Old 05-24-2010, 12:38 PM   #1
Default Which Speedo?
Hi folks,
I am considering buying a new ESC and wondered what your thoughts are with which one i should get.
I am racing pro stock (10.5T) and want the 'advanced timing' feature.
Can anybody tell me which they would go for out of LRP SXX, Speed Passion GT.20, Muchmore Fleta, Tekin RS, Nosram Pearl or any others you guys suggest?
adz2383 is offline   Reply With Quote
Old 11-11-2010, 03:59 AM   #2
blade072's Avatar
Trader Rating: 98 (100%+)
xtreme stock esc from hobbywing is what i have been using for 10.5 and is more than enough for what you want.....
i also recommend either the sp gt 2.0 or mm fleta 3.0 as they are the same esc...which i will be using for mod....
and the sp and hw software work on each other.....
im using hw sofware on the xtreme and will use sp on the fleta...and they are cheap as
also have used a tekin rs
as far as size the tekin is the smallest followed by the xtreme and the sp and fleta are a bit bigger
hope this helps....
David Randall
blade072 is offline   Reply With Quote
Advanced Electronics Black Diamond ESC prodriver Electric On-Road 1085 01-19-2016 01:22 PM
Ko BMC Speedo Green Speed Electric On-Road 1289 11-05-2015 06:06 PM
CRC / Advanced Electronics Black Diamond Speedo - Ban due to cost?? or8ital Electric On-Road 131 11-30-2009 07:47 PM
LRP SPX Brushless Speedo BJ Electric On-Road 46 05-03-2009 10:22 PM
SEO by vBSEO 3.5.0
