Old 11-19-2009, 08:20 PM   #14221
Laz
Originally Posted by Evoracer View Post
Originally Posted by Laz View Post
Hey guys, I was wondering what gearing you recommend for a brushless EzRun 60A ESC/6000kV motor combo. I looked around, but nothing I found was anything specific. I have both the stock 48P and the 128T 64P spurs and barely any pinions so anything goes I'm thinking of using it for drifting with abs "tires" and asphalt bashing/racing for now if that helps.
Drifting has different requirements than racing. You WANT the car to have a lot of torque so you're not worried about speed. Gearing for drifting could be around the 8.0 to 1 range depending on the track size. The shorter the track could use around 8.0/1. A longer track maybe go into the 7.5 range. For bashing with rubber tires you'll want to go down around 5.0 to 1 on a short track and 3.5 to 4.0 on longer. Really depends alot on track size. Try those ranges but CHECK MOTOR TEMPERATURE after about 3-5 minutes. For 17.5 BL racing I use the 108 64p spur with a 41t pinion to get around 5.0 ratio. If you dont know how to figure gear ratios heres the math for a xxxs. Spur gear tooth number divided by pinion tooth number X internal car gear ratio ( 1.83 for the xxxs) = final drive ratio. Hope that helps.
That was really helpful, although the post doesn't show up in the thread correctly. The only thing is that to get such a low ratio, I would need something close to a 50 tooth pinion. I'm not sure how I'd go about this since I'm pretty sure a 50t won't fit, and I don't know of any spurs other than the stock and the 108 and 128. Are there such smaller spurs I can use?
Last edited by Laz; 11-19-2009 at 10:49 PM. Reason: Just in case the reply to my first post never shows up right.
Laz is offline   Reply With Quote
Old 11-19-2009, 08:57 PM   #14222
Company Representative
SweepRacingUSA's Avatar
50t fits with a 108t spur fine, I think a 52t is limit.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 11-19-2009, 09:48 PM   #14223
nikkon's Avatar
Trader Rating: 245 (100%+)
Send a message via AIM to nikkon
Anyone know where i can get or have a part number for shock rebuild kit? need to redo mine since they are leaking.Thanks
nikkon is offline   Reply With Quote
Old 11-19-2009, 10:57 PM   #14224
Laz
I don't think you necessarily need a "shock rebuild kit" even though the parts that come with Losi A-5015 are essentially that, minus shafts, piston, and e-clips. I would think that'll do though since it is the screw on cartridge and o-rings. That might be all you need, anyone correct me if I'm wrong, I've never needed to do this yet. Found as "LOSA5015" in most places as the part number, by the way.
Old 11-20-2009, 08:53 AM   #14225
Micro-E's Avatar
When mine start to leak, I just tear'em down, clean things real well and re-assemble with Associated 'Green Slime' coating the o-rings. Fill with quality silicone shock oil and you should not have to mess with them until you want to change viscosity for tuning.
- Erik
Micro-E is offline   Reply With Quote
Old 11-20-2009, 08:12 PM   #14226
small=breakable's Avatar
Trader Rating: 21 (100%+)
Default Motor Sparks?
Alright. I took my xxx-s out for the first time. It ran great. However I did notice that whenever I ran the brushed motor in reverse, sparks would fly within the motor. There is no noticeable power loss but is there a problem here? Thanks.
small=breakable is offline   Reply With Quote
Old 11-20-2009, 08:16 PM   #14227
mtbboy's Avatar
No problem.
The brushes will "seat " in one direction so those little sparks are caused by the brush running on the opposite side to which it has set in.
Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 12-01-2009, 03:03 PM   #14228
Right now I am putting on the yellow (extra flex) belt and spool pads in the front. Let me say this, the car is a HUGE PAIN to work on as far as I can see. Any suggestions as how to seperate the front diff? I need the two driveshaft cups to seperate. I have been trying to unscrew it them (a screw goes through both and the gear) but that has been unsuccesful so far.
Old 12-01-2009, 03:17 PM   #14229
Hey Small, to take the diffs apart you need a flat head screw driver ( if it's still a screw and T nut set up) and anything that will fit into the out drive slot on the other side to hold it from moving, then just unscrew it. if it possibly stripped out the T nut then thats going to take some creative/ forcefull techniques to stop the nut from turning.
good luck with your car, and please re post if that doesnt help.
rc_racer1 is offline   Reply With Quote
Old 12-01-2009, 05:12 PM   #14230
mtbboy's Avatar
Here you go guys...
http://www.losi.com/ProdInfo/Files/losa0251-manual.pdf
Print it off.
Read it.
Good to go.
Dave.
Old 12-01-2009, 08:11 PM   #14231
Thanks and the solution to losening the nut was to simply take the diff out of the chassis then loosen. I am about done rebuilding. I just don't enjoy all the parts that must be taken off. This was my first time trying to really wrench on the car. Next time it should be a sinch.
Old 12-02-2009, 03:48 PM   #14232
Hey Small, once you get familiar with the car you'll love how simple it is to work on, and how adjustable the car is, there is another forum the for XXXS and between the 2 you'll have more than enough info to make your car kill just about anything you putt it up against.
Old 12-07-2009, 07:40 PM   #14233
Which forum are you talking about?
Old 12-08-2009, 08:24 AM   #14234
Maddafunker's Avatar
hgcolors: Salamat chief! Kelan ko kunin sayo?
emer: Thanks Prez. Lapit na rin ako mag-EBuggy. Busy lang mag-hopup ng ibang sasakyan.
Maddafunker is offline   Reply With Quote
Old 12-08-2009, 03:31 PM   #14235
What language is this?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
