #67720 Pro-Spec diff assembly. This is the new diff design that comes standard with the Cyclone TC and it drops right into your Surikarn edition. It uses larger balls, rings and uses a much beefier diff screw assembly which stands up to the torque of todays BL motors. This diff is butter smooth and stays smoother longer. It also comes standard with ceramic 3mm balls.
Just a suggestion.
