Like Tree3Likes
Old 07-12-2015, 11:21 PM   #811
Originally Posted by EDWARD2003 View Post
Thanks Edward...is this what most of the guys in Japan are running? The inner holes?
Simon Noton is offline   Reply With Quote
Old 07-12-2015, 11:31 PM   #812
EDWARD2003's Avatar
In Japan, most guys run their side springs on the outer hole position (on top of the side-link). I prefer the inner hole position, however, you'll need to run a slightly firmer spring (inner hole position).
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 07-14-2015, 05:52 PM   #813
EDWARD2003's Avatar
New Team Bomber chassis plate which gives you a multitude of electronic layouts. Transverse or inline battery positions. Front servo mounting or Yokomo crank system. There are mounting holes for popular Sanwa SRG servos.
Just a quick note on this chassis.
The overall length is 2 mm longer than the stock Yokomo C3.1 chassis. Which means if you're running the Team Bomber adjustable bulkheads then you'll probably have to move the axle in the forward position. If not, then you'll be running a 5 mm longer wheelbase.
By all means give it a try and see how it works with running 5 mm!
                 VBC 12M - D08 - FX
Old 07-14-2015, 05:55 PM   #814
EDWARD2003's Avatar
New Team Bomber parts!
Updated rear bulkhead with aluminum cross brace.
Comes in blue and black anodizing.
They seem to have gone away with the optional axle positions.
The rear offset is set 1 mm back. Also the axle adapter height position has been lowered. This will allow you to still maintain legal ride height while running tires that are 39.00 or smaller.
                 VBC 12M - D08 - FX
Old 07-20-2015, 07:42 AM   #815
EDWARD2003's Avatar
https://www.youtube.com/watch?v=aI_jBMLmIa0
Video review of the Team Bomber R12 2015 chassis.
                 VBC 12M - D08 - FX
Old 07-21-2015, 09:40 PM   #816
bornox's Avatar
Trader Rating: 26 (100%+)
forgot to ask u. is this a direct fit on r12w?
bornox is offline   Reply With Quote
Old 07-21-2015, 10:35 PM   #817
rocketron's Avatar
Trader Rating: 16 (100%+)
Edward is there any chance you could point me to a shop in Japan that I can purchase TeamBomber product that ships to the US?
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 07-22-2015, 04:22 AM   #818
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
info@teambomber.jp
I sent them an email... The reply said they would gladly ship to the US, even take Paypal payment too.
Mach10_shooter is offline   Reply With Quote
Old 07-22-2015, 10:46 AM   #819
rocketron's Avatar
Originally Posted by Mach10_shooter View Post
info@teambomber.jp
LOL thanks too easy
Old 07-22-2015, 03:43 PM   #820
EDWARD2003's Avatar
Hello!
Sorry, I couldn't answer your message. Thanks Mach10_shooter for giving him the info. I know the owner of Team Bomber. His name is Kato. Nice guy, and very friendly.
                 VBC 12M - D08 - FX
Old 08-31-2015, 02:47 PM   #821
bornox's Avatar
http://www.muddslidemotorsports.com/1graxkitwi3m2.html
1/12th Graphite Axle Kit with 3mm Offset Hub - Includes : Axle (IRS2112BL), 3mm Drive Hub (IRS1126BL), Clamping Hub (IRS219BL), Diff Cone (IRS527BL), Diff Nut (IRS203BL), (2) Ultra Lite D-Rings (IRS2511), Diff Nut (IRS203BL), (12) Diff Balls (IRS204)
The above is what I am using. I'll measure the shims tonight and let you know the proper spacing.
Just a picture to show the different wheel colors. You can still run the Yokomo front wheels with no problems. If you're all about looks, you can run any brand of front wheel with no issues. Keep in mind, as you change from one wheel brand to another the offset might be different. Which means you'll have a different front and rear track width.
does it need a thrust bearing on this differential?
Old 08-31-2015, 06:44 PM   #822
EDWARD2003's Avatar
Yes, and you can use the Yokomo R12 thrust bearing or a Slapmaster thrust kit. Works like a treat.
                 VBC 12M - D08 - FX
Old 09-03-2015, 08:45 PM   #823
bornox's Avatar
thanks!
Old 09-03-2015, 09:55 PM   #824
bornox's Avatar
for the TN racing wheel hub part number TN958 can i use different brand wheels on this one?
Old 09-12-2015, 02:37 PM   #825
Send a message via ICQ to MattW
Does anyone know the spring rates of the Yokomo side springs?? Trying to see how they fit alongside the Associated range.
MattW is offline   Reply With Quote
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
