Old 04-30-2007, 03:39 PM   #13876
gearhead13's Avatar
Originally Posted by minnesh
ok going to give the 540 a rest a bit ,got a 27t older motor to try out
have put a 28 pinion with 86 spur, still to try it out
what u guys think
maybe i should try a 26 pinion...or should i go smaller
whats the recommended roll out for this motor
thanks minnesh
go here:
http://www.gearchart.com/index.cfm?f...n=chart.create
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
gearhead13 is offline   Reply With Quote
Old 04-30-2007, 09:18 PM   #13877
Send a message via AIM to sloshedmr_bones Send a message via Yahoo to sloshedmr_bones
can you guys post some pix of your rides with mamba max systems. I am trying to figure out how to mount all my stuff in the chassis because i dont like how it mounts stock. Thanx
sloshedmr_bones is offline   Reply With Quote
Old 05-01-2007, 06:40 AM   #13878
Default Help
I new to the forum and had a quick question from the expert before I tear my car down to find the problem. I have a XXXS with the novak brushless system. All was find until got home yesterday slapped a battery pack and tried to run the car but a horrible grinding sounds started. Low speed and high speed(sounds louder). sounds seems to be coming from the rear end. I am not sure what the deal is and some advice before I start tearing everthing. Where should I start.
thanks
great forum
ragaxxxs is offline   Reply With Quote
Old 05-01-2007, 09:22 AM   #13879
sloshedmr_bones
Here are some pictures of my Losi XXX-S with my recent Mamba max 7700 system.
Great stuff ! 20 runs and no problem (no temp shutdown). I'm pretty impressed with the handling of the car.
Have fun with yours.
Cheers.
Team Losi XXX-S G+ (Mamba Max 7700)
Team Losi XXX-4 G+ (Nosram Matrix 2005 & Storm 3 stars)
Team Xray T1 FK '05 (Nosram Matrix ISTC & Storm 3.5)
Team Orion Avionics Advantage / Team Orion Li-po 3200 Carbon Edition (5) / Futaba 3PK
Blin is offline   Reply With Quote
Old 05-01-2007, 03:34 PM   #13880
Thanx Blin. Glad someone can help me on here. I like the way you have yours done it very clean. You wouldn't happen to know about hop ups for the car would you? I want to run purple on the car but no one besides hpi makes anything. I was planning on purple hpi cvds, turnbuckles, wheel nuts, and a purple aluminum battery strap that is off set. One other thing do you have a problem with your motor hitting the ground when you drive? Thanx again.
Old 05-01-2007, 05:36 PM   #13881
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
sloshedmr_bones: On my XXX-S my motor scraped against the ground, when there was a bump, or when i went over the orange dots my local track uses. Doesnt hurt it. Does it because it sits so low.
Blin: One thing I'd suggest to you. Change the fan that you have on there. The E3 racing does nothing. Not powerful enough to run. The heatsinks that they make are nice, just get a different fan, more powerful.
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 05-02-2007, 12:05 AM   #13882
TL XXX-S Racer,
Thanks for the piece of advice. I'll try another fan.
Sloshedmr bones,
Sorry but I have no idea about the hop-ups you're looking for.
I protect the motor because I run mostly on a parking with some bumps and little stones. The motor is a 550 (not a 540) size (I think). So it seats a little lower and is a little more exposed to those bumps and stones.
But my "protection'' is not heavy : just three layers of tape. 20 runs and no hit in the motor. I plan to use a piece of lexan in the future.
Well, on carpet or on track asphalt, I think this protection is not needed.
Cheers.
Old 05-03-2007, 12:30 PM   #13883
Well i found out that hpi parts will not work for everyones information, you can make them work but theres no point. Now my question is does anyone make aluminum parts for the xxx-s. I had to change my idea and now i am gonna do neon yellow and aluminum. Looking for turnbuckles, shocks, wheel nuts, hubs, steering servo arms, screws, anything that is shiny. website urls would be helpful. Thanx
Old 05-03-2007, 12:39 PM   #13884
MartinSorlie's Avatar
Asiatees
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
www.teamsmallsize.com
MartinSorlie is offline   Reply With Quote
Old 05-04-2007, 12:21 AM   #13885
Default How to add weight with a carbon 3200 li-po ?
Hi guys,
I've just bought a Team Orion Carbon 3200 Li-po battery. Great runs to come with my Mamba Max 7700 combo... well I guess.
Here is my question : any idea to make housemade weights to balance the car ?
Thanks for your answers.
Cheers.
Old 05-04-2007, 01:38 AM   #13886
Hi,
1:1 Gas Powered car tire balancer weight works perfect
Faiz is offline   Reply With Quote
Old 05-04-2007, 03:46 PM   #13887
can i use the shocks on asiatees website for the tc3 on my xxx-s. I want aluminum shocks.
Old 05-05-2007, 03:55 AM   #13888
I)arkness's Avatar
probly, as long as there the same length
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 05-05-2007, 11:36 AM   #13889
Default How much weights to balance the car with a 3200 Lipo ?
Faiz,
Well, I went to the rc hobby store this afternoon. I bought a lot of weights (200 gr for my Losi XXX-S and 200 gr for my T1 FK'05) for a few bucks.
I've got another question : how much weights do I have to add to balance the car ? What is the weight difference between 3300 and 3700 Nimh and 3200 carbon lipo ?
Thanks for the answers.
Cheers.
Old 05-07-2007, 08:57 PM   #13890
I)arkness's Avatar
well i know that my IB 3800 packs weight about 412grams
B.Portelli
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
