Like Tree3Likes
Old 08-30-2010, 08:40 AM   #211
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Quante View Post
Where is everyone getting their parts??
I'm yet to come accross the first shop that has the lower whishbones of the front suspension on stock...
Also, how are the yokomo tires doing?? Is there really nobody that knows?? Does Yokomo has a forum or anything that at least i can ask what compound/ shore I've bought before glueing them.
I had to use my second kit as spares!
race & drift
http://rcmarket.com.hk/
http://shopping.rcmodel.hk/
hotdognobun is offline   Reply With Quote
Old 08-30-2010, 10:54 AM   #212
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by eichkay View Post
Taking mine for its first run on wed night.. wanted to run it this weekend just gone but had a big off road trophy event to attend, defending my title from last year
Just finished the body this arvo
What foam tires do yo have on?
OVA is offline   Reply With Quote
Old 08-30-2010, 12:43 PM   #213
nutsisneat's Avatar
Stunning paintwork!
I don't see Yoke decals... factory driver for corally or CRC ??
nutsisneat is offline   Reply With Quote
Old 08-30-2010, 04:20 PM   #214
eichkay's Avatar
Yokomo super grips on the rear, with yokomo firms on the front, Ive got medium fronts to mount still as well as the medium hard rears which feel skickier and firmer than the super grips
Originally Posted by nutsisneat View Post
Stunning paintwork!
Kit doesn't come with decals , much upset about that...
2011 AARCMCC National Titles 2wd Stock #1 -- 2011 AARCMCC National Titles SC Truck #2 -- 2010 WA AARCMCC State Titles, SC Truck #1
Offroad Schumacher Catsx & Cougar SV, X-Factory SCX60 Onroad Yokomo R12
www.stanbridges.com.au -- www.upgrade-rc.com
eichkay is offline   Reply With Quote
Old 09-02-2010, 04:14 PM   #215
eichkay's Avatar
has anyone found the R12 setup sheets anywhere ? I did stumble across them somewhere but for the life of me cant find them anymore.
Old 09-02-2010, 07:07 PM   #216
I did something on purpose I guess: http://www.petitrc.com/reglages/yoko...YokomoR12.html
Arn0 is offline   Reply With Quote
Old 09-02-2010, 09:59 PM   #217
eichkay's Avatar
That's the first place I went ... But I've come across the setup sheets with allot of japaness written all over it form the drivers them selves from test sessions possibly.
Old 09-03-2010, 03:31 AM   #218
Recieved my R12 yesterday, i've put it together yesterday evening and here are my comments:
- Parts are of a good quality, chassis screwholes are nice and tight.
- The screws that were delivered to hold the rear "ballpiece" were too short, 6mm delivered while the manual specified 8mm -> I took the 8mm ones of the front bodyposts instead.
- Steel screws supplied for the front bodyposts, replaced by aluminum ones. My experience is that you'll rip the steel screws through the chassis plate in a hard impact. Alu screws just break and leave the chassis intact.
- front end fits together very nicely, works smooth and is almost play- free.
With the std springs, the front seems very stiff though, need to see how the car drives.
- I did notice a reasonal amount of play on the ballcup of the centerspring...
- 6mm(?) balls of the suspension feel/look cheap but seem to work fine
- rear suspension ball still has a small amount of play allthough the plastic piece is fully compressed...
- No height spacers supplied for the front end... I cant believe you have to adjust front ride height with the screws in there because you'll also change the spring rate then...
Since my vacation starts today and I'm out of the country, its gonna be at least 2 weeks before I can drive the car. Oh man.... couldnt have picked a worse moment
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 09-03-2010, 04:03 AM   #219
I try to get data and translate them into English when they aren't, sometime that's possible and some other not possible, especially with handwritten scanned sheet, I'm not fluent in Japanese.
But if you guys are successful to get setup, feel free to drop an-e-mail (address on setup sheet) and I'll add it to this page, that includes turning into pdf the setup sheet if needed.
Old 09-03-2010, 05:58 AM   #220
eichkay's Avatar
I was worried about the stiffness of the front, but that wasn't a issue when I had it on the track, just swapped in gold AE side springs and the car was hooked up, the yokomo tires were very impressive first time out I was running the super grip rears and firm fronts
Old 09-03-2010, 07:33 AM   #221
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
What to thread lock!!
2 things which came loose during my testing..
2.5m Screw which attaches the front wheel axle
rear centre shock became loose
This could well be due to the bump track I was racing on but was a good shake down shame about my racing.
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Last edited by Me_MrTyson; 09-03-2010 at 08:19 AM. Reason: Brain & keyboard not in sync
Me_MrTyson is offline   Reply With Quote
Old 09-03-2010, 08:02 AM   #222
Originally Posted by Me_MrTyson View Post
What the thread lock!!
I am checking the axle right now and...............YES! the left 2.5 is loose on mine too and my fronts shock is leaking? crap!
Old 09-06-2010, 09:13 PM   #223
Alex C's Avatar
Trader Rating: 50 (100%+)
Default Yoko R12 Ordered!!!
One would assume on a Carpet Track as to the above mentioned, although would you please confirm.
Further anyone with lessons learned or information as to car setup or build would be greatly appreciated.
Best Regards!!!
Alex
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 09-07-2010, 06:58 AM   #224
eichkay's Avatar
Originally Posted by Alex C View Post
One would assume on a Carpet Track as to the above mentioned, although would please confirm.
Best Regards!!!
Alex
I was on a old outdoor surface which would be low to medium grip asphalt. I hadn't mount the other tire types yet so was riming the super grips.. Which seemed ok outside, but ideally I think they are a harder compound indoor tire, Which I'll be doing some testing tomorrow hopefully. I've only just got all my front springs to suit the car so more testing ahead but out of the box the kit springs worked well.
Old 09-09-2010, 05:34 PM   #225
no questions just get it!!!!!
http://www.driftspeed.com/index.php?...ec6dcab4b54627
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 03:19 PM
Yokomo GT-4W with R12 rossi motor Boadazofa Australia For Sale/Trade 12 06-05-2009 08:50 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 02:29 PM
Yokomo GT-4??? bgotori Nitro On-Road 263 05-09-2002 07:22 AM
