Old 11-16-2009, 03:31 PM   #14206
paraletic's Avatar
IMO Id be doin a quick tear down of the car and doing a quick check and clean of the bearings and diffs etc
checking belt tension and setting up the toe camber etc
it should roll alot more than how you described (not sure if thats with mtor/pinion installed etc) but yea best bet is check ya bearings nothin worse than running ot with ditry bearings etc an killing them an ya new motor.
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 11-16-2009, 03:33 PM   #14207
Trader Rating: 24 (100%+)
The 1 pic of the rear tire looks to be right but the fronts are wrong direction. Not a big deal though. I doubt you'll be racing with those tires.
Agree with Paraletic....probably shouldnt run car yet without a bit of an inspection. Also...if you stick that BL motor in there I can guarantee the gear ratio wont be right and might harm the motor.
Evoracer is offline   Reply With Quote
Old 11-16-2009, 03:34 PM   #14208
small=breakable's Avatar
Trader Rating: 21 (100%+)
Alright the belts are both blue (kinda green). They are pretty stiff it seems.
EDIT: and the motor was in place when I tested how easily it coasted.
small=breakable is offline   Reply With Quote
Old 11-16-2009, 03:39 PM   #14209
paraletic's Avatar
try removin the motor an see how it rolls
but yea id do a quick clean etc of the car then ul know atleast how too work on it and that its all clean an ready 2 use
ASSociated RC12L4
Old 11-16-2009, 03:40 PM   #14210
Belt(s) ? There's only 1 belt on the car. Is it blue or yellow? Sounds like yellow but probably old. Whatcha think?
Old 11-16-2009, 03:45 PM   #14211
Yes my fault, it looked like two belts and it really does look blue/green. I will do a clean up and get back with you guys. Thanks so much for all of your help so far. I am sure there is a lot more work ahead.
All the wheels are facing the same direction. The arrows on the tires are all facing the back when looking from the top. I think I will switch them. Also, Is there something I can do to fit a lipo? The battery holster is made for nimh/nicd.
Old 11-16-2009, 03:47 PM   #14212
paraletic's Avatar
sounds like the original kit belt if its blue/green
try grabbing a yellow belt for it or get the black long belt conversion for it that will free it up more too.
ASSociated RC12L4
Old 11-16-2009, 03:49 PM   #14213
The tires may be mounted incorrectly. Just about any size 2c lipo should fit. notice the nubs on the battery tray and the one on the battery strap ?? They have to be ground off. Very easy.
Old 11-17-2009, 07:49 PM   #14214
Well I just ordered a SPC 2s battery
http://www.specpointbatteries.com/in...p?productID=59
1. However, it is only rated 20c. Do you suppose it will be okay? An employee at my LHS says I should have purchased one with more c's so that it does not overheat.
2. I somehow lost one of the bearings of the car while cleaning them. I am looking to replace them with no maintenance sheilded bearings that won't be to pricey. Any suggestions?
3. My vxl motor shaft is so long that it hangs over the belt (I think it is barely touching). I see this as a problem. I will be buying a new motor in the future as I will be using the VXL in my rustler. Are any other motor shafts this long?
Old 11-18-2009, 06:22 AM   #14215
Not a bad price on the batt. As an option take a look at www.hobbycity.com. Great prices on batts and other stuff.
Bearings....check ebay. There's some excellent rubber shielded ones available for cheap. Some are in the U.S.
Not quite understanding about the motor shaft. Are you sure you have the motor mount installed correctly? Which part of the belt is it almost touching...the upper part or the lower part closest to the bottom of the car? The length of the shaft shouldn't be a problem. Can't imagine it's so long that it reaches the other side of the tunnel. I think the position of the motor is the problem.
Old 11-18-2009, 01:15 PM   #14216
paraletic's Avatar
I think he mentioned it's a mamba max motor
I've had same prob with all my mambas an xxxs an xxx4 cars the pinion shaft just touched the belt
I just took too it with a dremel an drum sanding wheel
don't need too remove much an jus make sure u don't leave a sharp edge after
ASSociated RC12L4
Old 11-18-2009, 02:01 PM   #14217
I would have purchased a flightmax battery for a great price at hobby city but they have been out of stock for a while.
The motor is actually my vxl (traxxas brushless motor). I had to return the mamba max, it didn't work correctly. I will be buying a new motor for this car because the vxl goes in my rustler. The shaft is barely rubbing the top of the botom belt where there are no teeth so it can probably run but not as efficient as possible.
My hobbyshop mainly stocks mini and micro losi parts, not 1/10 scale losi parts so I had to order the new yellow belts and some spool pads through them.
I will search for the correct size of bearings but if you guys know the size give me a heads up.
Thanks.
Old 11-18-2009, 03:01 PM   #14218
Company Representative
SweepRacingUSA's Avatar
look here to find size or the part #
http://www.losi.com/ProdInfo/Files/l...-explosion.pdf
Thanks.
SweepRacingUSA is offline   Reply With Quote
Old 11-19-2009, 08:15 AM   #14219
Laz
Default Gearing?
Hey guys, I was wondering what gearing you recommend for a brushless EzRun 60A ESC/6000kV motor combo. I looked around, but nothing I found was anything specific. I have both the stock 48P and the 128T 64P spurs and barely any pinions so anything goes I'm thinking of using it for drifting with abs "tires" and asphalt bashing/racing for now if that helps.
Laz is offline   Reply With Quote
Old 11-19-2009, 09:27 AM   #14220
post edited
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
