Old 07-20-2013, 01:31 AM   #466
CFR
CFR's Avatar
Originally Posted by Tiburon View Post
you guy's wouldn't happen to know how much each side has to be spaced in mm would you?
Aim for 6.2/6.3mm or under so you can add axle shims either side to get to class width of 172mm with Yokomo wheels/axle and to allow you to centre the axle.
Inner bearing races in the right picture
CFR is offline   Reply With Quote
Old 07-20-2013, 06:08 AM   #467
Thanks for the note. I thought the typical maximum width for 1/12 should 170mm and lower. Hence, shimming it to 172mm is not really legal ? correct me if I am wrong.
My blog: http://ongbenghui.blogspot.com
ongbenghui is offline   Reply With Quote
Old 07-20-2013, 08:07 AM   #468
CFR
CFR's Avatar
172mm max here in the UK
IFMAR
4.0.7 All cars must comply with the dimensional requirements. Maximum overall width of car
(EXLCUDING shell): 172mm
Old 07-20-2013, 03:01 PM   #469
haura415's Avatar
haura415 is offline   Reply With Quote
Old 07-20-2013, 05:06 PM   #470
Tiburon's Avatar
Thanks, helps a ton! hopefully the pipe cutter can cut pieces that small off.
Tiburon is offline   Reply With Quote
Old 07-20-2013, 09:02 PM   #471
Tiburon's Avatar
well tried 6.3mills and it was WAY wide, all I had to do is shim the left side with maybe 2.5 mills or so and its perfect- 172mm and from the very center of the chassis the wheels are within a .5mm difference. So it looks like the R12C has a even larger offset than the r12W.
Old 07-21-2013, 03:18 AM   #472
CFR
CFR's Avatar
Different diff side hubs from W to C
Probably changed them to allow for getting the width to 172 or under if needed
Old 07-21-2013, 06:23 AM   #473
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
The whole rear pod is shifted over to the right side of the chassis a bit, hence the shorter right diff hub and I think, longer left diff hub.
dontfeelcold is offline   Reply With Quote
Old 07-21-2013, 07:44 AM   #474
Default R12c left hub
Hi hi,
I took a measurement of the new R12C left hub (r12-24hlc) that served as a counter weight. The R12C left hub is 8g and the regular hub (r12-24hl2) is 4g
Old 07-22-2013, 09:59 AM   #475
CFR
CFR's Avatar
Cheers
Old 07-22-2013, 06:29 PM   #476
mike ivy's Avatar
Trader Rating: 50 (100%+)
Any One have a R12C ? Like to try one out.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 07-27-2013, 11:50 PM   #477
2013 New Model R12??
Damper tube front end rather than cross damper?
That front end looks awesome. Just needs damper tubes on the rear.
Team Serpent
Steve S is offline   Reply With Quote
Old 07-28-2013, 05:33 AM   #478
tim fry's Avatar
It does look awesome i wonder when it will be released?
tim fry is offline   Reply With Quote
Old 07-29-2013, 03:50 AM   #479
IgorR's Avatar
It usually comes in september.
The new kit R12 C3 has been announced today on Yokomo's web site.
http://www.teamyokomo.com/news/order...9_yr_r12c3.pdf
Yokomo BD7 16, YR-X12
IgorR is offline   Reply With Quote
Old 07-29-2013, 12:17 PM   #480
Looks Awsome.
How this works comperse crc/ xray chassi.
( i have no experiens of 1:12 racingb
Zooberg is offline   Reply With Quote
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
