Old 03-30-2007, 07:40 AM   #13801
Sigearhead's Avatar
Trader Rating: 68 (100%+)
the transmission will handle it no problem, you just have to tighten up the belt a little so it won't skip on acceleration.you have to be more specific on settings. Where are you racing? carpet? tarmac? rubbers? foams? smooth? bumpy? etc....
Sigearhead is offline   Reply With Quote
Old 03-30-2007, 01:05 PM   #13802
Default Which motor pinion for Mamba Max 7700 ?
Sigearhead, thanks for your quick answers.
Well, i'm back from the rc store. Actually, after a long discussion with the dealer, I bought a mamba max 7700 (ESC + motor). I trusted him for years now and hope I didn't make a big mistake.
Question : is the 14 teeth motor pinion still good (with the yellow 88 teeth spur gear) ?
My first choice was a combo nosram matrix competition esc and 3.5 storm motor. He told me : 'for fun as you do, nothing else that the mamba max". And the mamba max is cheaper than the nosram combo.
Question : what's your idea about this choice ? Will it be a (huge) difference between the 2 systems ? For the record, I don't do competiton. I regulary run with friends seriously on a (mid) large smooth parking.
Well, about the settings : I run rubber tires (nosram vtec 30R) - mid-large smooth mid-grip parking track - 30W shock oil front & rear - purple springs front & silver springs rear - 3800 factory team nosram pack.
Cheers.
Team Losi XXX-S G+ (Mamba Max 7700)
Team Losi XXX-4 G+ (Nosram Matrix 2005 & Storm 3 stars)
Team Xray T1 FK '05 (Nosram Matrix ISTC & Storm 3.5)
Team Orion Avionics Advantage / Team Orion Li-po 3200 Carbon Edition (5) / Futaba 3PK
Blin is offline   Reply With Quote
Old 04-01-2007, 09:20 AM   #13803
Default spur adaptor
gentlemen,
where can i get an adaptor(spur)
car is just to slow in comparasion with other cars in the 540 class
i like this car ,strong good to drive easy to maintain and set up but just a bit to slow
any advise please
thanks
minnesh is offline   Reply With Quote
Old 04-01-2007, 09:27 AM   #13804
SteveM's Avatar
Trader Rating: 132 (100%+)
I found mine on eBay.
Originally Posted by minnesh
gentlemen,
any advise please
thanks
SteveM is offline   Reply With Quote
Old 04-01-2007, 12:44 PM   #13805
Default 540 silver can
how many guys run the 540 motor in this ?
spur and pinion set ups
thanks
Old 04-01-2007, 01:17 PM   #13806
thanks
Old 04-01-2007, 01:19 PM   #13807
LOSI123's Avatar
Trader Rating: 63 (100%+)
depends if its the 540 chrome can (shinny) or the 540 grey can, both are johnson motors, which one will you be running?
I know gearing recomendations for both
LOSI123 is offline   Reply With Quote
Old 04-01-2007, 06:42 PM   #13808
I)arkness's Avatar
whats the difference in the 2 motors as ive always wondered?
i run the mabuchi silvery one and it seems to run cooler.
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 04-02-2007, 08:00 AM   #13809
Default thank u thank u
thank u thank u
sir,
please
imn running a 540 in a losi xxx s 86 spur and 38 pinion 48dp
the car is just not fast enough to keep up to the other 540 cars
i like this car
can u please help with your suggetions
thanks
minnesh
Old 04-02-2007, 08:02 AM   #13810
Default sorry
i have both the shinny one and the not so shinny one
even have a old 4 slot one as well
thanks
Old 04-02-2007, 08:51 AM   #13811
PoLsKiE's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to PoLsKiE
maybe its just me... your final drive ratio is 4.14 thats wayyy to low. maybe your not fast enough because you have too much top end and its not winding out i run a 19t with 1 6.45 fdr and its perfect lots of speed try lowering your pinion maybe that would help
PoLsKiE is offline   Reply With Quote
Old 04-02-2007, 09:04 AM   #13812
Default 4.14
how du get to 4.14
Old 04-02-2007, 09:06 AM   #13813
PoLsKiE's Avatar
gearchart.com enter any ratio
Old 04-02-2007, 12:39 PM   #13814
Default lowering pinion
ok
so u mean that if i am using a 38 i can go lower like a 35 or maybe 33 or even lower
is that correct
can i still leave the spur to 86 or must i change that as well
i do have a 88 tooth]
thanks for your help
Old 04-02-2007, 12:41 PM   #13815
Default losi 123
need some help here guy
thanks
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
