Like Tree3Likes
Old 08-06-2016, 11:10 PM   #871
bornox's Avatar
Trader Rating: 26 (100%+)
Originally Posted by EDWARD2003 View Post
Are you talking about the Team Bomber rear pod? You can use the IRS axle unit on either the Yokomo C3 rear bulkheads or the Team Bomber bulkheads. You will need to use axle shims and "standard" wheels to complete this setup.
stock rear pod w/ bomber bulkheads
bornox is offline   Reply With Quote
Old 08-07-2016, 05:29 AM   #872
EDWARD2003's Avatar
Originally Posted by bornox View Post
for r12c3 with team bomber conversion, can i use the irs kit?
Then you'll be fine.
EDWARD2003 is offline   Reply With Quote
Old 08-07-2016, 07:35 AM   #873
bornox's Avatar
thanks!!!
Old 08-26-2016, 08:08 AM   #874
TOM MAR's Avatar
Anyone looking for a R12c?
TOM MAR is offline   Reply With Quote
Old 08-07-2017, 06:41 PM   #875
Default Rear ride height adjusters w/ larger offset
Would anybody happen to know if Yokomo (or maybe an aftermarket source) make rear ride height adjusters with an offset greater than the 1.75 insert that comes with Yokomo's set of adjusters? I'd sure like the ability to run smaller rear tires while still maintaining ride height.
vafactor is offline   Reply With Quote
Old 08-07-2017, 08:06 PM   #876
TOADYY's Avatar
Send a message via AIM to TOADYY
You can use the CRC rear ride height spacers.
https://teamcrc.com/crc/modules.php?...prodID=7719129
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 08-07-2017, 08:39 PM   #877
JimmyMac's Avatar
Did you get the car back?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 08-07-2017, 09:39 PM   #878
AZ Wolfie's Avatar
Yokomo made 2.0 inserts for their previous F1 car, the YRF001, which are a perfect fit.
https://www.amainhobbies.com/yokomo-...yf-20h/p261437
The CRC ones listed by TOADYY will not fit the Yokomo R12, or at least they won't fit on mine.
AZ Wolfie is offline   Reply With Quote
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
