Like Tree3Likes
Old 07-05-2015, 12:34 AM   #781
EDWARD2003's Avatar
Under chassis
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 07-05-2015, 02:02 AM   #782
Edward,
Were they running the prototype for this race or was this just a display piece only? If they were running an actual prototype how did it look on the track?
Thanks,
Patrick
XCELL is offline   Reply With Quote
Old 07-05-2015, 02:21 AM   #783
EDWARD2003's Avatar
Just a display piece. They're still running the C3.1. I think this chassis will be a difference maker in low traction. The current CRC dominates on low traction conditions, so Yokomo is trying to fix that.
As for when it will be released. Who knows? I think they'll start testing in the coming months.
Naoto was in attendance with a Team Associated/Muchmore R5.2. Didn't fair so well. I'm not surprised. It goes to show how important his old mechanic was to his success.
                 VBC 12M - D08 - FX
Old 07-05-2015, 02:28 AM   #784
EDWARD2003's Avatar
Team Bomber has an optional chassis in the works. This main chassis is saaaaaaweeeet. So many layout configurations.
                 VBC 12M - D08 - FX
Old 07-05-2015, 12:20 PM   #785
JimmyMac's Avatar
Awesome pics Ed, thanks!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 07-05-2015, 03:14 PM   #786
bornox's Avatar
Trader Rating: 26 (100%+)
Default R12w
does anyone here knows if the new parts of r12c3 fits r12w?
bornox is offline   Reply With Quote
Old 07-05-2015, 05:42 PM   #787
EDWARD2003's Avatar
What parts are you thinking of installing?
                 VBC 12M - D08 - FX
Old 07-05-2015, 07:08 PM   #788
EDWARD2003's Avatar
Team Yokomo A-main finalists (stock and modified). Pictured here (myself and Kuroda Naoki) were the only two Team Bomber chassis'present at the Japan Nationals. However, both were working really well. A string of electrical problems prevented a podium showing for me and Kuruda just had plain bad luck. There's always next year.
For those who are interested, I'll post my setup in the coming week.
                 VBC 12M - D08 - FX
Old 07-05-2015, 07:35 PM   #789
bornox's Avatar
Rear end parts. wheel hub (diff side), counter weight (left) rear shocks, front upper and lower A arm, steering blocks.
Old 07-05-2015, 07:53 PM   #790
EDWARD2003's Avatar
To be honest. I would look at purchasing an IRS differential kit. Beautiful kit and this would allow you to run different wheel brands. I've noticed most guys doing this here in Japan.
Upper arms are the same.
Steering blocks are the same.
Rear shock? You mean the middle damper? Or the pitching damper?
Lower arms are different. You might need to buy a new lower chassis. For it to work. I would save you cash and wait for the new chassis to come out.
                 VBC 12M - D08 - FX
Old 07-05-2015, 08:39 PM   #791
bornox's Avatar
where can i get the IRS diff kit? yes the middle damper. Do i need to change the front axle if im gonna use the IRS diff kit? Sorry i'm new to this class.
Old 07-05-2015, 08:49 PM   #792
Korey Harbke's Avatar
That is interesting. I'd def give the car a go if I could get an IRS axle for it. Then I can run whatever i want! I figured there would still need to he an odd offset for it to work from the pod design.
Korey Harbke is offline   Reply With Quote
Old 07-05-2015, 09:13 PM   #793
EDWARD2003's Avatar
http://www.muddslidemotorsports.com/1graxkitwi3m2.html
1/12th Graphite Axle Kit with 3mm Offset Hub - Includes : Axle (IRS2112BL), 3mm Drive Hub (IRS1126BL), Clamping Hub (IRS219BL), Diff Cone (IRS527BL), Diff Nut (IRS203BL), (2) Ultra Lite D-Rings (IRS2511), Diff Nut (IRS203BL), (12) Diff Balls (IRS204)
The above is what I am using. I'll measure the shims tonight and let you know the proper spacing.
Just a picture to show the different wheel colors. You can still run the Yokomo front wheels with no problems. If you're all about looks, you can run any brand of front wheel with no issues. Keep in mind, as you change from one wheel brand to another the offset might be different. Which means you'll have a different front and rear track width.
                 VBC 12M - D08 - FX
Old 07-05-2015, 09:16 PM   #794
bornox's Avatar
thanks alot! i really appreciate you help.
Old 07-05-2015, 09:23 PM   #795
EDWARD2003's Avatar
You want this center damper.
http://www.teamyokomo.com/partslist/...ts_r12_37.html
                 VBC 12M - D08 - FX
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
