Old 08-18-2011, 11:57 AM   #14311
Trader Rating: 24 (100%+)
Well, at least you'll have a chance to own a TMF adaptor and lots more......all my xxxs stuff is going up for sale. I'm aiming to open my own business so it's time to concentrate only on what I need to keep racing.
Evoracer is offline   Reply With Quote
Old 08-23-2011, 06:13 AM   #14312
J SiN's Avatar
Have found a bunch of XXXS G parts
2 x Graphite Rear Arms
1 x Graphite Front Arm
1 x Graphite Front Shock Tower
1 X Graphite Rear Shock Tower
3 x Graphite 0Deg Caster Blocks
1 x Graphite 2Deg Left Caster Block
1 x Graphite 4Deg Right Caster Block
1 x Graphite 4Deg Left Caster Block
1 x Graphite Diff Cover (does have a small crack near the mounting point but still useable)
2 x Graphite Chassis Inserts
2 x Graphite 0Deg Offset Rear Hubs
4 x Graphite 0Deg Rear Hubs
1 x Graphite 1/2Deg Left Hub
1 x Graphite 1/2Deg Right Hub
10 x Graphite Steering Hubs
1 x Blue Belt
2 X Diff Pulleys (think 1 is an under drive pulley)
5 x Graphite Hinge Pin Holds
4 x Alloy Hinge Pin Shims
2 x Long Hinge Pin Holders 1 Front 1 Rear
6 x Sway Bars (different sizes)
Please PM me an offer for this lot of parts
T.O.P. Racing Australia
R.A.B Hobbies
AVID Bearings
J SiN is offline   Reply With Quote
Old 08-26-2011, 12:58 AM   #14313
Default chassis
I am looking to buy 2 maybe 3 graphite plus chassis. I know some members on here had some, bur not sure if they still do. I have searched various online places, but no luck. Iím looking for new or good condition (no stripped holes, cracked chassis). Also on a side note, I have an APO address so shipping is just like in the states using USPS.
Thanks,
Patrick
XCELL is offline   Reply With Quote
Old 08-28-2011, 12:20 PM   #14314
Default chassis
Found a new one just waiting to hear back from them. Still looking for another one if someone is willing to sell it.
Thank you,
Patrick
Old 09-18-2011, 07:02 PM   #14315
Trader Rating: 118 (100%+)
Default XXXS Speed car
I figured out my problem. The aluminum pinion had a small burr on it. Replaced the pinion with a new 45tooth and 86 spur. It ran great with no problem. Got 96mph out of it on 3s w/ a Castle 7700. Didnt want to push it to the limit.
I came across a huge lot of parts, graphite chassis roller and plastic car roller. Right now I have 2 speed cars, a 68 VTA Camaro, a drift car and a regular on road race car. I'm in the process of building a 65 Shelby GT350. Might hang on to the regular chasiss for parts and get rid of most of the graphite chassis. Thanks for your help.
cdlowe30907 is offline   Reply With Quote
Old 12-07-2011, 10:54 AM   #14316
racer53's Avatar
Gentlemen,
I need a set of replacement shocks for my xxx-s and would like to get something with threaded shock bodies and that have a good seal...
I didn't find any original shocks from losi during my search, so I guess i'll have to get a differant brand...
Anyone have a good recomendation...
Thanks for your time,
Racer53
"Whatever can go wrong, will go wrong"...Murphy's Law...Murphy was an optimist.
/ FT RC10B4 / FT RC10T4 / Driven just about everything else /
/ Mike's Hobby Shop...Carrolton Texas /
"All short course drivers aren't hackers,but all hackers are short course drivers"
racer53 is offline   Reply With Quote
Old 12-07-2011, 11:30 AM   #14317
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by racer53 View Post
Gentlemen,
Racer53
I saw three complete sets and a zillion springs sell on ebay for $35 the other day. If you can't wait for them, I'd buy these:
http://www.ebay.com/itm/losi-jrx-s-o...f#ht_874wt_954
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 12-07-2011, 11:37 AM   #14318
racer53's Avatar
Edit:
Never mind I just picked up a set from Ebay
Thanks,
Racer53
Old 12-27-2011, 11:21 PM   #14319
eds24's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to eds24 Send a message via Yahoo to eds24
Hey guys,
I'm working on a custom touring car.. and I'm in need of the belt length of the xxx-s.. I'm looking for the length of the blue or yellow xxx-s belt. I know the xxx-4 yellow belt is 259T.. but I need the length of the xxx-s belt so see if it will work on my project before I buy one..
On the yellow belt I have seen pictures of markings on the belt that show 200-0230. But I don't know if this is really an indication of how many teeth their are on the belt. 230T makes sense..but if anyone could confirm this that would be great..
eds24 is offline   Reply With Quote
Old 12-27-2011, 11:44 PM   #14320
CraigMBA's Avatar
I bought a yellow belt thinking it was for a XXX-s as a spare (out of package) but it is 259T. I have a black belt in the car, and I have an extra black belt coming via ebay so I'll check it when it gets here.
Old 12-27-2011, 11:56 PM   #14321
eds24's Avatar
After a bit of looking I found that the black belt is 777mm long... so divide that by 3.. and I got that the black belt is 259T as well..
Sounds like the Yellow xxx-s g+ belt and the stock blue xxx-s belts are shorter than the black belt.. so those are the belts I'm needing dimensions for.. thanks though.
Old 12-28-2011, 04:18 PM   #14322
Be careful, the newer yellow belt may actually be for the XXX-4 buggy. It is longer than the original xxxs yellow belt. Both the black belt and the xxx4 belt require the longer belt tensioner with the black delrin roller. The xxx4 belt is now the easiest of the bunch to find.
Old 01-02-2012, 07:42 PM   #14323
CraigMBA's Avatar
The black belt is exactly the same length as the 259t yellow belt. I now have parts coming out my ears on this car.
Old 02-14-2012, 06:39 PM   #14324
Dustin's Avatar
Trader Rating: 113 (100%+)
Looking for a spur gear adapter if anyone has one they would part with... I have a bunch of other parts for this car if anyone needs anything, most are new in package....
Dustin Thompson
HB Racing
AKA Racing
Dustin is offline   Reply With Quote
Old 02-14-2012, 06:57 PM   #14325
nf_ekt's Avatar
Search the FS thread, with some key words related to this, I did this and found some old threads... there was one guy I pm'd and he got back to me, but I never bought it from him, ended up scoring two NIP adapters elsewhere. I may have deleted the pm's but I would look on your own, as I say there were some people that had them. Since getting one I have been happily running the car into oblivion ....
nf_ekt is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
