Old 02-08-2007, 07:16 PM   #13741
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Originally Posted by losi-sw
are people still running this car....reason for asking is im getting one for free and wanted to know if can still compete with the latest TC's
thanks
I run it. Does pretty well.
Dasupacat1 is offline   Reply With Quote
Old 02-08-2007, 07:25 PM   #13742
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by nemisis
can anybody tell me wat would be a good spur to run in the losi on a tight track with a 27 turn stock motor in
Ran 32/128 on a 55mm foam.....car was still able to race against the current carbon fiber chassis.....the best part is, I don't have to worry about adding weight cause this car is over weight...
This car is plenty fast.....the reason I keeping her is this is a GREAT outdoor car, using her to run stock brushless to 3.5 brushless with Li-po and NEVER need to worry abotu chassis will get scratch or chip the carbon fiber, cause it will not happen on this car, car is a TANK.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 02-13-2007, 02:17 AM   #13743
rcstunt101's Avatar
Default SADDLE??
Hey, can anyone tell me if the xxx-s will accept saddle battery packs? Thanks in advance
rcstunt101 is offline   Reply With Quote
Old 02-13-2007, 08:02 AM   #13744
I)arkness's Avatar
yeah it will fit both saddle and stick packs but you might find it to be a tight fit to get the batteries down using the standard posts and strap thing unless you use tape.
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 02-13-2007, 08:21 AM   #13745
SteveM's Avatar
Trader Rating: 132 (100%+)
The Losi XXX-S is designed for 6-cell stick packs or 6-cell side-by-side packs. The chassis can accommodate up to 7 cells and you could use saddle packs as long as placed them side-by-side. Same setup as the TC3. If you want to use 3-cells per side then you are SOL.
SteveM is offline   Reply With Quote
Old 02-13-2007, 11:54 AM   #13746
Sigearhead's Avatar
Trader Rating: 68 (100%+)
You can do a little filling to the chassis and mostly to the battery strap and get a nice tight fit with the newer slightly bigger batteries.
Sigearhead is offline   Reply With Quote
Old 02-21-2007, 06:12 PM   #13747
I'm looking at doing the XXX-S to "XXX-R" conversion (rally car), but I can't find a set of 4 rally weapon shocks/springs. Anyone have ideas where I can find some? I made a thread in the WTB forum: WTB: Rally Weapon full shock set
Sweeney921 is offline   Reply With Quote
Old 02-21-2007, 06:37 PM   #13748
Would the front shocks from the xxx4 be a good alternate?
Old 02-27-2007, 10:00 PM   #13749
koinonas's Avatar
Need some help with my front diff.
I'm running the stock standard XXX-S RTR II and took apart the front diff this morning as it kept coming loose. I quickly found cause of it loosening up all the time (have been running it very tight and had actually crushed one of the thrust washers and foam diff seal to peices).
However, I also found that the other side of the diff was different to the instructions. The instructions show a diff coil spring and #4 washer that is held in place by the diff nut/carrier. But my diff only had a whole series of conical shaped plastic washers in place of spring and washer.
Is this normal, or should I buy a new set of coil spring and washer to replace the plastical conical ones (to bring it back to assembly as detailed in instructions)
koinonas is offline   Reply With Quote
Old 02-28-2007, 09:58 AM   #13750
Default help guys
what pinion and spur to run with a 540 motor please
how do u adjust or set the diffs
thanks
minnesh
minnesh is offline   Reply With Quote
Old 03-02-2007, 02:26 PM   #13751
koinonas's Avatar
Doesn't look like there are that many ppl running the XXX-S anymore....
As for gear ratos for 540 (standard Tamiya/Johnson silver can motor), it depends on your track. So best to check with other racers at your club.
The track that I race at is the size of a tennis court and has some fairly tight technical sections, with one long straight and sweeper. I'm currently running a 34 tooth pinion (from RW) with the standard 88tooth spur. But motor does get very hot (about 140degrees celcius) even with a 3racing heat sink and fan.
In terms of adjusting the diffs, there should have been an instruction sheet which came with the kit. But basically you need put one of the hex wrenches into the right outdrive to lock it diff screw in place and then turn the other outdrive. Its kind of hard explaining so go to http://www.teamlosi.com/Products/Def...rodID=LOSA0285 and click on the Getting Started to download the instructions on the diffs if you didn't get them with the kit.
Old 03-02-2007, 02:29 PM   #13752
koinonas's Avatar
Think I've got the problem solved. Looks like I got the XXX-4 (off-road version of the XXX-S) assembly of the diff rather than the normal XXX-S assembly. So will leave as is
Old 03-02-2007, 02:50 PM   #13753
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
You can also go to the Losi website and d/l the instruction manuel exactly for the XXX-S. Ive raced the this car for many years and absolutely loved it. Easy to work on, and easy to set up. So just pm me if u need some help with something.
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 03-03-2007, 04:16 AM   #13754
I)arkness's Avatar
hey koinonas if your car is pulling 140degrees celcius i think you might want to change you ratio.
i run 86spur with 38 pinion which is 4.14 FNR and my temp runs to maybe 45 degress C thats with a fan and heat sink with oiled bushings and thats on a 36 degree day
B.Portelli
Old 03-03-2007, 05:26 AM   #13755
koinonas's Avatar
45degrees? What type of track do you run on (is it a big open one, or tight technical one). And are you running the graphite chassis or the RTR plastic one (think my RTR setup weights about 1700g)
Struggling on the motor temps at the moment. Want to gear it for lower FDR, to keep up with the other guys, but motor seems to get real hot. The little 3Racing fan has started to die (which is probably contributing to high temps) so will probably replace that as well when I get the new diff parts in.
Have to admit, I've also struggled a bit with the drivetrain, and have only recently got it spinning reasonably freely (have oiled bearings, running belt looser and got the gear mesh right now). I did have to change the main diff bearings as I could never get the rubber shielded ones that came with the kit spinning freely (with the shields in). But it still doesn't roll as easily as the old ball raced TT01 (though does handle much better).
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
