Old 11-03-2013, 12:51 AM   #511
CFR
CFR's Avatar
Originally Posted by Me_MrTyson View Post
What servo are people using ??
Servo, Spektrum A5040, 25 in the UK and well worth it compared to 60 + for a Futaba.
You need to to shorten the servo turnbuckle by 3 or 4 mm to get the right length so that the servo saver is inclined forward. Centre servo then move saver 1 spline forward. if that's to much then use the trims.
CFR is offline   Reply With Quote
Old 11-03-2013, 02:56 AM   #512
hi, i'm running a R12-C3 and i have a problme with the front.
The car jumps in fast corners. I've tried everything but nothing change.
Do you have any advice for me?
drake_1985 is offline   Reply With Quote
Old 11-03-2013, 07:52 AM   #513
CFR
CFR's Avatar
On the cross damper make sure the grub screw is at 90 degree's to the chassis so it's not touching in roll
or try the following if the above is done,
If you've built the front end as per kit then try the hinge pin inserts so the hole is at the bottom to lower the roll centre
Also mount the side springs inboard so they touch the chassis not the links as this removes preload from the spring. You need 14mm screws for this and make sure the ball joint of the centre damper doesn't touch the 14mm screw in roll.
http://rcracechat.com/vb/showthread....l=1#post449287
Old 11-09-2013, 03:35 PM   #514
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Default steering rack
in the kit a few options are available from -0.5 2 +1.5
has anyone tested the difference ?
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 11-22-2013, 01:55 PM   #515
swimbikerun's Avatar
Trader Rating: 100 (100%+)
It adjusts your ackerman. -0.5 give you the greatest ackerman while the +1.5 is the least. I've been playing around with 1mm to the 1.5mm to mellow out the front end.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 11-23-2013, 02:17 PM   #516
Me_MrTyson's Avatar
Thanks for the reply been using +1.0 myself really makes the car feel better
Am wanting to also test between 2 and 3 hole pistons have you tried different pistons and what effect did u find .. Normal I run 2 hole with ae 60wt
Old 12-02-2013, 03:44 AM   #517
peter george's Avatar
Trader Rating: 318 (100%+)
Unhappy
An ybody here care to share if they have a US supplier for yokomo R12 parts? I'm still ok but I am running low on front arms. Thanks
Team Underdog-Team UPURZ-Island Raceway & Hobby-Showing up and paying entry fee alone is not:"supporting your track" Stop fooling yourselves-buying online kills local racing programs.If we trade lower feedback always ships first.Team Associated B5m-CRC-Durango DEX210-CSO-Intech-Eagles of Death Metal-Tylenol
peter george is offline   Reply With Quote
Old 12-22-2013, 11:23 AM   #518
Hello, what's the difference between regular and 0.5mm front upper arm mounts?
MimoGR is offline   Reply With Quote
Old 01-06-2014, 03:02 AM   #519
BardSmith's Avatar
Trader Rating: 59 (98%+)
My RC12C3 is up for sale... FS Yokomo R12C3 12th Scale Like New
"Bard"
On-Road Only!
BardSmith is online now   Reply With Quote
Old 01-06-2014, 04:16 AM   #520
JayBee's Avatar
Trader Rating: 31 (100%+)
Is that front end a bear to set up?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-06-2014, 04:22 AM   #521
BardSmith's Avatar
No, not a problem at all. It's fun to tinker with. Has downstop and travel set screws (droop and ride-height screws), and dampers. Its way cool.
"Bard"
On-Road Only!
Old 01-21-2014, 08:43 AM   #522
Any one know the part no for the new wire type anti roll bar for c3?
I upgrade from conversion kit. The kit not come with it.
Is it worth to buy or just use the original anti roll?
Thanks.
Lcvwing is offline   Reply With Quote
Old 01-21-2014, 12:35 PM   #523
CFR
CFR's Avatar
There are two out there but this is the one I beleive you want. All spares for the C3 should have C3 in their title
#R12-17C3 - R12C3 Front Stabilizer (R12-117C3)
http://www.rccarshop.co.uk/index.php...r12-117c3.html
Old 01-21-2014, 05:25 PM   #524
Yes, I think it is this.
Any test for use or not use anti roll bar/new or original type (R12-17)?
Old 01-21-2014, 09:02 PM   #525
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I'm mounting and truing some donuts for a friend with a C3. Is everyone using the Yok arbor, or is there an alternative for truing them?
AWD
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
