Old 03-24-2007, 11:16 AM   #13786
PoLsKiE's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to PoLsKiE
motor temp going lower with higher fdr isent nessaseraly true if you go to high youll heat up your esc and your motor i did it i melted the endbell and unbonded the can magnets you want to get it middle lol not too much or too little
PoLsKiE is offline   Reply With Quote
Old 03-24-2007, 12:25 PM   #13787
Trader Rating: 10 (92%+)
Is the XXX-S still competetive with today's new cars? I haven't seen many comparison between it and any of the new all bling bling carbon/eye candy cars.
Intotheblade is offline   Reply With Quote
Old 03-24-2007, 12:42 PM   #13788
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Yes, it is still very competitive. You don't see them being raced competitively as often now because most races even at the club level always have the newest and shinniest products in hopes that it will make them faster.
Sigearhead is offline   Reply With Quote
Old 03-24-2007, 02:51 PM   #13789
team green's Avatar
I use mine as a back up to my xray T2 007. Couple of weeks ago I had to use it in the main because my one-way bearing took a dump on me and I did'nt have time to fix it.The car ran flawless my lap times were on par with my xray.
team green is offline   Reply With Quote
Old 03-24-2007, 04:31 PM   #13790
PoLsKiE's Avatar
yes very competetive ive turned some nice laptimes with it no problem my favorite aspect about this car over all other belt cars is inclosed belt no rocks or debris to worry about and its very smooth and consistant.....i recently sold my jrxs cause i liked my xxx-s better
Old 03-24-2007, 04:57 PM   #13791
LOSI123's Avatar
Trader Rating: 63 (100%+)
same, i love the car, keeps up no worries, as long as you set it up correctly.
but In rtr form its a bit of a heavy / poor handling dog.
LOSI123 is offline   Reply With Quote
Old 03-24-2007, 06:07 PM   #13792
LOSI123's Avatar
Default spur gear adaptor?
anyone here know where you can get the spur gear adaptor for the xxx-s
I have found a few places but they are all out of stock & i was told they are not going to be making them anymore.
Old 03-24-2007, 07:17 PM   #13793
Sigearhead's Avatar
I would just keep using the Losi spur gears, by the time you get an adaptor and your own spur, your adding weight to the drivetrain.
Old 03-28-2007, 12:35 AM   #13794
Default Which motor pinion for 3.5 brushless motor ?
Hi guys !
Well, with the beautiful weather we got here in Belgium, I'm back to racing sedan.
I plan to buy a combo Nosram matrix competion ESC & Storm Evolution brushless motor for my Losi XXX-S G+.
Can anyone tell me which motor pinion must I get for a 3.5 or 4.5 brushless motor ? I use the standard spur gear (yellow one) and rubber tires. I run on a mid-grip medium track.
Thanks for the answer.
Cheers.
Team Losi XXX-S G+ (Mamba Max 7700)
Team Losi XXX-4 G+ (Nosram Matrix 2005 & Storm 3 stars)
Team Xray T1 FK '05 (Nosram Matrix ISTC & Storm 3.5)
Team Orion Avionics Advantage / Team Orion Li-po 3200 Carbon Edition (5) / Futaba 3PK
Blin is offline   Reply With Quote
Old 03-28-2007, 12:59 AM   #13795
Yellow > did you mean orange?
if it is orange (90t spur-48dp) then using 14t pinion would take it into around 11.5 gear ratio recomended by Novak for 3.5R/4.5R
Faiz is offline   Reply With Quote
Old 03-28-2007, 01:13 AM   #13796
Sigearhead's Avatar
No I think he does mean the yellow.
The yellow one is 88t 48p. Or, if it's the 64P yellow one then it's 118t.
Old 03-28-2007, 08:59 PM   #13797
I)arkness's Avatar
hey guys i was wondering if you could tell me if its better to use the standard 3 spur gears or to use you own with the adapter.
as my situation is, im using around 4.1 with a 86 sp and 38 pn but i aslo can get it by using 69sp with 31 pn = 4.07 what would be better
to use a bigger spur or smaller one as ive heard theory that you have bigger spur gives more topend speed
what do people think about this
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 03-28-2007, 09:26 PM   #13798
Mike Haynes's Avatar
As far as i can say the gears are just numbers, if anything pick the gear size combo where the motor itself can sit lower.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-28-2007, 11:39 PM   #13799
Sigearhead's Avatar
I prefer to either run the 90t 48p or the 128 64p. I think the car has a better feel and better top end speed if you use a bigger spur, smaller pinion combo.
I would also just use the Losi spur gears, they are lighter than if you put your own spur and adapter on there. You want the least amount of rotating mass as possible.
Old 03-30-2007, 02:59 AM   #13800
Default 3.5 brushless motor settings
Thanks guys for your answer about the motor pinion.
I'll try the 14 teeth one and let you know.
Has anyone run a 3.5 brushless motor with the XXX-S G+ ? Can the transmission manage such a power ?
And what about the handling ? Any advice about the settings (oil, springs...) ?
Thanks.
Cheers.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
