Old 11-13-2012, 05:21 PM   #421
Default World Conversation Kit
Hi,
Has anyone measure the new World Conversation Kit chassis differences already ?
ongbenghui is offline   Reply With Quote
Old 11-15-2012, 08:09 AM   #422
Originally Posted by ongbenghui View Post
Hi,
Centre shock position has changed and there's mounting holes for bellcrank and steering servo, other than that it looks very close to the previous chassis.
CPD Racing
chris_dono is offline   Reply With Quote
Old 11-15-2012, 03:49 PM   #423
Hi Chris, as compared with previous narrow or width chassis?
Old 11-15-2012, 10:13 PM   #424
B00t13g's Avatar
Why does volker run the associated instead of the Yokomo 12th?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 11-16-2012, 12:20 AM   #425
Compared with the one from the R12 kit (rather than the R12W)
CPD Racing
Old 11-19-2012, 09:25 PM   #426
Default World Conversion Kit
Okie, the front mount is wider. I think this is similar to the wide chassis. So, the original rear shock need to be moved to the front.
The rear is offset by ~2.5mm. Which I don't quite understand. See attached picture.
Old 11-20-2012, 04:30 AM   #427
There's a new offset axle in the conversion kit as well which lines up nicely
CPD Racing
Old 11-23-2012, 08:19 AM   #428
Here's the setup I used from last weekends national
http://cpdracing.co.uk/index.php?opt...d=58&Itemid=62
and a video of the final, I'm the car 5th on the grid (Red rear, white front)
+ YouTube Video
CPD Racing
Old 11-23-2012, 01:11 PM   #429
tim fry's Avatar
+ YouTube Video
How are you finding the Yoke Chris?
I assume the new axle allows the use of normal wheels?
tim fry is offline   Reply With Quote
Old 11-25-2012, 02:33 AM   #430
Hey Tim, very different from what I've run in the past, but seems to work quite well now
New axle is still for Yokomo offset wheels, I've used an IRS axle with a short (3mm offset) diff hub in order to run Ulti wheels/tyres. Jaco/Mobgum etc should also be fine, although the CRC wheels may end up being too wide.
CPD Racing
Old 12-06-2012, 05:31 PM   #431
haywood's Avatar
Trader Rating: 48 (100%+)
Default R12c
When is the new car available? Does someone have a link to where to buy rims and tires for the R12?
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-06-2012, 11:09 PM   #432
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
new car due around 14th of this month
drop me a msg and i will see what stock is like of yokomo med and softs
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 12-10-2012, 01:13 AM   #433
Updated with the setup (missed the A by 1 second) from Tamworth National
Video of the Final:
+ YouTube Video
CPD Racing
Old 12-10-2012, 01:16 AM   #434
Video of the Final:
+ YouTube Video
Bit scrappy in the Final and I had some bad luck, but still an improvement over the last round
CPD Racing
Old 04-02-2013, 12:30 PM   #435
noline's Avatar
Has anyone have any setups for US tracks? Also setup tips for the front end?
noline is offline   Reply With Quote
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 04:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 09:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 03:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 08:22 AM
SEO by vBSEO 3.5.0
