Old 11-30-2014, 06:28 AM   #601
EDWARD2003's Avatar
Just finished doing product reviews for Team Bomber Racing products.
These products are specifically designed for the Yokomo R12 series.
Check them out!
https://m.youtube.com/watch?v=8x01amNdgv8 Front end
conversion.
https://m.youtube.com/watch?v=sM07qlrNzQU Rear Pod
https://m.youtube.com/watch?v=THPJyGpY-wI Roll tubes
Please feel free to ask me any questions about Team Bomber.
I'm also looking forward to testing out and reviewing products from TKO!
EDWARD2003 is offline   Reply With Quote
Old 11-30-2014, 06:43 AM   #602
EDWARD2003's Avatar
Here's a complete shot of all the Team Bomber products.
Old 12-04-2014, 05:27 PM   #603
EDWARD2003's Avatar
I've done a series of Youtube videos on how to setup the front suspension on your Yokomo R12C3.
Front Suspension Arm Screw Settings.
https://www.youtube.com/watch?v=pKCHMjI49t0
Setting Ride Height.
https://www.youtube.com/watch?v=4geyzPV57Jw
Setting Down Stops (droop)
https://www.youtube.com/watch?v=jYaiV2EG0Ow
Setting Up Stops
https://www.youtube.com/watch?v=kNrPC_XIc2Q
Front Hinge Pin Settings
https://www.youtube.com/watch?v=boVY7jeHEro
Roll Center and Camber Gain Values
https://www.youtube.com/watch?v=v45zMoz6PAI
Front Springs Commonly Used on the R12C3.
https://www.youtube.com/watch?v=YhWDqA-rNWA
Rear Pod Modification
https://www.youtube.com/watch?v=_6PUCeSLCwo
Hope these videos help clear up any chassis setup woes.
Old 12-04-2014, 06:40 PM   #604
Clawhammers's Avatar
Setting Up Stops
Thanks a lot for sharing!!
I've learned a lot from your videos.
Thumbs-UP!
Clawhammers is offline   Reply With Quote
Old 12-04-2014, 07:21 PM   #605
@EDWARD2003, what ride height gauge is that in the 2nd video?
-Mike
Old 12-04-2014, 08:04 PM   #606
EDWARD2003's Avatar
Thumbs-UP!
I'm glad the video worked for you. I'll try to do more videos on other aspects of 1/12th scale. i.e gluing tires, and truing tries.
Old 12-04-2014, 08:06 PM   #607
EDWARD2003's Avatar
-Mike
Eagle Racing ride height gauge.
Old 12-05-2014, 03:19 AM   #608
The Teacher's Avatar
Trader Rating: 47 (100%+)
EDWARD2003, can you post a video on how to get one of these rare R12C3.1....
The Teacher is offline   Reply With Quote
Old 12-05-2014, 05:14 AM   #609
miller tyme's Avatar
I ordered mine from tonisport in Germany, ordered Monday, shipped Tuesday got it on a Thursday,
Ken Miller
RC America - X-Ray - ORCA - EA Motorsorts - Pro Level RC - Sanwa - TQ Wire - ProOne Racing Tires -
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 12-05-2014, 08:01 AM   #610
SLOWINSLOWOUT's Avatar
Trader Rating: 18 (100%+)
I like mine, its not difficult to set up once you figure it out. the car handles well, and is quick, but it is not on point in stock racing. The car is too heavy out of the box, with Ti screws, and the smallest servo, it is 40g over weight.
A smaller shock in next, other than that, dont know where to shave weight from, other than losing the independent front end and bell crank. Then it would be just another generic 12th scale.
I converted mine to the 3.1. With the small tubes, you need to run a significantly higher lube than most other tube designs to get the same feel.
I also found that the car handles best with the smallest possible tires, which is 41.5. The axle spacers do not go low enough to run any smaller and still maintain ride height.
Edward, what tires are you finding work well on the carpet? I have been running the Med/Hard front, and Soft rear in stock 13.5, and med/med in mod.
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Gravity RC - GRIPWORKS RC
WCICS.ca club rep.
www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 12-05-2014, 08:26 AM   #611
Surprising, Mine set up for mod with ESC fan and 6800 batteries and mostly Ti screws weighs in about 3-4 grams heavy, perfect !
Ken Miller
Old 12-05-2014, 09:14 AM   #612
miller tyme, did you get the 3 or the 3.1? Do you know what differs between the 2?
Old 12-05-2014, 04:59 PM   #613
don't do it Teach.
vafactor is offline   Reply With Quote
Old 12-05-2014, 05:34 PM   #614
wingracer's Avatar
Trader Rating: 22 (100%+)
There is a lot of variance in weight of many components. Different motors can easily be 10g or more different in weight. Some esc's are bricks. A viper weighs a LOT more than a Tekin. Batteries can be different. Servos can be a few grams different and smaller isn't always lighter.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-05-2014, 07:00 PM   #615
You are right, of course. I should of qualified my statement. Out of the box, with no electronics, the R12C3 is 25g heavier than a X-12/14 w/graphite axle.( And the Xray isn't exactly a light weight!) Ti turn buckles(all 5), and most screws got 10g off the Yok., and the side tubes are 5g lighter than running the shock. Need to find another 20g somewhere, and run a lightly painted body! (I got the Xray to min weight with the same electronics I have on this car)
I would like to know what electrics others are running to make min. weight. I am running; ORCA VX1, ORCA 6400mah, Sanwa SRG-HS, Sanwa RX-472, Killshot, all wires shortened, 16g motor and batt leads.
Earl Towson
WCICS.ca club rep.
www.krcracing.ca
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
