Like Tree3Likes
Old 02-12-2015, 04:14 PM   #691
choisan's Avatar
Can't buy the wheel disks, out of stock for long time, want to try
choisan is offline   Reply With Quote
Old 02-12-2015, 04:48 PM   #692
EDWARD2003's Avatar
I have them
Don't worry, you're not missing out on anything special. I find that running them on the front made the car easier to drive. Very well could be my imagination.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 02-12-2015, 05:41 PM   #693
Trader Rating: 29 (100%+)
Amain has the rears in stock
branover is offline   Reply With Quote
Old 02-13-2015, 07:09 PM   #694
Am I supposed to trim the plastic shock ends 3mm or something?
Originally Posted by EDWARD2003 View Post
Yes.. This works for me 95% of the time.
1- Fill the damper a little past where the threads start. Take note of the little machined groove in the shock body.
2- Put the piston in and push it down to the bottom.
3 Do 2 or 3 times.. Move the piston up and down to remove any air bubbles that might be trapped.
4- Slide the plastic end piece onto the piston shaft.
5- With your index finger, keep pressure on the piston shaft to prevent it moving up while screwing the plastic end piece on.
6- Before you screw the plastic end piece on, locate the machined groove in the shock body.
7-The machined groove helps channel any excess oil out past a few of the threads and into the sponge, and anything the sponge can't absorb will be cycled through the sponge and push out.
8- When slowly screwing in the plastic end piece, move the shock from a vertical position to a horizontal position. This will give the excess oil a better chance to escape and flow out easily. Go slow, and give the oil a chance to escape.
9- Slowly tighten the plastic piece down and just snug it up, I find you don't really need to tighten it all the way down.
10-Let go of the piston shaft and see what it does. If it moves out a little you're good to go. If it doesn't move that's fine too.
Move the piston back and forth, and listen to hear if there are any bubbles trapped inside.
albertv78 is offline   Reply With Quote
Old 02-16-2015, 01:56 AM   #695
CFR
CFR's Avatar
Servos
Apart from the small Sanwa/Airtronics ones which others fit the chassis using the bellcrack steering chassis?
CFR is offline   Reply With Quote
Old 02-16-2015, 04:47 AM   #696
EDWARD2003's Avatar
1/12th line of servos by Savox, Futaba.. I've bolted them in with little to no problems.
                 VBC 12M - D08 - FX
Old 02-17-2015, 02:33 AM   #697
Hi guys I have the c3.1, would anyone have a base setup for carpet with high side bite?
Also does anyone know where I could buy Team bomber conversion?
*RC-ADDICTION* is offline   Reply With Quote
Old 02-18-2015, 12:29 PM   #698
Does anyone know where to get parts for the latest version Yokomo 1/12th?
Rocket RC Speed Shop - USA Importer of Team Powers products
[email protected]
http://rocketrcspeedshop.webstorepowered.com/
Crashby is offline   Reply With Quote
Old 02-18-2015, 12:51 PM   #699
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
TQRC
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-18-2015, 03:55 PM   #700
Originally Posted by RedBullFiXX View Post
TQRC
TQRc is a good place, Amain has a few parts too, otherwise Banzai Hobby or RC Race and Drift in Japan. Both are very reputable online store.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 02-18-2015, 04:50 PM   #701
TQRC
Thanks, Dave!!
[email protected]
Old 03-23-2015, 02:17 AM   #702
Hi,
do you have any advice to remove the excessive play in the steering?
R12 C3.1
thanks
andrease is offline   Reply With Quote
Old 03-23-2015, 03:50 AM   #703
EDWARD2003's Avatar
Try different manufacture ball cups. I've been using TN Racing ball cups which are a harder plastic then the Yokomo cups. Work well.
As for the bell crank, just use some thin shims and that should remove and slop in the bell crank.
Click here. Yokomo R12
                 VBC 12M - D08 - FX
Old 03-23-2015, 05:35 AM   #704
Many thanks Edwards2003
I will try TN Racing ball cups
Old 03-29-2015, 10:28 PM   #705
EDWARD2003's Avatar
Quite a few shops no longer have (or can't order in) Yokomo C3.1 chassis kits. Most places are out of stock here in Japan. This might be a sign of something new is on the horizon...
Maybe we'll see a WC version in the coming months?
                 VBC 12M - D08 - FX
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
