Yokomo R12
#751
Can you run the CRC 72 spur with the 3/32nd balls? That might also save you a little bit more weight and rotational mass. It was apart of my weight saving program on my RR12. It was a pig at 750+grams. I switched out a ton of screws to aluminum, cut off 10mm from my power and motor wires. Switched my 4 cap down to a 3 cap on my esc. Then I switched my amb transponder to my caseless amb transponder. That put me right at 730 grams.
Is the IRS axle a direct fit onto the Yok? Or are you running a Team Bomber rear pod?
The Team Bomber and Yokomo pods are the same width. The IRS is a direct fit and all you'll need to do is shim it for proper width.
#752
Steve Dunn
www.facebook.com/proonerc
[email protected]
#753
I assume I am doing this right... Since the Yokomo/Team Bomber pod is offset. To get the correct distance for each tire from center, I have been measuring the distance between the center point of the chassis to the inside wheel edge. So as it stands, the left side hub has 5 mm shims and the right has 1 mm shim. The distance between the inside wheels to the center point on vernier calipers equals out to be around 48.00+mm- on both sides. This also gives me 172 mm track width. Keep in mind, I am using -2 mm offset wheels when using these shims.
#754
https://m.youtube.com/watch?v=apA2PoDQR8g
The YouTube video demonstrates how to remove any unwanted slop in your steering crank system. It's cheap, easy, and fast to do.
#755
#756
I'm running the C3.1 and see above people running small diameter tires. Not sure what I'm doing incorrect but I can not run rear tire less than 43.5 and achieve 3.5 to 4mm ride height. Any insight is appreciated - I have all the various ride height adj inserts. My primary track is a a little bumpy and this is why so high.
I've seen something about an optional 2.0 ride height insert? this would be perfect
I see there are other spring now available for the X Shock but am not finding an online shop to purchase them.
#758
Yes, there are numerous springs available. You'll have to shop for them using a Japanese hobby shop website.
You can check out - Futaba Pro Shop, RC Champ. Just google it.
FYI you can flip the axle ride height inserts...
#759
How many inserts do you have? I just finished a race today with my tires at 42.00 mm. Ride height was at 3.2 mm for carpet. Are you running on asphalt?
I'll re-try searching for the springs
#760
I haven't seen anyone do that here in Japan. From what I've heard, the modifcation on the rear wheels was a one of deal. The track conditions were low grip and the tire additive was useless. Therefore Naoto's mechanic had to take drastic measures to gain rear traction.
By the way Edwards I enjoy you videos!!!
#761
Morotech making some springs for the X-Shock. So far I can't find them in a shop that ship oversea.
#763
#765
Awesome! I wonder if it still uses the Yok rear wheel offset or "standard" type.
