Like Tree3Likes
Old 05-03-2014, 12:07 AM   #541
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Is there an English version of the manual for these cars anywhere? I'm working on an R12C3, but the manual is in Japanese and I need to order replacement front sway bar mounts. I already ordered the part I thought was the replacement according to the manual, but the slot for the swaybar to rest in is too big. Can anyone give me some insight into this? I cant seem to find any other part numbers that would be correct, much less where to order them to arrive in the states.
Old 05-03-2014, 07:47 AM   #542
EDWARD2003's Avatar
http://www.teamyokomo.com/partslist/...s_r12_17m.html
Is this the part you're looking for?
EDWARD2003 is offline   Reply With Quote
Old 05-04-2014, 06:24 AM   #543
Is this faster than the BD7 touring car around a same track?
Prince Nuada is offline   Reply With Quote
Old 05-04-2014, 09:45 PM   #544
That is in general the correct part. The problem is I ordered one and it varies from the part on the car I need to replace. The one on the car now is intended to hold a smaller sway bar as it has a smaller recess. the r12-17m I received has a significantly larger cutout for the sway bar which makes it nearly useless as the bar moves up and down without translating the force to the opposite arm. Specifically, here is what/where I ordered.
http://www.amain.com/product_info.ph...FewRMwodEBQA_Q
Does anyone have any ideas on getting the right part?
Old 05-04-2014, 10:07 PM   #545
EDWARD2003's Avatar
TQ'd and won the first stage of the 1/12 All Japan Nationals. It was my first outing with the a Yokomo R12C3 and what a beast. Managed to post the fastest lap of the day and was the first time ever to record a 10.645 lap. The fastest ever recorded lap time on this track was a 10.510 by a Yokomo factory driver. Not bad considering it was first time and had limited track testing.
Old 05-05-2014, 09:36 AM   #546
IgorR's Avatar
Hello,
Could you give us some tips about the way you setup the car, what body and tires you used?
Yokomo YR-X12
Shepherd Velox EC
IgorR is offline   Reply With Quote
Old 06-20-2014, 04:24 AM   #547
IgorR's Avatar
An update kit for the C3
Team bomber also has the tube option kit
Yokomo YR-X12
Shepherd Velox EC
Old 06-20-2014, 05:56 AM   #548
EDWARD2003's Avatar
Just bought the Team Bomber version today .
Old 06-20-2014, 05:59 AM   #549
EDWARD2003's Avatar
Originally Posted by IgorR View Post
Hello,
Forgot this post... Oops.
Body - Team Bomber
Tires Team bomber medium front and medium soft rear. However, I might move up to medium in the rear.
Old 06-20-2014, 03:29 PM   #550
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Think I am going to give the R12C3 a try this year. Really like my X12'14, and it has performed well for me, but I like different.
Few questions, does this car use standard size bearings? Or are they metric?
Also, in regards to tires, one of the reasons I want to try this car is the rear hub set-up. Seems to me that the hub off set would work well. However, I have found that I really like certain compound tires, specifically, purple or black for the front, and green or yellow in the rear. How do the Yokomo/CRT pre-mounted compare to the above, what would be the equivalent?
Cheers
SLOWINSLOWOUT is offline   Reply With Quote
Old 06-21-2014, 06:57 AM   #551
EDWARD2003's Avatar
Cheers
Uses standard sized bearings.
I just bought 140 USD worth of Yokomo CRT Premounts. I'm running CRT medium (magenta) front and rear. .
They work like a charm for stock racing. Just sauce them achieve the handling you desire.
Old 06-21-2014, 04:17 PM   #552
Thanks, I know you race in Japan and use different motor batt., but do you have any set-ups for stock racing for this car. Not much here in NA using it. Wondering what springs I should get for it.
Also, is there any other shops in NA that sell parts/tires for this car besides Amain?
Old 06-21-2014, 10:12 PM   #553
TOADYY's Avatar
Send a message via AIM to TOADYY
If you want the standard compounds with an offset, look at PRO One RC, they have a facebook page.
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 06-25-2014, 01:28 AM   #554
Hello
Where can i purchase this TEAMBOMBER products?
Body and conversion kit looks very interesting for me.
But I'm a little bit confused about the part numbers of
the conversion kit. On the HP there are 4 part numbers...
2 for the conversion with the blue and 2 numbers for the
conversion with the black tubes. i own a C3, so which
is the correct part number for the blue ones?
Regards,
Gero
Gero is offline   Reply With Quote
Old 06-25-2014, 04:48 AM   #555
EDWARD2003's Avatar
The first two Team Bomber codes are for the C3
TB20081 and TB20082. The 83 and 84 are for the R12 chassis.
I'm not sure where you can buy the kits outside of Japan. I can email the owner and ask him.
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
