Old 05-12-2004, 11:00 PM   #1
Mr-s413bt's Avatar
Default power cap question
Hey Guys.
Ok i own both a GM V12 and a Novak GT7 speed controls.
Now i think that the power cap on the GT7 is damaged and want to know if i used the one from the GMv12 just to test and make sure that the power cap is damaged, would this be ok???
I am not going to drive the car, but i want to test it with a motor hooked up on the bench. The reason i ask is cos my GT7 has been causing major interference problems and i am hoping that it is only the power cap. I would buy one, but no one here in Adelaide sells them
Thanks Guys.
Mr-s413bt is offline   Reply With Quote
Old 05-13-2004, 04:21 AM   #2
Default Re: power cap question
It is ok to mix capacitors. You could go the nearest Radio Shack, Tandy or whatever it's called where you live, and buy any 10-16v (10 is better if available) 1.000-10.000 uf (higher is better) capacitor as substitute, just make sure it has low ESR although most new capacitors do.
Do a search on power capacitor here on RC-Tech and read the 4 or 5 posts on capacitors that have been going for the last couple of months.
andsetinn is offline   Reply With Quote
GTB power cap question Perry Radio and Electronics 0 05-01-2008 11:24 PM
Power supply question Racingfreak6 Electric On-Road 3 12-21-2006 12:54 PM
Question about brushless power in a ST? NotEZ2Beat Electric Off-Road 2 09-26-2006 02:02 PM
Power Inverter question Core Creations Electric On-Road 9 04-24-2006 01:09 AM
Power Supply/GFX Question tc3blue Electric On-Road 8 10-04-2005 12:11 AM
SEO by vBSEO 3.5.0
