Old 01-19-2012, 11:30 AM   #31
When we were using silver can motors on our tight indoor carpet track, a FDR of 7-7.5 was worked best. Again this was a tight track with high traction.
ebruce is offline   Reply With Quote
Old 02-11-2012, 12:32 PM   #32
its nice to see other ppl running this car how do you guys find the durability of it? what gear ratios for silver cans & 17.5 do you guys run? has any one tried the exotek chassis? does any one have a setup & setup sheet for this car? sorry to bing a older thread back
urban is offline   Reply With Quote
Old 02-20-2012, 02:27 AM   #33
Originally Posted by JKL1031 View Post
RPM ball cups all around and put another spring under the left servo saver.
Can you please give me a clue about this spring? What type? is there any specific spring i can use?
Thanx in advance.
crusadores is offline   Reply With Quote
Old 02-20-2012, 04:42 AM   #34
Cool My 17.5T setup
Hello there.
I have been racing a Sprint 2 for 1 year now on asphalt (frt.gr). I am using soft (green) front and purple(medium) back springs with 35wt on both.
For my 17.5T Nosram i go for:
IDR:2,13
Spur:72
Pinion:36
FDR:4.26 (balanced acceleration and decent speed)
The HW Xerun is not extremely pushed, so temps are well within limits.
You can go up/down 4 pinion teeth if you wish to adapt your Sprint to different tracks.
Old 02-20-2012, 12:20 PM   #35
FauxMako's Avatar
Thanx in advance.
Put 2 of the normal spring in there.
Or really crank down on the tension ring and lock tight it.
Either way you have to tighten up that area or the steering will have too much play in it.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 02-23-2012, 05:25 PM   #36
JKL1031's Avatar
yes just any spring u can find that can fit under there.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 02-24-2012, 08:17 AM   #37
vti-chris's Avatar
Anyone knows what one-way fits this car?
I can't find anything for the sprint 2...
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 02-24-2012, 08:54 AM   #38
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
I am thinking about this Chassis for RCGT for my local club. Besides the RPM cups, any major changes out of the box that really need to be addressed?
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 02-24-2012, 10:32 AM   #39
esckalayd's Avatar
My brother bought a Sprint 2 sport with the camaro body to learn racing with and we have had a problem with this cars ESC for some reason. We are using the stock motor, stock ESC and 2s 5000mah LiPo batteries. We placed the ESC in LiPo mode like the manual stated and the last two races we have blown the ESCs . HPI replaced the 1st one for free b/c we just bought the car and we thought something was wrong the the ESC but after the second one, i am thinking something may be wrong with our setup. Any ideas?
Anthony Schimizzi AKA ~The Rookie~
| Serpent America - DeSoto Racing - Murnan Modified |
Bodies by Paintin Pete
esckalayd is offline   Reply With Quote
Old 02-24-2012, 10:46 AM   #40
esckalayd
the hpi esc sc15 are junk
pick up a new esc and rpm ball caps and your good to go
Old 02-25-2012, 11:23 PM   #41
JKL1031's Avatar
cut around the rear diff if you are racing around rocks n debris.
China Lipos
China Speedos
China Chargers
Old 02-28-2012, 10:49 AM   #42
azeroth's Avatar
Trader Rating: 20 (100%+)
setting one up now for VTA fitting Lipo into with out rubbing the belt is being addressed will post up some pics soon
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 04-24-2012, 07:41 PM   #43
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
bump
John Higgins
liljohn1064 is offline   Reply With Quote
Old 05-15-2012, 03:09 PM   #44
Default belt tensioner
I removed the tensioner and drove a bolt through the lower mounting hole for the side plate, just below the belt. I then attached two small bearings with a lock nut. This stops the belt from rubbing the battery pack and seems to provide enough tension.
I picked up some RPM cups but I must have got the wrong ones. They are too long and a bit too bulky for the wheels.
Will the Associated cups work okay?
nubie-wan is offline   Reply With Quote
Old 05-15-2012, 04:37 PM   #45
I took the left side steering belcrank apart and made a spacer to go between the two bearings since the inner races are not supported. I also took a small punch to the pin to flare it some so the bearings would fit tighter on the shaft. Then carefully CA's the bearing to the shaft. Now it is nice and tight. On the other side, I found a nylon washer to use under the servo saver so the thumb-wheel can't go so loose it touches the chassis, and used Lock-Tite on it too. Don't just "Crank it all the way up".... I did and knocked teeth off the servo, it has to still have some "give"
I would like to know what settings anyone is using, I'm trying to run VTA with mine till I find something better. Any help?
YellowStangDuan is offline   Reply With Quote
HPI Sprint 2 Flux any good? Cheezburger Electric On-Road 25 05-28-2013 03:23 PM
Spliff's HPI Sprint 2 Drift Sport spliffnwesson Electric On-Road 27 09-18-2010 11:34 PM
hpi sprint 2 bulldog79 Electric On-Road 53 04-29-2010 02:17 PM
HPI Sprint 2 drift, novak 13.5, many extras davidg86 R/C Items: For Sale/Trade 31 05-18-2009 07:57 PM
SEO by vBSEO 3.5.0
