Spec-R Gear diff review
#436
MOD. XRAY NT1 Rear Gear Diff. bester than 2 !
but little expensive than this 2 brand name .
#437
Hi,
has anyone run both and have an opinion which one is better?
I know there is a weight difference, even the different diameter makes a difference when it comes to rotating mass, but are there construction differences, beside the obvious size difference, or durability comparisons?
Thanks.
Thanks.
i can't get hold of spec-r gear diff for my 416X at the moment cos it's out of stock. but my LHS just rec'd shipment of u-pro gear diff for photon. my question, will this fit 416X? sorry if it's been covered before. many thanks
#438
when reopening the differential silicone comes off well without leaving a trace
instead for leaking near shafts we have to wait the new o-ring from Spec-R, at the IFMAR World Championship they provided the TRF Team with a new transparent o-ring
#439
#440
You'll never get rid of the leaking completely, just like shocks, they will eventually need rebuilding as well.
Sounds like the new O-ring will help, and perhaps a thin, round, very large O-ring closer to the outside, like a 1/8 gear diff might help a lot more than the cardboard gasket that is currently used.
Skiddins
Skiddins
#441
I thought this was the new o ring ?
#442
I've managed to stop leak around shaft area only leak comes around pulley I ll try that tip to stop that thanx for the info...
P.s muchmore slime over o rings stopped all leak
#443
I've just ordered my spec-r gear diff for my TRF416X, but i've been reading a lot about diff oils.
I just don't know were to find some of these diff oils and i even don't know what would be a thicker oil.
The higher the number or lower the number?
I know that tamiya has diff oils of 5000, 10000 and 30000 but wich one is a thicker oil?
Can someone help me out with this mather?
Kind regards
Kind regards
#444
Kind regards
Kind regards
#446
How does a thicker oil (higher CST) react compaired to thinner oil? What is a good starting weight for 17.5? (1000 CST?)
#447
#448
#450
