Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-19-2001, 06:20 PM   #1
RcTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Default Losi XXX-S
I thought it would be nice to get a Losi thread going on here like what was previously on RCTouring.
Quick Q? - Steering felt a bit sloppy to me. I'm running the stock ballcups. Should i ditch those for RPM?
Troy
#2 RCTech Member
RCDriver Magazine
TSR6 is offline   Reply With Quote
Old 08-19-2001, 06:23 PM   #2
AE_Racer's Avatar
Send a message via AIM to AE_Racer
Well, once I added RPM ballcups to my Atlas it took some out, but the Atlas is the god of "slop". Sloppiest car i've ever seen. It works for me though. Just need to add some shims in a few places and it'll fix er up
AE_Racer is offline   Reply With Quote
Old 08-19-2001, 06:25 PM   #3
Suspended
What happened to RCTOURING???
Anyway, I have thought the steering is a bit sloppy as well. I am planning on switching to RPM and that should clear up that issue.
For the push, you might try messing with the droop settings. I was surprised at how much they affected the handling of the car.
MASTER XXX-S is offline   Reply With Quote
Old 08-19-2001, 06:28 PM   #4
RcTech Member #2
TSR6's Avatar
Well, i would rather have it tight than loose. It is "ok" the way it is, but i wouldnt mind a more neutral setting.
RCTouring was Shutdown due to unknown reasons. I still havent been able to contact Dan. It was a big loss.
Troy
#2 RCTech Member
RCDriver Magazine
Old 08-19-2001, 07:25 PM   #5
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Cool
I have a XXX, and I have about 3 degrees of slop in it's steering, the RPM ballcups didn't help. I think if you switched to BB's in the steering it may clean up the problem...
Speedo
Speedo is offline   Reply With Quote
Old 08-19-2001, 07:27 PM   #6
Suspended
One other suggestion for XXX-S owners, take out all of the bearings and remove the shields and clean out the old grease then replace with Royal Oil or Dura-Lube. Your drive train will be as free as a well broken in TC3.
Did this to mine and she rolls clear accross a large kitchen floor with just a tap.
Has anyone picked up any graphite parts? I am curious where this stuff is avaiable for mail order.
Old 08-19-2001, 07:30 PM   #7
Moderator
Speedo's Avatar
Cool
I did that to my XXX and it means you have to constanly check it for maintanance. I spend two hours cleaning my bearings in my XXX buggy every two weeks.
Old 08-19-2001, 07:33 PM   #8
Suspended
If you are a serious racer, you should be checking at least that often as is.
Just gives me a better reason to tear the car down to make sure there isn't anything broke or worn.
Old 08-19-2001, 07:35 PM   #9
RcTech Member #2
TSR6's Avatar
I was planning on getting the Bearings. 5 x 8's, i just haven't gotten them yet. It always slips my mind on my way home from work. We get so busy sometimes i can't buy my own stuff
Troy
#2 RCTech Member
RCDriver Magazine
Old 08-19-2001, 07:36 PM   #10
Suspended
Someone had mentioned that the bearings from a MR4TC's steering will work but I tried and they don't. Just a heads up.
Old 08-19-2001, 07:43 PM   #11
RcTech Member #2
TSR6's Avatar
Yeah, I was just planning on getting some cheap 5 x 8's ( if that is the correct size ) I'm taking my car to work on Tues anyways, so i will just find out what fits. I think it is 5 x 8 though.
Troy
#2 RCTech Member
RCDriver Magazine
Old 08-19-2001, 07:48 PM   #12
Moderator
Speedo's Avatar
Try www.rcboyz.com for bearings, great prices and free shipping too
Old 08-19-2001, 07:50 PM   #13
RcTech Member #2
TSR6's Avatar
Well, I work at my LHS. I think i will get them there
We stock full Boca & Dynamite bearings, so i will just get those
Troy
#2 RCTech Member
RCDriver Magazine
Old 08-19-2001, 07:53 PM   #14
Moderator
Speedo's Avatar
Cool
I like boca, but they are a little too pricey for me
Old 08-19-2001, 07:56 PM   #15
RcTech Member #2
TSR6's Avatar
Boca is very nice. They have different levels of bearings. The cheap " Sportsman" bearings, all the way up to the Pro bearings. They also have bearing sets fore most popular cars.
Remember, you get what you pay for in most cases. That is mostly true with the bearings
Troy
#2 RCTech Member
RCDriver Magazine
Forum Jump
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
