Like Tree3Likes
Old 06-20-2013, 06:41 AM   #451
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by CFR View Post
Confused
apart from the price whats the difference on rc mushroom between the Yokomo R12 1/12 On-Road World Edition [item no: YOK-R12W] & Yokomo R12 1/12 Onroad Competition Kit [item no: YOK-YR-R12]?
Also, anyone know were to get the R12C rather than just a conversion kit?
http://www.redrc.net/2012/11/yokomo-...it/#more-60314
R12W is wide vers of R12
R12C is wide with crank steering
http://www.rc-race-and-drift-japan.c...oducts_id=4203
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-25-2013, 05:41 AM   #452
CFR
CFR's Avatar
Do Futaba do a suitable sized servo for the R12c?
I know there's the Sanwa SRG-HR & Spektrum A5040
This chassis with centre point steering
http://www.teamyokomo.eu/yokomo-euro...49-Yokomo-R12C
CFR is offline   Reply With Quote
Old 06-26-2013, 03:10 PM   #453
CFR
CFR's Avatar
some news on facebook saying Mobgums will have rims & foams to suit car September this year.
we will have the same wheel as Yokomo soon....just with Yokomo offset....
will be ready for September or so
Old 07-07-2013, 04:15 AM   #454
CFR
CFR's Avatar
Originally Posted by IgorR View Post
Mobgums and Torke tires are sold glue on R12 rims. They are almost the same price as Jaco.
I would go for this solution.
Who sells them?
Old 07-07-2013, 06:09 AM   #455
What is the track Wide in rear with Jaco and other tire?
Any one have R12C car for sale?
Options and spear parts?
Zooberg is offline   Reply With Quote
Old 07-07-2013, 05:53 PM   #456
These wheels have the center offset similar to the Yokomo wheels and are available here in the USA.
https://www.facebook.com/ProOneRc
You would still need to run the Pro One hubs but they are inexpensive, $15 pair.
sdunnmcp is offline   Reply With Quote
Old 07-09-2013, 05:36 AM   #457
CFR
CFR's Avatar
Were these parts just used to adjust the front springs on PRE R12C cars?
Old 07-09-2013, 06:05 AM   #458
He guys!
Yes, its true, MobGums will have a Yokomo offset 1/12 rear tyre from september on.
They will be the same than our current rear wheel as far as the design is concerned, just with the Yok offset.
You can check the news from time to time on www.speedtechrc.de
Later!
Markus Mobers-Speedtech RC Germany
Speedtech RC Germany-Home of MobGums tyres
--------12scale addicted---------
Mr. Blonde is offline   Reply With Quote
Old 07-09-2013, 08:43 AM   #459
CFR
CFR's Avatar
2013 New Model R12??
Damper tube front end rather than cross damper?
Old 07-09-2013, 01:33 PM   #460
AdrianM's Avatar
Probably Matsukura's new ride for the 2014 Worlds on asphalt.
Adrian Martinez
Old 07-17-2013, 09:08 AM   #461
Tiburon's Avatar
Hi, just built the car, does anyone how much I have to shim to use a Asso 12r5.1 axle? I have yokomo pre-mounts on their way, but I don't think they are going to me here on time for the next race.
Thanks.
Tiburon is offline   Reply With Quote
Old 07-18-2013, 09:25 AM   #462
Thanks.
If yours is R12C, I don't think AE axle will work. The offset is too much.
If yours is an old R12, then AE axle will fit nicely. I have tried it and I didn't use any shim.
My blog: http://ongbenghui.blogspot.com
ongbenghui is offline   Reply With Quote
Old 07-18-2013, 10:59 PM   #463
CFR
CFR's Avatar
AE axle or similar fits the R12C. Just needs shimming correctly.
Spacers are made from inner bearing race until I find some alloy spacers
1. R5 axle with 1 shim on diff end and two bearing inner races. Spacer was from BMI car.
2. R12C axle with shims either end
3. R12C with spacers and less shims
Yokomo R12-r5-axle.jpg   Yokomo R12-yok-axle-shims.jpg   Yokomo R12-yok-axle.jpg
Old 07-19-2013, 07:34 PM   #464
Tiburon's Avatar
cool, I actually found some aluminum stock that will slip over the axle as a shim, I can cut it at any length. you guy's wouldn't happen to know how much each side has to be spaced in mm would you? hopefully those tires show up tomorrow so I don't have to do this.
Thanks in advance.
Old 07-19-2013, 11:22 PM   #465
Tiburon's Avatar
is there anyone here with mounted/unmounted yokomo tires? I hate ordering overseas, my tires are stuck in customs.
by the way, in regards to the earlier posts, this is the R12W chassis not the new C-chassis.
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
