Old 05-14-2004, 06:39 AM   #31
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
I'm going out to the track tonight and will try the ice cubes. From what you've told me, just lay them on the "underside" of the can. Is this so the condensation stays at the bottom or is there something else? I could probably set my car up at an angle and set one (shaped) cube into the sapce between the top or the can and the motor plate.... http://www.teamlosi.com/kits/detail/...030-05-450.jpg
Then I could wedge one under the motor (shaped cube) and the motor guard... http://www.teamlosi.com/kits/detail/...030-09-450.jpg BTW. on the second picture, on the very back of the motor guard, there is a "TL" I have that cut out so there's more room to put something. I also don't have stickers on my motor, so I should be fine.
mafiaracers is offline   Reply With Quote
Brushless motor heat sinks w/fan... P2 Electric On-Road 1 05-08-2008 04:25 AM
When and how to pre heat a motor..... Mpowerz Nitro Off-Road 10 01-14-2008 08:42 PM
Motor Heat Sinks - Good or Bad? Eggyolkeo Electric On-Road 2 08-14-2007 02:09 AM
Motor Heat Sink Question Drift_Buggy Electric On-Road 1 02-05-2007 12:35 AM
Stock Motor Gearing/Heat LOSI123 Electric On-Road 35 01-12-2007 10:01 PM
SEO by vBSEO 3.5.0
